Carbon82 Moderator September 4, 2019 Share September 4, 2019 Starting this thread to share and discuss about some nice concept cars, that may or may not have make it to production. This car left me a deep impression, so much so that I can still remember it after nearly a quarter century... Why buy four cars when you just need one, but with four different body styles? 1995 Mercedes-Benz VRC Concept Basic Module Wagon Cabriolet Coupe Pickup Basic Informations Vehicle: Mercedes-Benz Vario Research Car Introduced in: 1995 Where: Geneva Motor Show Goals: Variable vehicle concepts, ergonomics Powertrain: Front-wheel drive, continuously variable automatic transmission Technical highlights - Swap bodies: saloon, estate, convertible and pickup on one and the same chassis, exchanged within 15 minutes - Light and sturdy bodies made of carbon-fibre reinforced plastic (CFRP) - Active Body Control (ABC) [Production launch in the Mercedes-Benz CL (1999, C 215 series)] - Colour display [Production launch in the Mercedes-Benz S-Class (1998, W 220 series)] - Central rotary control for the electronic functions [Production launch in the Mercedes-Benz S-Class (2005, W 221 series)] - Navigation system [Production launch in the Mercedes-Benz S-Class (1995, W 140 series)] - Safety display coupled to traffic sign evaluating function and distance warning radar One car, four vehicles – variability is the emphasis of the design of the Vario Research Car (VRC) by Mercedes-Benz, which attracted great attention at its premiere at the 1995 Geneva Motor Show. For in just a few minutes, the VRC can be converted into a different car. Whatever trip you plan, you will not need more than one car thanks to the variability of the body of the Vario Research Car. On weekdays it’s a saloon. For longer journeys, the load capacity of an estate is available. In the summer the sun invites you to take an open-top ride in a convertible. And for heavy loads, there’s the pickup with its open cargo space. Mercedes-Benz solved the problem with a compact two-door car. It features a single-piece body consisting of roof, side walls and rear section; the body can be lifted off and exchanged for another variant. Doing it calls for a few simple operations and only about 15 minutes’ time. The Vario Research Car was combined with a vision: customers do not own the bodies themselves but drive up to a rental station. While they drink a cup of coffee, service technicians switch the body. A few minutes later, customers are back on the road again. How long they use a particular body variant is up to them, because the rental system is just as flexible as the car itself. One car for different activities Futurology provided the impetus for the Vario Research Car. The prediction is that people will have more leisure time which they will employ for different activities. For these activities, and for everyday use, they would like to choose a vehicle to fit their purpose. But having one’s own little fleet would not be economical. The Vario Research Car from Mercedes-Benz offers the solution. On top of that, the VRC illustrates clearly that research vehicles demand a dialogue with the public: Mercedes-Benz requests drivers to state their opinions about each new concept. In the case of the Vario Research Car, the response has been particularly extensive and unusually diversified. From this response, Mercedes-Benz obtained numerous valuable suggestions for future production models. This research car too features a number of forward-looking technical solutions. The body change should be easy to accomplish. Only the interplay of several components can make this possible. The service technicians place the roof structure on the chassis; electric motors pull it into its final position, where special locking mechanisms hold it at eight anchorage points. To release it, it suffices to actuate levers on the door pillars and the upper windshield frame. The rest is again done by the servomotors which undo the locks and slightly raise the body so that it can easily be lifted off. For the electric connections in the rear, which differ for each body, there is a central terminal which automatically recognises the type of body. If, for example, an estate body is mounted, the rear-screen wiper/washer will be supplied with current. In the saloon, the heated rear screen and trunk lights have to be connected to the electric system. In the convertible, the electric drive for the soft-top requires energy and has to be controlled. Bodywork made of new materials The bodies are light and sturdy – a result of the new materials tested by the engineers. They are made of the high-tech material CFRP – carbon-fibre reinforced plastic. Compared to aluminum, CFRP is 25 per cent lighter and, what is more, features high strength. The bodies weigh only 30 to 50 kilograms each and, despite