nigel8210 3rd Gear May 17, 2019 Share May 17, 2019 I have changed my AGM battery after 2.5years, 70Ah Varta once Now the start/stop function fail again after 2 years, I thought AGM batteries can last longer than conventional type Does it mean now my battery is weak again presumably that's the cause for the start/stop failure recently? Ride : W205 C200 year 2014 ↡ Advertisement Link to post Share on other sites More sharing options...
Ysc3 Twincharged May 17, 2019 Share May 17, 2019 avg lifetime of a car batt usually 2 years. and stop/start function not helping. most ppl will disable it as they say it hurts the transmission. 2 Link to post Share on other sites More sharing options...
Beregond Supersonic May 17, 2019 Share May 17, 2019 I have changed my AGM battery after 2.5years, 70Ah Varta once Now the start/stop function fail again after 2 years, I thought AGM batteries can last longer than conventional type Does it mean now my battery is weak again presumably that's the cause for the start/stop failure recently? Ride : W205 C200 year 2014 Benz orginal battery if fail 2 years i think very fast , normally last 3-4 years. u can try check the auxiliary battery . (normally this spoil got the auxiliary battery malfunction) error 2 Link to post Share on other sites More sharing options...
Elmo 4th Gear May 17, 2019 Share May 17, 2019 Maybe alternator weak and not charging up the aux battery? Link to post Share on other sites More sharing options...
Blueray Hypersonic May 17, 2019 Share May 17, 2019 I have changed my AGM battery after 2.5years, 70Ah Varta once Now the start/stop function fail again after 2 years, I thought AGM batteries can last longer than conventional type Does it mean now my battery is weak again presumably that's the cause for the start/stop failure recently? Ride : W205 C200 year 2014 do you use start stop all the time and have short driving journies ? Link to post Share on other sites More sharing options...
nigel8210 3rd Gear May 17, 2019 Author Share May 17, 2019 do you use start stop all the time and have short driving journies ? short driving journies maybe But all the while the first thing I do is to OFF the start stop function upon starting the car as I hated it Now it will always be YELLOW and wont turn GREEN to activate the function in a way, its good I don't have to press the OFF button anymore But I am worried and concerned if the battery is weak as I plan to go for a road trip in Malaysia soon PS: Not cheap leh, the last change for the 70Ah Varta was like $400, and its those outside tyre battery workshop Link to post Share on other sites More sharing options...
Blueray Hypersonic May 17, 2019 Share May 17, 2019 short driving journies maybe But all the while the first thing I do is to OFF the start stop function upon starting the car as I hated it Now it will always be YELLOW and wont turn GREEN to activate the function in a way, its good I don't have to press the OFF button anymore But I am worried and concerned if the battery is weak as I plan to go for a road trip in Malaysia soon PS: Not cheap leh, the last change for the 70Ah Varta was like $400, and its those outside tyre battery workshop If you are planning to drive to malaysia then I would suggest checking the battery and changing if necessary. Conti cars are a bit sensitive to weak battery and may throw up other issues. Do confirm if yours is just one battery or one main battery + one aux battery. For those models with aux battery, should be the aux battery powering the auto start stop. 1 Link to post Share on other sites More sharing options...
No_worries 6th Gear May 17, 2019 Share May 17, 2019 I won’t be able to comment on other makes. I just change my battery on my car (2 years old) as the start stop didn’t work any more. Once it is changed, start stop works normally . In our climate and short trips, I suppose car batteries won’t last . Link to post Share on other sites More sharing options...
Discoburg Supersonic May 17, 2019 Share May 17, 2019 Bring the key fob next to the start/stop button. Does it start up the ride? Link to post Share on other sites More sharing options...
Kb27 Supersonic May 17, 2019 Share May 17, 2019 Start stop batteries don't seem to last long, due to the extra stress on it. The battery has to start the engine many more times, compared to a normal battery starting cycle. Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 17, 2019 Share May 17, 2019 The battery needs to be properly charged periodically. Depending on the car alternator is not enough. That's why I have an external battery charger to help me refresh my battery every few months. 1 Link to post Share on other sites More sharing options...
Old-driver 5th Gear May 17, 2019 Share May 17, 2019 Same problem... went to see and see to check but they say no issue so battery wasnt changed. drove home and still haven't seen green today yet. 1 Link to post Share on other sites More sharing options...
Solar Turbocharged May 18, 2019 Share May 18, 2019 Start stop batteries don't seem to last long, due to the extra stress on it. The battery has to start the engine many more times, compared to a normal battery starting cycle. I remember reading somewhere that cars with auto SS will require special kind of battery, not those normal ones due to the reason u mentioned. Anyway, mine konked after less than 2 years. Not sure if it's exactly due to the auto ss.. I have car camera recording 24x7 that may cause excessive drain. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic May 18, 2019 Share May 18, 2019 Start stop batteries don't seem to last long, due to the extra stress on it. The battery has to start the engine many more times, compared to a normal battery starting cycle. start stop or EFB battery have more crank cycle. suppose to last longer then normal battery .(under same useage condition) if your car is starting more cos of the stop start function , could be driving habit, or just off the function. Link to post Share on other sites More sharing options...
Kb27 Supersonic May 18, 2019 Share May 18, 2019 (edited) I remember reading somewhere that cars with auto SS will require special kind of battery, not those normal ones due to the reason u mentioned. Anyway, mine konked after less than 2 years. Not sure if it's exactly due to the auto ss.. I have car camera recording 24x7 that may cause excessive drain. SS requires either AGM or EFB battery. Car camera draining battery 24x7 should have benefited from the above, as compared to regular battery. But then this EFB tech is quite new, so it remains to be seen how effective it is. AGM is not new tech, but it suffers from heat, unless placed in a cool location. Imo, the lack of water in AGM allows it to be heated directly, so is less lasting. Edited May 18, 2019 by Kb27 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged May 18, 2019 Share May 18, 2019 The battery needs to be properly charged periodically. Depending on the car alternator is not enough. That's why I have an external battery charger to help me refresh my battery every few months. Is it a Normal Battery Charger.?Thinking of buying 1,can shoot a picture of your Charger.? Link to post Share on other sites More sharing options...
flashbang Turbocharged May 18, 2019 Share May 18, 2019 2 years very good already, mine 1.5 and it's dead. 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic May 18, 2019 Share May 18, 2019 (edited) Is it a Normal Battery Charger.?Thinking of buying 1,can shoot a picture of your Charger.? AGM requires a lower charging voltage, typically around 13.5V Regular lead-acid battery voltage charging voltage is higher, around 14.4V If you place a AGM in a car with alternator putting out 14.4V, it tends to overheat and don't last very long. So be careful with the charging voltage. Edited May 18, 2019 by Kb27 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Mercedes AMG GT Gen 2
2023/2024 6th Generation Mercedes E-Class (W214)
2014 Mercedes CLA
2014 Mercedes CLA
[Spyshots] 2022 2nd Generation Mercedes Benz GLC
Mercedes Owners Thread
Mercedes CLE
Mercedes CLE
