  • Search this thread
  • Reply to this topic
20 replies to this topic | 5 praises
#1
Posted 26 February 2019 - 04:53 PM
darkwish
  • THREAD STARTER
  • darkwish
    Author Image
    17
its a 2011 toyota camry currently on Michelin Energy XM2. 215/60R16 95H. need to change all 4 tyres since its been like 4 years already. not sure what tyres to change to so just here to get some recommendations.
Thanks!
#2
Posted 26 February 2019 - 05:16 PM
Pureland107
  • Pureland107
    Author Image
    10
Installed 4 215-55-17 continental uc6 for my camry at Klang Malaysia yesterday, the cost is RM1,260.00 cheap cheap.
Pm me if u want the address
Regards
#3
Posted 26 February 2019 - 05:19 PM
MQX87511
  • MQX87511
    5th Gear
    Author Image
    1,566
Thanks!
Yokohama BluEarth RV-02,
quiet, fuel saving, wet grip
Edited by MQX87511, 26 February 2019 - 05:19 PM.
#4
Posted 26 February 2019 - 08:52 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    53,173
For me I will still stick to Michelin range of tires. Although they cost more dan most brands but they also can last longer dan most brands. Performance wise they are up to expectations. Noise wise when it's worn it's not noisy. Of course noise levels when worn largely depend on the tire pressure. If you have tpms your tire pressure is consistent throughout your tires will stay quiet. Noise usually is also an indication of uneven wear. A lot of factors to consider.
For me I look at the tire grooves. Those with fine grooves are usually quiet tires but it also depends on your car's sound insulation. Wet tires have larger grooves so that the grooves can move more water at a faster rate so that tire and tarmac have a better surface contact. Therefore fine grooves tires may not perform as well as wet tires in the wet but they do better in dry conditions. An all rounder will have a combination but it may not be quiet. For tires they are like that you have some kinda compromise. No perfect tires. So when ppl say wet performance and quiet at the same time it doesn't make sense.
Edited by Watwheels, 26 February 2019 - 09:01 PM.
thesoul praised this
Too much to think about...
#5
Posted 26 February 2019 - 08:56 PM
Kopites
  • Kopites
    2Fast2Furious
    Author Image
    24,942
For me I look at the tire grooves. Those with fine grooves are usually quiet tires but it also depends on your car's sound insulation. Wet tires have larger grooves so that the grooves can move water so that tire and tarmac have a better contact. Therefore fine grooves tires may not perform as well as wet tires in the wet but they do better in dry conditions. An all rounder will have a combination but it may not be quiet. For tires they are like that you have to some kinda compromise. No perfect tires. So when ppl say wet performance and quiet at the same time it doesn't make sense.
Agreed with Michelin tyre on the comfort and grip. Continue with Michelin.
However there is one down side. Very soft sidewall so be careful not to scratch too often against the kerb.
#6
Posted 26 February 2019 - 09:32 PM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    53,173
Just bear in mind some of the info on tires.
Dry performance tires usually give better fuel economy and speed performance. Plus most are quiet. But in wet conditions it's better you drive slow.
Wet performance tires give poorer fuel economy on dry conditions and it also slows your speed. Pplus they are usually more noisy cos of the larger grooves. Its only pro is better performance in wet conditions.
So dont be fooled by the tire dealer when buying tires or the BS they dish out to you. If they dont have what you are looking for move on to other dealers.
#7
Posted 26 February 2019 - 09:59 PM
Lala81
  • Lala81
    2Fast2Furious
    Author Image
    124,144
Thanks!
I'm quite happy with my Goodyear f1 asymmetric 3. Good grip in wet for my driving, brakes fine, quiet, reducing rolling resistance compared to my stock 17" Michelin.
Not sure if it's available in your dimensions.
#8
Posted 26 February 2019 - 11:42 PM
darkwish
  • THREAD STARTER
  • darkwish
    Author Image
    17
yea my current tires have quite some scratches already albeit being 4 years. havent really tried other tires before either so dont really know the feel of other tyres. but i might just stick with the michelin cause so far find online not alot of tyres with the dimensions. will be calling up shops tomorrow to check. appreciate the replies thanks alot!
#9
Posted 27 February 2019 - 01:32 AM
Smith121
  • Smith121
    Banned
I drive a Toyota Camry Hybrid 2016. Before I change the originals, the handling was not good. Noisy and not comfortable. My tyre guys introduced CC6 to me. I really hesitated at first but why not give a try - 4 new set.
Three weeks later when I drove to my holiday hill resort - 300 km. Unknowingly I felt the drive was so refreshing and comfortable when I reach my destination. Only during dinner I realized that the tyres were so dependable and comfortable.
Everyone must try - no harm done !
