  • Search this thread
  • Reply to this topic
30 replies to this topic | 50 praises
#21
Posted 05 January 2019 - 10:07 PM
Buadongdong
  • Premium member
    Buadongdong
    2Fast2Furious
    Author Image
    31,129
I changed the tire PSI To 220. Feels the same. My last pump was 98 at Caltex. Spark Plugs changed during last servicing.
Whne my current speed is 40km/h I hit the accelerator.. The car jerks and hesitates for about 1 second before RPM shoot ups to 2.5-3k and engine roars.
I Checked with my Mechanic. Battery problem won't affect acceleration. I'm not sure if it has anything to do with my car 02 sensor though.. Can't Think if anything else or its a common altis problem
Probably got the wrong car.. Not to your expectations.. You can get those aftermarket piggy-back throttle controller and your acceleration should improve.
lausai88, Carbon82 and Freeder praised this
#22
Posted 06 January 2019 - 06:26 AM
ER-3682
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    11,598
Maybe send your Car to Harnip Auto,he can help you better,by the way,Toyota Cars,cannot just fully step on the Throttle....you should drive gently..
Mazda 6..2.5.
#23
Posted 06 January 2019 - 10:31 AM
MCFmrhonda
  • Premium member
    MCFmrhonda
    5th Gear
    Author Image
    1,056
Doesn't sound like rim size problem.
Better to get 2nd opinion from elsewhere.
#24
Posted 10 January 2019 - 07:14 PM
Deckbuild
  • Premium member
    Deckbuild
    Author Image
    8,519
It hesitated and did not accelerate for another 1 or 2 secs even when i pressed more on the accelerator pedal
I think my question here is whether is it possible that the change from Performance Tires to Touring Tires (Yokohama AE50) can cause these kind of acceleration issues? Or should I be looking at rim size (I do believe it is possible as stock is 15, compared to current one which is 17).
You got the car brand new and change the rim from 15 to 17?
#25
Posted 10 January 2019 - 08:11 PM
ismailmiller
  • THREAD STARTER
  • ismailmiller
    Author Image
    3
The previous owner changed to 17 Inch Rim. I send to Hanip before. He changed the fuel filter and it helped abit before the problem came. Seems like after consecutively filling 98 petrol.. The car acceleration is smoother. I suspect my fuel pump tot issue maybe becos I leave my petrol to low level quite frequently.
#26
Posted 10 January 2019 - 08:17 PM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,995
Just to clarify,  yours is AT and not CVT?
When I was using AT,   overfilling of ATF will cause sluggish performance.
If AT,  if there hesitation, likely it could be transmission problem.
AFAIK.
The common understanding is that the battery is used to start the car.
After starting the car,  the alternator will charge the battery.
The current will be reduced as the battery get sufficiently full.
If the battery is weak,  it will ne continuously charged by the alternator using higher current.
So far, I have been getting better response from the accelerator everytime I change out a weak battery.
#27
Posted 11 January 2019 - 12:49 AM
ismailmiller
  • THREAD STARTER
  • ismailmiller
    Author Image
    3
AFAIK.
Corolla made back in 2008 are 4 Speed Transmission. My Amaron battery will be 1 year 6 months this coming Feb. My colleague said my car probably has gearbox issue as when going downhill.. My RPM will shoot up if I press my brakes slightly hard. I will probably change another new battery during my next servicing
#28
Posted 11 January 2019 - 08:42 PM
Kklee
  • Kklee
    6th Gear
    Author Image
    2,995
Check the ATF and ensure not overfilled.
#29
Posted 11 January 2019 - 10:38 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    15,219
The problem with TS is that he did not even describe the problem clearly , end up making others to guess his problems and suggest solutions that will lead to nowhere, and he continues to suspect rim and tyre size.
Ash2017 praised this
#30
Posted 12 January 2019 - 01:02 PM
ER-3682
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    11,598
Exactly,even from 14" to !7" won't affect Performance so badly,unless he fitted FlintStone Stone Wheels. [:p]  [:p]
Ct3833 praised this
Mazda 6..2.5.
#31
Posted 31 January 2019 - 05:35 PM
Yamapi
  • Yamapi
    6th Gear
    Author Image
    3,179
Sorry, want to ask what is the pcd of 2016 Altis? Is it 5x100?
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Autostrasse Pte Ltd
Autostrasse Pte Ltd  |  Rating   Submit Review
Reviewed by Vavavoom118  |  Neutral Newbie
First off, let me say this. I drive an Alfa Romeo. So for a lot of you reading this, you may say good luck! In my 30 years of motoring, I've had more than my fair share of dodgy mechanics and given my relatively layman-like knowledge of car mechanicals, call me a sucker for pain. But I love my bella and in the past 8 years that I've had Greg and Jenn from Autostrasse ta... » Read More
MSP Far East Pte Ltd
MSP Far East Pte Ltd  |  Rating   Submit Review
Reviewed by JEFFRE  |  Neutral Newbie
Foreign cars can be a PAIN, I personally attest to this fact unless you find the right guys that really know what they are doing and can actually offer you an affordable price.
That said, i am very thankful to have found these guys at MSP. I personally double check out the parts and they are reasonably price. I basically interviewed several shops before I d... » Read More
Related Motor Directory search on sgCarMart.com : Power Enhancement
Quick Reply
Tags: toyota, corolla, altis, size and 2 more...
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
