  • 1
  • Search this thread
  • Reply to this topic
12 replies to this topic | 13 praises
#1
Posted 12 June 2019 - 05:48 PM
Icedbs
  • THREAD STARTER
  • Icedbs
    NOS-ed
    Author Image
    16,041
Hi all,
Thesedays, my aircon sometimes blow out warm air when engine is idling, but it will be ok when the car is moving.
I suspect that the condenser fan is not running well.
My question is, how often does this fan cuts-in and run?
When I first on my air-con (while car is stationary), I realise that this fan doesn't run.  Then it suddenly comes alive (together with another fan (radiator fan?) next to it) maybe 5 minutes later. Then after running for like 3 minutes, it will stop again....and won't come back on again until like 10 minutes later.
How to check if this fan is performing as it should?
#2
Posted 12 June 2019 - 08:25 PM
Apple-Tree
  • Premium member
    Apple-Tree
    6th Gear
    Author Image
    2,543
I think check and change the connector of the fan lor.  Very likely you need to replace it.
If not fix, may damage you evaporator due to high pressure from the compressor lor.
Hi all,
Volvobrick and 1 Anonymous member praised this
#3
Posted 12 June 2019 - 08:54 PM
Contipro
  • Premium member
    Contipro
    5th Gear
    Author Image
    1,562
Hi all,
if fan still able to start stop.
but issue when stationary, moving ok,
then most likely the fan not performing example fan speed have reduced due to faulty.
or possible compressor faulty where need higher engine rpm to compress the refrigerant to correct level.
just approach the air con specialist for help.
I have experienced both failure separately.
Please read below link before response. Let's keep MCF environment harmony..
http://www.mycarforu...les-guidelines/
disclaimer: no real person living or dead involved on production of above.
#4
Posted 12 June 2019 - 09:18 PM
RadX
  • Premium member
    RadX
    Moderator
Cooling coils too
RESPECT is only for the DEAD!
CirclesLife Code: RADX89
#5
Posted 12 June 2019 - 09:47 PM
Icedbs
  • THREAD STARTER
  • Icedbs
    NOS-ed
    Author Image
    16,041
Cooling coils too
Yeap, I suspected this too........but it is hard to tell if it is the cooling coil (evaporator) or the condenser fan not working. The workshop says the refrigerant levels are ok and the compressor is working fine. They say is cooling coil.
However if is is cooling coil issue, then car moving or idling would still blow out warm air isn't it?  Or there is something  I don't know?
Edited by Icedbs, 12 June 2019 - 09:48 PM.
#6
Posted 12 June 2019 - 10:23 PM
Contipro
  • Premium member
    Contipro
    5th Gear
    Author Image
    1,562
ya. dont know what logical idea for cooling coil issue based on your scenario.
for mine 1st workshop check found compressor pressure low at idle and shoot up when ram engine rpm. not stable.
however when I went to 2nd workshop for replacing the faulty compressor they found it work normal, which is puzzle as well.
anyway I replace at 2nd workshop and it work till I scrap the car.
#7
Posted 12 June 2019 - 10:59 PM
Ct3833
  • Ct3833
    NOS-ed
    Author Image
    15,300
Hi all,
Your fan at the  heat exchanger in front of your car is likely working normally .  When the aircon compressor clutches on(when you hear a fairly loud mechanical click noise), the fan motor will start to spin , when the compressor clutches off,  the fan will stop spinning.  You can confirm it by listening out for the compressor clutch on and off sound.
Your aircon get colder when car is moving because more air is flowing throw the heat exchanger when your car is moving, it help cooling down your aircon system better. When the car stop, the whole aircon system is depending on the fan to cool down the  heat exchanger , the cooling will be not as good.
Bottom line is there is inefficiency somewhere  along the system. In any aircon system, cooling comes from either the coil or the compressor, so likely one of the two. It is more likely that the compressor not functioning perfectly, of course it could be due to the cooling coil too but less likely.
But i notice you mentioned the exchanger fan will turn on 10 min after it is off, this is very long, the fan may have problem too. In our hot weather climate, the compresor will turn on in less than a minute or two, 10 min sounds far too long. Your aircon mechanic should be able to advise.
