  • Search this thread
  • Reply to this topic
57 replies to this topic | 55 praises
#1
Posted 15 May 2019 - 10:40 AM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    3rd Gear
    Author Image
    251
Hi guys seeking help here for some issues for my ride.
Assuming the car has been warmed up after a 45min drive.
- approaching traffic light RPM seems to decrease to about 400-500. Engine vibrates but not violently.however it did not stall once. Once coming to a stand still RPM will hover around 600 rpm. Slight vibration felt but car did not stall. All these is when the vehicle is in D mode.
- idle in P or N mode have a very slight vibration that seems normal. Around 700-800rpm. Vibration is definitely much lesser than in D mode.
- When engaged in R mode. The vehicle will jerk and rpm drops to 600. It reverses normally. No need to step on the gas however vibration can be clearly felt
Servicing has been done recently
New oil for both engine and transmission
New coolant
New spark plug
New MAF sensor
Last but not least. Welcome for any valuable feedback. Thanks!
BabyBlade praised this
#2
Posted 15 May 2019 - 11:20 AM
Volvobrick
  • Volvobrick
    2Fast2Furious
    Author Image
    31,501
Engine mounts? Coil? Dirty Injectors?
#3
Posted 15 May 2019 - 11:26 AM
Lava
  • Lava
    5th Gear
    Author Image
    1,039
dirty throttle and need some cleaning
Beregond praised this
#4
Posted 15 May 2019 - 11:28 AM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    13,671
Most important is what car?
Count-Bracula praised this
#5
Posted 15 May 2019 - 11:56 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    54,237
New coolant
New spark plug  Check
New MAF sensor  Check
What else left to check?
How about vacuum leak? Check vacuum hoses.
Faulty ignition coil?
Good luck.
Feel so rich. Or just an illusion?
#6
Posted 15 May 2019 - 12:03 PM
Justdaniel
  • Premium member
    Justdaniel
    Clutched
    Author Image
    37
New coolant
New spark plug
New MAF sensor
I have similar problem like yours.
Done throttle cleaning but still problem exist.
Finally fault is spark plug housing crack.
Your spark plug might be new but when the mechanic over tightened might cause crack.
Watwheels and Watwheels praised this
#7
Posted 15 May 2019 - 12:16 PM
Contipro
  • Premium member
    Contipro
    5th Gear
    Author Image
    1,696
New coolant
New spark plug
New MAF sensor
which car, model and engine, so anyone with similar experience can share.
Please read below link before response. Let's keep MCF environment harmony..
http://www.mycarforu...les-guidelines/
disclaimer: no real person living or dead involved on production of above.
#8
Posted 15 May 2019 - 12:38 PM
Glidemetro
  • Glidemetro
    Author Image
    22
New coolant
New spark plug
New MAF sensor
I can almost be certain it’s the fuel pump. Replaced it and it will solve the problem....
#9
Posted 15 May 2019 - 01:47 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    3rd Gear
    Author Image
    251
Thanks for all the valuable input.
It’s a Suzuki Swift Sport with 120k millage.
Throttle body was cleaned recently less than a month ago as it was the first troubleshooting point. Second was the MAF sensor, replaced it.
So far I have yet tested the ignition coil. However spark plug is in good condition and wasn’t overtighten.
Next I would be looking into ignition coil and/or fuel pump.
Recently have some intermittent starting issues as well. Can hear a click but nothing comes on. Battery seems to be an unlikely culprit as voltage and health indicator is in green condition
#10
Posted 15 May 2019 - 02:06 PM
Volvobrick
  • Volvobrick
    2Fast2Furious
    Author Image
    31,501
The battery can still be bad despite the "Green" indicator. I have one recently like that (unable to fully charge) and replaced it.
#11
Posted 15 May 2019 - 02:15 PM
Glidemetro
  • Glidemetro
    Author Image
    22
Do not assume the 4 ignition coil is functionally properly . 1 bad coil can cause sudden drop. Most workshop will have the basic computer scan tool to check the ignition coil if functional properly else error code indicating which coil kaput . If “rough idling “ still appears and u have done the throttle cleaning and new spark plugs. ...... Fuel Pump is the culprit...
#12
Posted 15 May 2019 - 02:30 PM
Glidemetro
  • Glidemetro
    Author Image
    22
Recheck your tramission fluid level... u sure the Mechanic TOP up the right way? Sakali not enough also can cause lor rpm...
