8J Rims.
  • 1
  • Search this thread
  • Reply to this topic
15 replies to this topic | 25 praises
#1
Posted 13 January 2019 - 12:57 PM
ER-3682
  • THREAD STARTER
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    10,944
Just check with Experts here,can 8Jx18 Rims fit 255/35-18 Tyres.?
BabyBlade praised this
Mazda 6..2.5.
#2
Posted 13 January 2019 - 08:37 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    11,612
J is for passenger car, so it is ok. 8" to fit 255 tyre will be too narrow. The tyre will have 1" of sidewall protruding out from the rim mount on each side to cause the tyre to look fat. The other consideration is because of the excessive oversize, the "J" mount between the tyre and the rim may not sit very nicely.
8.5" rim will be  the minimum, 9" will be ideal.
I could be wrong.
#3
Posted 13 January 2019 - 09:19 PM
ER-3682
  • THREAD STARTER
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    10,944
Thanks.
Mazda 6..2.5.
#4
Posted 13 January 2019 - 09:22 PM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    11,992
I could be wrong.
You are right. 9in will be the best. The 35 profile sidewall will be well supported to get the best out of the 255 width.
Ct3833 praised this
#5
Posted 14 January 2019 - 02:35 PM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,823
technically for 255/35/18
best opimum wheel width 9.5 J (9j is min 10.5 max)
if you come across a shop tell you without hesitation 8J can use with 255/35/18 , he properly do not know what tire and wheels, only KNow  Monies.
#6
Posted 14 January 2019 - 07:41 PM
ER-3682
  • THREAD STARTER
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    10,944
Another choice will be stick to 245 width,but upgrade the Profile to 40,instead of 35,the front..use stock size,225/40-18,but i am afraid can affect the ABS & Traction Control...Systems.
Mazda 6..2.5.
#7
Posted 15 January 2019 - 01:24 AM
Icetee168
  • Premium member
    Icetee168
    2nd Gear
    Author Image
    199
Edited by Icetee168, 15 January 2019 - 01:24 AM.
#8
Posted 15 January 2019 - 12:13 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    11,612
by  changing the aspect ratio from 35 to 40 is not an upgrade.   It will affect or even damage your transmission if your car is a 4WD or AWD . In addition, it will cause quicker tyre wear unnecessarily.
For 2WD cars, it will result in front and back wheels having slightly different revolution per min because of the difference in wheel diameter. it should not affect ABS or traction control but it will affect your speedometer accuracy depending on which wheel the speedometer reading is taken from.
Looks like your car is having  staggered wheels setup, why do you want to change the aspect ratio in the first place ?  If you want  40 aspect ratio, 225/40R18 would  be the perfect match with your front, but you need to check the width of the rim at the rear could take 225  tyres.
Edited by Ct3833, 15 January 2019 - 12:15 PM.
#9
Posted 15 January 2019 - 12:24 PM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    11,992
never seen 9.5 recommended for 255/35/18.
most manufacturers use 9in rim width for measurements which i assume is the optimal. for Michelin PS4s its 8.5-10in as recommended width.
i would assume that they know better?
https://www.tirerack...=Pilot Sport 4S
#10
Posted 15 January 2019 - 12:57 PM
Sky61
  • Sky61
    5th Gear
    Author Image
    1,055
Been thru 245/40/18 for 9j, 235/40/18 for 8.5j, and now 265/35/18 for 9.5j. Honestly not much difference in speedometer readings or handling feel.(stock 225/45/17). More rubber means more contact with the ground so technically better grip n road feel. No damage to transmission, maybe wheel bearings will wear out faster but so far no such experience too.
#11
Posted 15 January 2019 - 10:30 PM
ER-3682
  • THREAD STARTER
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    10,944
Yes,my M240i came with Staggered Rims,the stock rear came with 245/35-18,which Diameter is a tad smaller than the front with 225/40-18...i prefer the rear a bit bigger...now i going to opt 245/40-18 for the rear for a better look...thanks everybody for the advice... [thumbsup]  [:)]
Edited by ER-3682, 15 January 2019 - 10:31 PM.
Ct3833 praised this
Mazda 6..2.5.
#12
Posted 15 January 2019 - 11:07 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    11,612
Haha wah nice. Next time must declare earlier when you have a few hundred horses hidden under your bonnet.
By the way this might make your car look better F 245/35ZR19 / R 265/35ZR19....Steam roller wheel from the rear view.
#13
Posted 16 January 2019 - 05:16 PM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,823
SORRY for worng interpretation.
after double checked is 8.5-10 as from some tire company site
anyway 9.5 rim width is still within the recommended range
#14
Posted 16 January 2019 - 05:19 PM
Jamesc
  • Premium member
    Jamesc
    2Fast2Furious
    Author Image
    180,155
This thread is so misleading.
I thought the 8 was B.
So disappointed.
:D
SiLangKia praised this
Say no to harsh artificial chemicals
that pollute the earth
and go natural. [thumbsup]
#15
Posted 17 January 2019 - 07:09 AM
ER-3682
  • THREAD STARTER
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    10,944
[:p]  :a-confused:Jamesc needs new Specs...
So disappointed.
:D
Jamesc praised this
Mazda 6..2.5.
#16
Posted 02 March 2019 - 12:59 AM
bryangreene
  • bryangreene
    Author Image
    -23
I plan to upsize the tyre of my Bolero DI 4x4 to Maxxis Bighorn 31x10.5R15. I have lifted the vehicle through leaf cambering and shackle lift and gained around 3 inches lift. I am looking to increase the track of the vehicle by going in for offroad negative offset steel rims. What is the ideal wheel for the above mentioned tyre? Should I use 8J rims with negative offset or can I use 10.5J rims with negative offset? Can I use a 10.5J negative offset steel rim on Bolero DI 4x4 without it fouling with the suspension or insides of the wheel well?
Edited by bryangreene, 02 March 2019 - 01:01 AM.
  • 1
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Stamford Tyres
Stamford Tyres  |  Rating   Submit Review
Reviewed by Ycchee  |  Neutral Newbie
Quick, efficient and friendly service. I had a punctured tyre. Came here on 28 January 2019 at around 8.45am morning. The mechanic helped to take out the tyre and showed me that there was a screw stuck between the tyre tracks. He pulled out the screw and applied sealant. I was charged $10 and after making payment at the cashier next door, the patched tyre was already m... » Read More
Optima Werkz Pte Ltd
Optima Werkz Pte Ltd  |  Rating   Submit Review
Reviewed by MichaelYong_190664  |  Neutral Newbie
Like to thanks Ah Guan and Thomas for being very helpful with my E250. They will make sure my car has no more issue with my suspension and replace it since it's under warranty. PI cars can trust them because they are back by liberty insurance for owner need not to be worry if they are taking car of your car.
The only setback is some of their technicians might... » Read More
Related Motor Directory search on sgCarMart.com : Tyres & Rims
Quick Reply
Tags: bmw, rims, tyre width. and 1 more...