#10
Posted 27 February 2019 - 08:30 AM
SZ_ford
  • SZ_ford
    4th Gear
    Author Image
    784
Thanks!
really depends on what u want: grip, long lasting, quiet, shorter braking distance....
some of the tyres i can think of,
BS turanza T005 (quiet)
Goodyear f1a3 (grip)
Michellin Primacy (quiet)
Michellin ps4 (grip)
yokohama blueearth (long lasting)
#11
Posted 27 February 2019 - 08:41 AM
Beregond
  • Beregond
    2Fast2Furious
    Author Image
    23,921
f1a3 dun have his size.
ps4 also out
if buy yokohama for a premium seldan like camry,  i would recommend 551 for premium comfort and low noise
bridgestone should be t005A now instead.
and not to mention dunlop latest ve303
Edited by Beregond, 27 February 2019 - 08:41 AM.
#12
Posted 27 February 2019 - 09:59 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,850
size 215 60 /16 mostly use for comfort drive, is not practical for tire manufacturers to design performance tire.
in the market here if i can recall correctly there are few of 10 typre here
MIcheline is always 1 of my list , to me you pay what you get, and tires are the only 4 contacts between you(+ passenger) and Road,
further more you will know the Qualities and Safety important when you are in critical situations.
1 thing to take note buy the NEEDS not Wants is the Best.
Regards
this is a Good tire , correct me if I am wrong , this tire made in Malaysia ?
#13
Posted 27 February 2019 - 05:06 PM
Pureland107
  • Pureland107
    Author Image
    10
Yes, it’s made in Malaysia and its very comfortable.
At first, I went to tire shop in Batu Pahat, and they charged me RM 400.00 for each tire.
Next day, when I visited Klang, I was introduced by a local that one shop gives very good price for all tires. Klang charge only RM315.00 for each, and alignment for 4 wheels only RM32.00.
Edited by Pureland107, 27 February 2019 - 05:25 PM.
#14
Posted 27 February 2019 - 08:03 PM
Tohto
  • Premium member
    Tohto
    2Fast2Furious
    Author Image
    112,178
Go for Primacy 4. Quiet and decent performance tyre.
#15
Posted 08 March 2019 - 11:54 PM
gccp23
  • gccp23
    1st Gear
    Author Image
    73
I want to change to 235/45/18 ps4, or eagle f1 a3. But a few shops said no such size. Weird, coz i can see these offering in official SG website.
#16
Posted 09 March 2019 - 10:00 AM
Roberttan
  • Roberttan
    5th Gear
    Author Image
    1,850
may be the shop you went to meaning they do not have such size ,
anyway the 235/45/18 is not very common , but i am sure you should able to find them in the market.
Regards the Sg website or any Official Website , some are not updated , or typo or not avialable in our Shore .
#17
Posted 09 March 2019 - 10:11 AM
SZ_ford
  • SZ_ford
    4th Gear
    Author Image
    784
U can try 245/40/18 or 235/40/18. These 2 are more common. And your car should be able to use
#18
Posted 09 March 2019 - 10:13 AM
t0y0ta
  • t0y0ta
    6th Gear
    Author Image
    3,885
Should be getting common soon,
new Lexus ES, Toyota Camry, VW Passat, Skoda Superb all use this exact size.
#19
Posted 09 March 2019 - 12:55 PM
gccp23
  • gccp23
    1st Gear
    Author Image
    73
I saw in Singapore Goodyear and Michelin official site. Anyway out of 5 tyres shops, only 1 have the size hahaha
#20
Posted 09 March 2019 - 01:17 PM
Beregond
  • Beregond
    2Fast2Furious
    Author Image
    23,921
Odd size and if they dun have regulars that need them.
They wont keep stocks.
But if u want them to order for u .
I am sure 5/5 willing to do that
Back to Tyres and Rims  ·  Aftermarket Top Reply to this topic
Bridgestone Ecopia EP300
Bridgestone Ecopia EP300  |  Rating   Submit Review
Reviewed by Ricktyp  |  Neutral Newbie
Review of BridgeStone EP300 Tyre
Have just installed this tyre 3 days ago from AB under their buy 2 get 2 free promotion. The tyre is 195/65/15. They gave me a week 17 for yr 2017 and Made in Thailand Though it is only 3 days old, find that the tyre has very good rolling... » Read More
Reviewed by SGCMSupertoad76  |  Neutral Newbie
Quiet and feels smoother
I swop from stock Yoko AE50 14" to this tyre 195/55/15. There is an immediate difference. This tyre has very good rolling properties. It seems to accelerate easier and can roll longer. Handling is sharper compare to the yoko which felt mush... » Read More
Related Product Guide search on sgCarMart.com : Economy Tyre
Quick Reply
Tags: toyota, camry, tyre, need and 3 more...