Yewheng praised this
#13
Posted 15 May 2019 - 02:40 PM
Knoobie
  • Premium member
    Knoobie
    Supercharged
    Author Image
    6,525
I had a different car and had similar issue before. what happened for my case was the ignition sensor was faulty.
Doesn't mean you drive a faster car, you can travel at 70kph on a clear lane 1 with a train of cars behind you...
that is what lane 2 is for..
#14
Posted 15 May 2019 - 03:20 PM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    13,671
Itâs a Suzuki Swift Sport with 120k millage.
So far I have yet tested the ignition coil. However spark plug is in good condition and wasnât overtighten.
Have the exact same car but much lower mileage. No such problems yet. How long has this been happening? Brand of petrol used and octane?
Try changing petrol brand and octane? Using 95 still has a very very slight ping at times.
How old is the battery? Any parking camera? How do you test the battery?
Hear click and nothing happens is unlikely to be fuel pump. Even with faulty fuel pump, the car will always crank.
#15
Posted 15 May 2019 - 03:54 PM
Ichibawa
  • Premium member
    Ichibawa
    6th Gear
    Author Image
    3,166
Better bring back to where you service it. Seems like your engine is going into a stall and it choke itself back to life. Probably the spark plugs or the MAF sensor but nobody can be sure. Just get it rectified by mechs.. we can only play guess work here.
#16
Posted 15 May 2019 - 04:14 PM
Goldenvodka
  • THREAD STARTER
  • Premium member
    Goldenvodka
    3rd Gear
    Author Image
    251
Been using both SPC and Esso 95
Battery age 2 years old. No parking camera, only dash cam which only operates when I am driving.
No ICE. Basically no additional accessories to drain power.
I took this vehicle over for a couple of months and basic servicing and ATF was changed. Now I suspect they are using the wrong ATF.
By the way, when the ac is on, all the symptom is reduced by half.
Edited by Goldenvodka, 15 May 2019 - 04:17 PM.
#17
Posted 15 May 2019 - 04:24 PM
Inlinefour
  • Premium member
    Inlinefour
    NOS-ed
    Author Image
    17,268
last time my inline six 2.2 litre engine same and it is jumping like frog [:(]
go back to AD then replace the faulty ignition coil  [bigcry]
was 2004 and paid almost 500 cos warranty dont cover wear and tear  :a-m1524:
#18
Posted 15 May 2019 - 04:57 PM
Mkl22
  • Mkl22
    NOS-ed
    Author Image
    13,671
Try orig Suzuki oil.
#19
Posted 15 May 2019 - 05:56 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    16,139
Starting issue could be starter, may not be related to the vibration issue. Have you checked engine mount ? Engine did not die off that mean could be simply engine mount worn out.
Aircon on symptom reduced because when compressor is on, the idle rpm will go up by at least 200 to 300 rpm, and when u have a higher rpm, your engine will have less vibration.
#20
Posted 15 May 2019 - 07:15 PM
Contipro
  • Premium member
    Contipro
    5th Gear
    Author Image
    1,696
my pass experience..
1) faulty one of the ignition coil
2) faulty cam position sensor and crank position sensor
normally fuel pump should not have problem in your case, if lost of power during acceleration then i may suspect fuel pump as well.
Dynamics Mechanic Pte Ltd
MSP Far East Pte Ltd
MSP Far East Pte Ltd  |  Rating   Submit Review
Reviewed by eddymhdishak  |  Neutral Newbie
These guys were amazing! Those reviews here do not lie! I was looking for a simple oil change but cringed at the thought of having to take ever crowded Sin Min xxx workshop so after searching through SGcarmart I found MSP Car Workshop. They couldn't have been nicer and quickly did my oil change while I waited, they explained everything they checked and didn't try to pus... » Read More
Autowerkz Remanufacturing Pte Ltd
Autowerkz Remanufacturing Pte Ltd  |  Rating   Submit Review
Reviewed by JDyan  |  Neutral Newbie
Workshop well stocked with plenty of used Japan gearbox. Done my car in 1 day. Keep it up!
Related Motor Directory search on sgCarMart.com : Repair & Servicing
Quick Reply
Tags: vibrate, rpm, engine, rough and 2 more...
