  • 1
  • Search this thread
  • Reply to this topic
14 replies to this topic | 27 praises
#1
Posted 05 February 2019 - 07:50 AM
AndyHo
  • THREAD STARTER
  • AndyHo
    Clutched
    Author Image
    47
any bro tried the above? any improvement? I had installed ground king rectifier and still considering whether should proceed with installing the power nano ground cables. by the way nano grounding cables is expensive, it is different from the usual grounding cable. It is $120-130 per point. Wondering it is necessary to install both since both gives almost the same performance improvement. Your thought bro?
#2
Posted 05 February 2019 - 08:11 AM
Colin03
  • Premium member
    Colin03
    4th Gear
    Author Image
    868
Hi Bro,
My advise is not to install as the pricing is too high to justified for such a stuff.
#3
Posted 05 February 2019 - 08:17 AM
Wt_know
  • Wt_know
    2Fast2Furious
    Author Image
    51,942
snake+oil ...
#4
Posted 05 February 2019 - 09:23 AM
Vratenza
  • Premium member
    Vratenza
    2Fast2Furious
    Author Image
    62,099
Theatre-Bizarre-Snake-Oil-Flask-OUT-OF-S
Circles Life Referral Code: HTWWD
#5
Posted 05 February 2019 - 09:42 AM
Fcw75
  • Fcw75
    2Fast2Furious
    Author Image
    68,833
Don’t bother.
SiLangKia and 1 Anonymous member praised this
#6
Posted 10 February 2019 - 08:03 AM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,368
one point for $120-$130? crazy price. the wire made of gold?  dont waste time. get a normal grounding cable will do the same job. money hard to earn leh. dont be carrot.
#7
Posted 10 February 2019 - 08:52 AM
AndyHo
  • THREAD STARTER
  • AndyHo
    Clutched
    Author Image
    47
Saw some bro installed 5 points, 10 points... lol... i rather spend the money on something else..
#8
Posted 10 February 2019 - 08:58 AM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    38,051
Let's look at jumper cables.
On the market, there are usually 2 types:
1. Pure copper
2. Aluminum-clad copper
The latter is much cheaper, but the former conducts much better.
What's the diff here is the physical metal.
But no one markets simple copper, they market wires with fancy name that doesn't make it conduct much better.
#9
Posted 10 February 2019 - 09:00 AM
Cheesey74
  • Premium member
    Cheesey74
    6th Gear
    Author Image
    3,666
If ur car can run means can run, if cannot run install smlj also no use, at most placebo + ego boost, better to donate the mod money to hungry children or destitute old folks..
Tianmo praised this
BSS "From Each His Best"
_______________________
Good Practice cultivate Good Karma. Be nice to people :-)
#10
Posted 10 February 2019 - 09:01 AM
AndyHo
  • THREAD STARTER
  • AndyHo
    Clutched
    Author Image
    47
1. Pure copper
asked the workshops why so expensive... they said it is nano technology. Further asked them what is nano technology? they cant explained ... just said it is german technology. Was quoted $650 for 5 points... I think i can get a race chip for $650... lol
#11
Posted 10 February 2019 - 09:04 AM
RogerNg_185295
  • Premium member
    RogerNg_185295
    6th Gear
    Author Image
    3,578
1. Pure copper
Are the wires still made from copper despite the fanciful names?
#12
Posted 10 February 2019 - 09:17 AM
Kb27
  • Premium member
    Kb27
    2Fast2Furious
    Author Image
    38,051
"nano" is one of those marketing buzzwords designed to fool the uninitiated.
Cables, wires are pure physics. The larger it is, the more current it can carry, with less resistance and heating effect.
Nothing can change that for now, unless there's a quantum leap in technology like maybe aliens perfected metal.
By the way, your car doesn't need anymore grounding wires.
FYI, it is more full of grounding wires all over the chassis. Just bcuz you don't see it, doesn't mean it's not there.
These wires usually ends in a bolt fixed on the chassis.
The car is a negative ground. Every current return is attached to the chassis, including the battery negative post.
If there's a fault with one of the grounding point, it will show up, like a light badly lit, not working properly, horn, wiper, etc. not working.
So, unless you have an old car that's rotten and full of corrosion which affects the ground, there's no need to add more redundant wires.
The funny thing is that some people will pay $500 for redundant fancy grounding wire.
Then when their battery died, they used a cheap $20 (ultra-thin) jumper cable, unable to carry the required current, and wondering why their jump didn't work.
Vratenza and Jamesgetz praised this
#13
Posted 10 February 2019 - 11:37 AM
StreamRSZ
  • Premium member
    StreamRSZ
    5th Gear
    Author Image
    2,368
but than again there will be some people who enjoy paying 10 points for 650 to buy the name "nano" than show off to their frd say they spent 650 for this nano grounding and based on butt feel to say it improve this and that.
to me they are just pure foolish. of cos is their money their call. at the end of the day i will just laugh and say stupid.  [laugh]
#14
Posted 10 February 2019 - 12:57 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    107,581
I needed a better performance car in terms of handling and engine refinement.
I changed car instead of wires.
Tianmo praised this
QUOTE
do to others what you want others to do to you......
#15
Posted 10 February 2019 - 03:10 PM
AndyHo
  • THREAD STARTER
  • AndyHo
    Clutched
    Author Image
    47
650 is for 5 points, not 10 points 😂
Cannot afford to change that why go forcthese kinda of gimmicks... say to change car is easy.
  • 1
Back to Performance and Tuning  ·  Aftermarket Top Reply to this topic
Quick Reply
Tags: toyota, toyotagrounding, nano and 6 more...
