  • 1
  • Search this thread
  • Reply to this topic
15 replies to this topic | 76 praises
#1
Posted 07 July 2019 - 02:21 AM
Fastfive1
  • THREAD STARTER
  • Premium member
    Fastfive1
    6th Gear
    Author Image
    3,210
I find taiwanese car products to be inferior or a knock off of something established. My friend has a 4 Piston D1 Spec brake caliper. He recently got ripped off the the local dealer of D1 Spec products when he had to change his brake pads. 300 bucks for supposedly good quality D1 Spec pads. That's just nonsense. I decided to get him to remove the brake pads and get it measured. I searched the internet high and low for pads that would meet those measurements. Turns out that you can use brake pads meant for Brembo Calipers. You can easily get original brembo pads for that application for less than 100 sgd if you order it online. Heck you can even get dixcel pads for around 170 sgd if you prefer that brand.
Don't believe that you cannot use anything other than D1 Spec Brake pads in a D1 Spec Brake Caliper. Most of these taiwanese brake companies copy the design from other established brake companies. If you own a D1 Spec BBK, please note that you have options when it comes to what brake pads. You just need to measure your existing brake pads and use the internet to search. The dealer of D1 spec BBK will definitely say you cannot use anything other than their pad so that they can hold you ransom. But f**k them!
Discoburg, Kia7200, Macrosszero, James996, Ronkovic and 1 Anonymous member praised this
#2
Posted 07 July 2019 - 01:54 PM
Macrosszero
  • Macrosszero
    NOS-ed
    Author Image
    11,473
Thanks for the public service announcement, although personally, I would only believe in aftermarket brakes if they have enough testing and racing expertise behind them, and a reputation that is worth cheap counterfeiters copying them - think brands like Brembo, AP Racing, etc.
The gene pool could use a bit of Clorox at times
#3
Posted 07 July 2019 - 02:06 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    106,159
I have always been sceptical on BBK.
I mean doesn't mean you put on a bigger brake means you brake better.
What about the rear puny brake that was left untouched and how balanced is the brake force distributed across the front an rear?
Many people who upgraded merely did and listen blindly to sales talk.
Mkl22, Tianmo, Ronkovic, Ichibawa and Jellyfish praised this
QUOTE
do to others what you want others to do to you......
#4
Posted 07 July 2019 - 02:48 PM
Dannnn
  • Dannnn
    3rd Gear
    Author Image
    398
depends on your car drivetrain, for FWD, rear is ok as most force is from the front , u will find no point upgrading your rear.
if RWD den maybe different, i read online before. from stoptech web or something.
#5
Posted 07 July 2019 - 03:01 PM
Hamburger
  • Premium member
    Hamburger
    2Fast2Furious
    Author Image
    106,159
It would be good to have a theory to back up. And surely there must be right combination for front and back.
I have seen 6 pot bbk at the front  and smallish stock fitted at the back. Really cartoon looking.
QUOTE
#6
Posted 07 July 2019 - 04:09 PM
Dannnn
  • Dannnn
    3rd Gear
    Author Image
    398
Having bigger pot doesn't= stopping power tho. Good brake pads contribute alot. N of cos tyres.
If u see new performance car. Mostly front is bbk and rear they just painted the original caliper red.
Street driving i believe shldnt be an issue. Hard core track driver then another story..
peasant praised this
#7
Posted 07 July 2019 - 04:21 PM
Fastfive1
  • THREAD STARTER
  • Premium member
    Fastfive1
    6th Gear
    Author Image
    3,210
I've tried the D1 Spec BBK. It performs decently and still works after being 10+ years old. It has better braking compared to stock brakes. But I just don't like how the local agent/dealer for these parts will charge you significantly more for pads which most likely aren't even made by them. This is their business model, bring in cheap BBKs but charge a high price for pads. Not even branded pads, want 300 bucks for it.
I will get my friend to get a set of dixcel pads and give it a go. See the difference in performance.
#8
Posted 08 July 2019 - 11:08 AM
kobayashiGT
Your title is misleading. I change it to brake pads instead.
All work and no play makes Jack a dull boy
#9
Posted 08 July 2019 - 05:04 PM
Ichibawa
  • Premium member
    Ichibawa
    6th Gear
    Author Image
    3,187
If the brake pads have the same metal backing plate and cake height then its compatible. The only difference will only be how the cake is cut (1 or 2 slots, chamfered or non chamfered edge) and the ingredients and method used to bake the cake.
Our cars are all front brake bias for drivability reasons. Even RWD cars will have bigger front brakes. When you step on the brake, all 4 brakes will bike just that to a different degree.
Many other components (e.g. booster, shock absorber, brake hose, brake fluid, tyres, etc)  will affect brake stopping distance. Having bigger brakes doesn't mean you stop better.
