Fitvip Supersonic April 19, 2019 Share April 19, 2019 Coming back home last night the car tyre monitoring system indicated a leak in front R tyre. Checked it out upon reaching home and indeed discovered a nail. 1. Extracted the nail out with an orange pliers. 2. Plug in a round file to smoothen and enlarge the hole. 3. Standby the sticky worm inserted into the needle eyes. 4. Insert into the hole with some force, with about 3/4 way in and pulled it out quickly. 5. Spray some water or bubbled one to check for leak. I pumped up the tyre a bit with a portable inflatable pump and drove to a petrol kiosk to fully inflate the tyres and do a reset on the tyre monitoring system. Do note that I am on RFT and hence could drive back home. Non RFT tyre should find a safe place to stop immediately and proceed to mend the tyre. Lucky me it was the front tyre, might need to take it off if it was at the rear which would restrict the hand movements. Fun, yes, Satisfaction, oh yes. Haha, you are damn good! Can snap step-by-step photos that come with instructions! ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 19, 2019 Author Share April 19, 2019 Haha, you are damn good! Can snap step-by-step photos that come with instructions! First thing when the tyre punctured, instinct tells me to start a thread in mcf. Hahahhaha Joke aside, all reair kits from Ali or taobao. I just ordered another set with metal handle. The plastic one I just used disintegrated into pieces after i pulled the plug out. I kept inside the car for more than a decade. Link to post Share on other sites More sharing options...
Ano727 2nd Gear April 19, 2019 Share April 19, 2019 Haha I used to have those worms. But got lazy over the years and also now prefer an internal patch . Did it only 2-3times in the past 20years. Other times I managed to discover the puncture early and pumped enough air to last to the shop to get it mended via internal patch. Would recommend to everyone to carry an air pump and just inflate it enough to get you to the shop to get it repaired via internal patch. Most punctures are not catastrophic where all the air leaks out. But rather a nail or screw where the leak is slow. So just an air pump is more than enough. The toughest worm I had to do was on a back tire and the hole was at an angle and not straight in. Took some effort lying on the ground. Lots of Kpkb in the end hahha. I was also looking for internal patch when I had tyre puncture, but all shops I asked only do the work thing. Where are the shops you know that do internal patch? I also prefer these over worm, if time permits. Thanks. Link to post Share on other sites More sharing options...
Mkl22 Twincharged April 19, 2019 Share April 19, 2019 I was also looking for internal patch when I had tyre puncture, but all shops I asked only do the work thing. Where are the shops you know that do internal patch? I also prefer these over worm, if time permits. Thanks. I have been only to 2 shops. SE tyre and hurry tyre. I’m sure there are others. Link to post Share on other sites More sharing options...
Ano727 2nd Gear April 19, 2019 Share April 19, 2019 I have been only to 2 shops. SE tyre and hurry tyre. I’m sure there are others. I googled both and looks like they are far from Punggol area where I stay. Any recommendation of internal patch in North/Northeast area? Thanks. Link to post Share on other sites More sharing options...
Kopites Supersonic April 19, 2019 Share April 19, 2019 (edited) my car come with those liquid bottle (milky colour) and an auto pump. once I connectEd the pump using car ciggis inlet. pump up drove to the nearby service station about 3km away. all fine for me. Edited April 19, 2019 by Kopites 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 19, 2019 Author Share April 19, 2019 I googled both and looks like they are far from Punggol area where I stay. Any recommendation of internal patch in North/Northeast area? Thanks. I once done it at cinema tyre shop at TPY. Can't recall the cost though. 10 or 15..... 1 Link to post Share on other sites More sharing options...
Solar Turbocharged April 20, 2019 Share April 20, 2019 The patch isn't meant to be long term... Still need to get that tyre replaced. I kenna before. Thought after patch can drive happily ever after.. Then flat again after a few weeks Link to post Share on other sites More sharing options...
Fitvip Supersonic April 20, 2019 Share April 20, 2019 If using the worm, the external part needs to be trimmed. If not, the part will loosen the sealing as it rubs against the road surface. 1 Link to post Share on other sites More sharing options...
Matrix0405 5th Gear April 20, 2019 Share April 20, 2019 Bought a set of worm patch after coming to this thread. Worm + service at petrol kiosk used to be $6, last done 2yr ago was $10 . not sure abt 2019 pricing. Link to post Share on other sites More sharing options...
Mkl22 Twincharged April 21, 2019 Share April 21, 2019 The patch isn't meant to be long term... Still need to get that tyre replaced. I kenna before. Thought after patch can drive happily ever after.. Then flat again after a few weeks I thought internal patch is the recommend repair and will last the life of the tire. It’s the worm repair that is temporary, but I have driven till the tire is worn with the worm too. 1 Link to post Share on other sites More sharing options...
awhtc 6th Gear April 21, 2019 Share April 21, 2019 I always get workshop to do a $10 worm patching whenever I get a nail in my tyre. They always coat with a layer of liquid (glue?) before inserting the worm. Thereafter, they trim off the worm neatly. I never have any leak issue thereafter and I always thought this is the standard practice until income across "internal patching" here. Link to post Share on other sites More sharing options...
Tohto Hypersonic April 21, 2019 Share April 21, 2019 (edited) I always get workshop to do a $10 worm patching whenever I get a nail in my tyre. They always coat with a layer of liquid (glue?) before inserting the worm. Thereafter, they trim off the worm neatly. I never have any leak issue thereafter and I always thought this is the standard practice until income across "internal patching" here. Internal patching is the best way. More work is involved as it need to remove tyre from rim. And it will be more ex.My regular tyre shop charge $15 for internal patching which is good price. Edited April 21, 2019 by Tohto Link to post Share on other sites More sharing options...
Volvobrick Supersonic April 21, 2019 Share April 21, 2019 Internal patching is the best way. More work is involved as it need to remove tyre from rim. And it will be more ex. My regular tyre shop charge $15 for internal patching which is good price. A lot of workshops don't want to do internal patch. Where's your WS? 15 is very reasonable. Link to post Share on other sites More sharing options...
Mkl22 Twincharged April 21, 2019 Share April 21, 2019 Internal patching is the best way. More work is involved as it need to remove tyre from rim. And it will be more ex. My regular tyre shop charge $15 for internal patching which is good price. $15 is cheap. Lousy lazy shops already charge $12 for the worm. And they don’t even remove the tire or check for leaks after the job. Just a cursory spraying of soapy water around if they even bother. And most will fob you off, saying can wan...... Link to post Share on other sites More sharing options...
mersaylee Supersonic April 21, 2019 Share April 21, 2019 A lot of workshops don't want to do internal patch. Where's your WS? 15 is very reasonable. Agreed. Please share good lobang... Link to post Share on other sites More sharing options...
Tohto Hypersonic April 21, 2019 Share April 21, 2019 (edited) A lot of workshops don't want to do internal patch. Where's your WS? 15 is very reasonable.Eng Wah tyre at TPY lorong 8.$15 not sure because I am their regular customer or standard price. Edited April 21, 2019 by Tohto 2 Link to post Share on other sites More sharing options...
Solar Turbocharged April 21, 2019 Share April 21, 2019 I thought internal patch is the recommend repair and will last the life of the tire. Itâs the worm repair that is temporary, but I have driven till the tire is worn with the worm too.Paiseh, then should be external worm patch. ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Tourador Tyres
Tourador Tyres
Tyre puncture
Tyre puncture
Yokohama Advan Apex V601
