Fuelsaver Supercharged July 27, 2016 Share July 27, 2016 I think you are ready. Email korpas.com with your Chassis and Engine no. to double confirm P/N. Here is the template : Subject Title : Enquiry on KIA Carens (1D) - Air Conditioner Assembly Hi, Need your help on this matter. My KIA Carens Air Conditioning is failing, there is a oil mark and gas leak at the hose, the compressor is also noisy. I have checked internet and found the following P/N. The following are the P/N : a) 97762-1D200 Discharge Hose b) 97763-1D200 Suction Hose c) 97701-1D200 COMPRESSOR ASSY My VIN is KNAFGXXXXXXXXXX and engine number G4KAXXXXXXXX. Please help to advice if the part is correct. Thanks!! Rgds, <Name> Write simple, unless you write korean. If you screwup installing, PM me or call Ah Hock. Good luck. Tia bro. ↡ Advertisement Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear July 27, 2016 Author Share July 27, 2016 What Tia ? Bro. Tia bro. Link to post Share on other sites More sharing options...
Fuelsaver Supercharged July 27, 2016 Share July 27, 2016 What Tia ? Bro. oh, it's thanks in advance (TIA) Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear September 11, 2016 Author Share September 11, 2016 My ownself fix aircon, not cold again. Turn out to be radiator fan connector. Never like to cut any wiring in the car, but this time have to cut away the connector. When to those heartland shop and bought a connector and electrical duck tape and rejoin the wiring. 20 mins job. ↡ Advertisement Link to post Share on other sites More sharing options...
Mazda evaporater failed at 25 000 km
Air-Con Compressor Spoilt
A/C repair in JB
A/C repair in JB
Need advice for Axio repair cost
Car dealers ownself set up portal
Aircon compressor replacement for Hyundai Avante
Use aircon compressor to dry bak kwa
Axio / Fielder evaporator (cooling coil) leak
