Cirruslogic Clutched August 14, 2019 Share August 14, 2019 Installed iRoad X9 in my car last year. Had set the voltage threshold to 11.8 V. Went for a vacation for 7 days. When I came back I could not unlock the car with smart key and could not start the engine. The iRoad had drained the car battery. So it looks like after it detects 11.8 V it does not disconnect the power. It still draws power from the car battery. Lesson learnt. Remove the power plug and USB cable from the camera if you are going on vacation. I don't know which workshops can install the battery pack that is discussed in some forums. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Daniu82 Supercharged August 14, 2019 Share August 14, 2019 Installed iRoad X9 in my car last year. Had set the voltage threshold to 11.8 V. Went for a vacation for 7 days. When I came back I could not unlock the car with smart key and could not start the engine. The iRoad had drained the car battery. So it looks like after it detects 11.8 V it does not disconnect the power. It still draws power from the car battery. Lesson learnt. Remove the power plug and USB cable from the camera if you are going on vacation. I don't know which workshops can install the battery pack that is discussed in some forums.I think 11.8V is too low, the recommended should be 12.3 or 12.4V. To be safe remove the wire at the camera. You can look for Nam Huat, they helped to remove and re-install the X9 from my old car and transfer to my new car. They should have the extra battery too. Call them 1st. 1 Link to post Share on other sites More sharing options...
Adrianli Hypersonic August 14, 2019 Share August 14, 2019 11.8v is too low. I dont think the camera drained the battery. It probably cut off at the set voltage of 11.8v. You must also consider other electrical components in the car is also draining the battery like car alarm system and the car's computer. Link to post Share on other sites More sharing options...
Shibadog Turbocharged August 14, 2019 Share August 14, 2019 I kena the same problem even though I set the LBP at 12.3V on my prev iRoad T8. From then on, I unplug it whenever I go away for more than 5 days. x9 has a power button. Can use that to power off. Or plug out the power cable to be double sure. But don't forget to reconnect/power on when back. I forgot it once n drove around for weeks without the cam on. LOL Link to post Share on other sites More sharing options...
Cirruslogic Clutched August 15, 2019 Author Share August 15, 2019 Thanks everyone. I wish there was an external battery pack that could be put in the car. This external battery pack would supply 5V power to the iRoad or other 5V devices. The battery pack can be charged when driving. If the battery pack drains, only the iRoad and other 5V devices are affected. The car computer and car alarm are not affected by the battery pack draining. Link to post Share on other sites More sharing options...
Tannl 1st Gear August 15, 2019 Share August 15, 2019 (edited) Thanks everyone. I wish there was an external battery pack that could be put in the car. This external battery pack would supply 5V power to the iRoad or other 5V devices. The battery pack can be charged when driving. If the battery pack drains, only the iRoad and other 5V devices are affected. The car computer and car alarm are not affected by the battery pack draining.There are external battery packs that can be installed. I have a 6000mah cellink neo installed in my car. And iroad x9 uses 12v by the way. Edited August 15, 2019 by Tannl 1 Link to post Share on other sites More sharing options...
Dinkydong 3rd Gear August 15, 2019 Share August 15, 2019 http://iroad.kr/global/?page_id=6127 Thanks everyone. I wish there was an external battery pack that could be put in the car. This external battery pack would supply 5V power to the iRoad or other 5V devices. The battery pack can be charged when driving. If the battery pack drains, only the iRoad and other 5V devices are affected. The car computer and car alarm are not affected by the battery pack draining. 1 Link to post Share on other sites More sharing options...
shawnigami 1st Gear September 10, 2019 Share September 10, 2019 On 8/15/2019 at 9:13 AM, Cirruslogic said: Thanks everyone. I wish there was an external battery pack that could be put in the car. This external battery pack would supply 5V power to the iRoad or other 5V devices. The battery pack can be charged when driving. If the battery pack drains, only the iRoad and other 5V devices are affected. The car computer and car alarm are not affected by the battery pack draining. Very worthwhile $300 investment Link to post Share on other sites More sharing options...
riot168 1st Gear October 16, 2019 Share October 16, 2019 actually, my workshop got option to auto-shutdown the whole thing thru' electrical wiring (ie, when u turn off the car, iroad is off). But I prefer option to have parkmode on as well, so he told me the only option then is to manually switched off the power button on the iroad whenever you are going away for holidays. If you drive daily or have 1 or 2 day rest in between, the car battery will not be flat. Link to post Share on other sites More sharing options...
terrydo Neutral Newbie October 30, 2019 Share October 30, 2019 good question bro Link to post Share on other sites More sharing options...
Koreancarsg Clutched January 3, 2020 Share January 3, 2020 Installed battery pack to X5 too, It shows also 11.8V once connected. Hope it would drain my car battery flat. Link to post Share on other sites More sharing options...
Ne0mesis Clutched August 14, 2021 Share August 14, 2021 Hi folks.. i have a x9. do you get the message “restart the system to protect the battery of the car” every time you start the engine? Link to post Share on other sites More sharing options...
Shibadog Turbocharged August 14, 2021 Share August 14, 2021 1 hour ago, Ne0mesis said: Hi folks.. i have a x9. do you get the message “restart the system to protect the battery of the car” every time you start the engine? yes this means the camera was shut down whilst it was parked to stop battery drain. Link to post Share on other sites More sharing options...
Atrecord Supersonic August 14, 2021 Share August 14, 2021 4 hours ago, Ne0mesis said: Hi folks.. i have a x9. do you get the message “restart the system to protect the battery of the car” every time you start the engine? Yup. Before that, when in parking mode very long and parked in high traffic area (so recording often activated, thus draining batt), when the iroad sensed low batt voltage already, it will actually say Shut down the system to protect the battery of the car Then when start engine it will say what you heard - restart... All iroad are like this. 1 Link to post Share on other sites More sharing options...
Ne0mesis Clutched August 21, 2021 Share August 21, 2021 thanks all.. i assume is something i can ignore so long is not like i leave the car unattended for days? btw, i have never hear the warning from the advance driver assistance system even though i enable it? is there something i missed out? Link to post Share on other sites More sharing options...
Hamburger Hypersonic June 30, 2022 Share June 30, 2022 need a quickie from iroad gurus. the X9 unit inmy car would not auto turn back on after i started my car. Hence i realize it was not recording anything during the drive. Used my hp and went into the setting and changed all to default mode and seems well again, until i parked overnight. Again it did not turn back on after i have to started the car and have to be manually turned on with the ON button. Any suggestion?? TIA!!!!!! Link to post Share on other sites More sharing options...
Samlimlp 2nd Gear July 11, 2022 Share July 11, 2022 I had the same issue with my ex iRoad. Had it replaced. Lesson learnt, bought one that has an on/off button, and also configure auto-off when car is turned off. Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear September 12, 2022 Share September 12, 2022 On 6/30/2022 at 5:24 PM, Hamburger said: need a quickie from iroad gurus. the X9 unit inmy car would not auto turn back on after i started my car. Hence i realize it was not recording anything during the drive. Used my hp and went into the setting and changed all to default mode and seems well again, until i parked overnight. Again it did not turn back on after i have to started the car and have to be manually turned on with the ON button. Any suggestion?? TIA!!!!!! I don’t hv such issues with mine. 3 years on parking mode tagged to battery running 24/7. maybe u can bring back agent to hv them take a look. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
My EV journey to the i4
Hdb flat renovation
Hdb flat renovation
Car camera recommendation
Request for dark mode
The Electric Vehicle Charging Problem