To me the OEM caliper will suffice. Just maintain the car timely, upgrade to slightly more metalic pads or slotted disc of the same size. Adding unsprung weight to the car will only cause an imbalance and parts to wear prematurely.
kobayashiGT praised this
#10
Posted 08 July 2019 - 05:57 PM
Stratovarius
  • Premium member
    Stratovarius
    6th Gear
    Author Image
    4,552
From stoptech webpage:
 "If there are no thermal concerns with the rear brakes (and on a front-engine street car there rarely are) then by installing a rear big-brake kit all you are doing is (a) spending money and (b) adding unsprung weight. This is not usually viewed as favorable, unless you like driving a heavy, expensive car.
Of course, if you decide to upsize your rear brake system components you can also impact the front-rear torque relationship, and consequently you can "bias" the "balance" more toward the rear. Go too far, and the rear brakes could lock before the fronts. Again, not the end result you were expecting, right?"
Up to you to evaluate if logical or not.
Hamburger praised this
#11
Posted 08 July 2019 - 06:11 PM
Beregond
  • Premium member
    Beregond
    2Fast2Furious
    Author Image
    25,456
What can u expect if u go to a d1 spec dealer and u are equip with d1 spec piston .
100+1 % they will only sell u d1 spec brake pad.
If like we go ad. If u ask for any other brand other then orginal they will tell u cannot.
Othello praised this
#12
Posted 08 July 2019 - 06:25 PM
kelaihoyin
  • Premium member
    kelaihoyin
    5th Gear
    Author Image
    1,178
If stock brake pads can activate ABS, then isn't the tyres the limiting factor instead of the pads? [laugh]
I would think better pads are less susceptible to brake fading? Unless one is hard-braking and going REALLY hard into corners every time i don't see how brake fading comes into play during street driving.
#13
Posted 08 July 2019 - 08:02 PM
ER-3682
  • Premium member
    ER-3682
    NOS-ed
    Author Image
    11,796
Like the latest Toyota Supra,Front 6 pots [thumbsup] ,Rear Single Pot "Sliding"Caliper [thumbsdown] .
Mazda 6..2.5.
#14
Posted 08 July 2019 - 09:05 PM
Fastfive1
  • THREAD STARTER
  • Premium member
    Fastfive1
    6th Gear
    Author Image
    3,210
The problem is when D1 Spec doesn't have certain data available, you have no choice but to get the pads from the agent. Even your typical workshops outside don't know what to do and will probably have to source these parts from the D1 Spec agent. Pui! You also cannot buy D1 Spec specific pads easily online. I doubt you can find pads on ebay that say it will fit D1 Spec Calipers. You have to pull out the brake pads, go measure it and find out which other brake pad matches this size. If y'all need pictures of the measurements, PM me and I will send it to you.
#15
Posted 08 July 2019 - 09:55 PM
Renegade777
  • Premium member
    Renegade777
    6th Gear
    Author Image
    3,723
I am not sure why people are saying negative things about Taiwan BBK. Have they tried it before commenting ? I am also apprehensive on Taiwanese BBK in the initial stage, however I decided to give it a try after having some extra spare change. After that, no regrets and brakings has never been better. The brakes bite is heavenly and I wont go back to lousy stock brakes anymore. Either branded or Taiwan after market BBK is for me.
Edited by Renegade777, 08 July 2019 - 10:11 PM.
#16
Posted 09 July 2019 - 01:40 PM
Fastfive1
  • THREAD STARTER
  • Premium member
    Fastfive1
    6th Gear
    Author Image
    3,210
Don't get me wrong. D1 Spec BBK is decent. But I don't like how their agents/dealers in singapore do things. 300 bucks for unknown brake pads? That's just stupid. These BBKs are copies of brembo, ap racing and even endless brake calipers. Their brake pads should not cost more than the real deal.
  • 1
Back to Performance and Tuning  ·  Aftermarket Top Reply to this topic
D1 Spec Big 4 Pots Brake System
D1 Spec Big 4 Pots Brake System  |  Rating   Submit Review
Reviewed by LennyLeo  |  Clutched
High Performance!
I have a very good experience with D1 Spec Big 4 Pot. It give me both the high performance and street driving! It is engineered with a floating disc mounting system and a billet aluminum hat to reduce unsprung weight for lower temperatures, b... » Read More
Reviewed by Afrohead  |  Neutral Newbie
Awesome brake kit!
My previous brakes were ending their useful life, so I went ahead to get a set of these D1 Spec Big 4 pot after being recommended by my relative. I drive quite fast, hence brakes that I need are those that won't give way while braking at high... » Read More
Related Product Guide search on sgCarMart.com : D1 Spec Big 4 Pots Brake System, D1 Spec Big 6 pistons Brake Kit System, Brake Kit
Quick Reply
Tags: bbk, taiwan, copy, spec, don39t and 2 more...