Edited by Ct3833, 12 June 2019 - 11:05 PM.
#8
Posted 13 June 2019 - 12:40 AM
Raychay
  • Premium member
    Raychay
    5th Gear
    Author Image
    1,526
Based on my cars with 2 radiator fans, 1 of the fans will be running when as long as the aircon is turned on.
Only the 2nd fan will kick in when the water temp goes up and stops when the water temp drops
#9
Posted 13 June 2019 - 07:21 AM
Contipro
  • Premium member
    Contipro
    5th Gear
    Author Image
    1,562
anyway what the car model, at least other of same model can share their experiences
#10
Posted 13 June 2019 - 08:38 AM
Watwheels
  • Premium member
    Watwheels
    2Fast2Furious
    Author Image
    53,896
How old is your car?
Most likely the condenser cooling coil is dirty. After much driving your AC condenser cooling coil will be clog with dirt and debris. You give it a thorough wash. If you are able to remove your front grill it will be ideal to have it washed. If cannot there's also another way.
Buy the 3M aircon spray cleaner.
Aim thru the front grill and spray at the aircon condenser.. Follow the instructions. Allow the solution to do its thing for a couple of minutes.
Note: do this when the condenser is cool. Use a pressurized washer to hose it down. If dont have just use your thumb to create some kinda pressure to hose it down. I usually do this every 2 years. Empty a can of the ac cleaner into the radiator and ac condenser and flush them with water.
Edited by Watwheels, 13 June 2019 - 08:40 AM.
Arya...who would have thought?
#11
Posted 13 June 2019 - 10:07 AM
Icedbs
  • THREAD STARTER
  • Icedbs
    NOS-ed
    Author Image
    16,041
Mazda 6 HB, the older model.......
Thanks bro....
I have a feeling that the condenser fan is not working well.  I can see that the compressor clutch does engage once every few minutes, but the condenser fan does not come on.
I will analyse this carefully again...
#12
Posted 14 June 2019 - 03:36 PM
Icedbs
  • THREAD STARTER
  • Icedbs
    NOS-ed
    Author Image
    16,041
Just an update, I believe the condenser fan is not working as it should.  When the air-con is switch on, this fan never runs and it will run only when the radiator fan kicks-in. Once the radiator fan stops turning, the condenser fan will also stop.
#13
Posted 14 June 2019 - 05:35 PM
Boxster
  • Premium member
    Boxster
    4th Gear
    Author Image
    865
Check the sight glass see if can see liquid refrigerant flowing thru.
Since you are saying ac is cool when car is moving and not cool when idling why not rev the engine in neutral at traveling RPM to eliminate the chance that the compression is weak during idling .
Edited by Boxster, 14 June 2019 - 05:36 PM.
Contipro praised this
男人不坏女人不爱
男人有钱就变坏
女人变坏就有钱
  • 1
Dynamics Mechanic Pte Ltd
Han Revolution
Han Revolution  |  Rating   Submit Review
Reviewed by AhBeanBearBearChong  |  Neutral Newbie
Was looking out for a shop for affordable sound proofing when i came across Han Revo. Quoted a affordable price, proceed to do on the same day.
When arrived, the staff were polite and ask for the preferred material.
The whole sound proofing for roof last about 1 hour and immediate effect was shown when it started to rain. No more rattling sound... » Read More
Pro-Jex V2D Auto Pte Ltd
Pro-Jex V2D Auto Pte Ltd  |  Rating   Submit Review
Reviewed by Kayaloti  |  3rd Gear
Received my free service voucher from MCF team and immediately called Vincent to make an appointment to have my car service.
My car was attended to immediately upon my arrival and mechanic was assigned to perform the work scope after instructions were passed down.
Voucher includes oil change, air-con rejuvenate and throttle body cleaning. All done within 1.5hr... » Read More
Related Motor Directory search on sgCarMart.com : Pro-Jex V2D Auto Pte Ltd, 9 Degree Auto Pte Ltd, Han Revolution, Air Conditioning
Quick Reply
Tags: mazda, air-con, condenser fan and 6 more...
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