their lightweight design, afford a high level of stability and crashworthiness. The Vario Research Car served to further test front-wheel drive in a Mercedes-Benz, which was combined with continuously variable automatic transmission as well as active suspension (Active Body Control, ABC) for improving handling safety and comfort. The cockpit contains a colour display which shows the driver all the required information. On the centre console a rotary actuator is installed with which the driver can selectively control the entire menu. It includes not only rev counter, trip computer and trip odometer, but also the route recommendations of the onboard navigation system. A special feature is the safety display in combination with a traffic sign evaluating system. If the driver keeps to the official speed limit, it shows a green circle. If he or she drives faster or does not keep a proper distance from the vehicle ahead, the colour and shape of the symbol change – the circle turns into a yellow ellipse or a red triangle depending on how much the driver exceeds the speed limit or falls below the safe distance. For this function, the onboard electronics are coupled with distance radar and traction control. The upper part of the centre console accommodates a second display where, among other things, information on the settings of the air conditioning and navigation system are shown. When the driver stops to refuel, he or she is also told whether the tyre pressure, the levels of engine oil, coolant and wash water, and the light system are okay. While on the go, drivers are prevented from choosing additional functions, so as not to distract their attention from traffic, while front passengers have unimpeded access to all secondary information. To tell the difference, the rotary control “senses” whether it is being touched by the left hand (front passenger) or right hand (driver). First-time use of drive-by-wire for steering and brakes The Vario Research Car was the first research car from Mercedes-Benz featuring drive-by-wire technology, in which the steering and the brakes, for example, are actuated electrically with no mechanical linkages existing to the steering hands and braking feet. But the testing of this technology was not the main purpose of the VRC – the variability of the body was the principal concern. With the Vario Research Car, Mercedes-Benz underpinned its forte, the holistic design of new vehicles – and its ability to put them on wheels in fully operational condition. ↡ Advertisement 9 Link to post Share on other sites More sharing options...
louisbosco 3rd Gear September 4, 2019 Share September 4, 2019 actually wouldn't mind a merc ute like that last photo.. with that generation's 55 AMG engine. it'd be sick! 1 Link to post Share on other sites More sharing options...
Davidklt 6th Gear September 4, 2019 Share September 4, 2019 Recall this vividly too. 1 Link to post Share on other sites More sharing options...
Carbon82 Moderator September 5, 2019 Author Share September 5, 2019 What catches my attention is the see through A-pillar, glass roof as well as the near full glass hatch, which really helps in improving overall visibility (I sat in the physical car before, and can feel it for myself). Sad to say all these features (including the practical 5 door design), did not make it to the production Volvo C30. 2001 Volvo SCC Volvo Safety Concept Car makes driving that much safer The main theme of the Volvo Safety Concept Car (SCC) is "superior vision". However, the car also employs a variety of technologies that enhance personal security and improve passive safety systems. SCC thus points the way to a new dimension in the research and development of car safety. The Volvo Safety Concept Car is a vision of the developments in safety that car buyers can enjoy in the future. It is also evidence that Volvo Cars and the Ford Motor Company are at the leading edge of the development of technology for safer driving. "With the quick pace of technological development, we are constantly gaining access to smaller yet more powerful computers, new sensors and so on. Volvo’s approach is to utilise the breakthroughs in an intelligent and sensible way. We combine advanced electronics with new materials and new mechanical design solutions to create customer benefits. One example of this is the Volvo SCC and its unique enhanced all-round visibility," says Hans Gustavsson, head of research and development at Volvo Cars. "More than 90 per cent of all important information to the driver comes in the form of visual input through the windows and windscreen of the car. If we improve the quality of this visual information, we will also improve the driver’s ability to make the right decisions in difficult situations, thereby avoiding collisions." Built for the eye That is why the forward-thinking Volvo Safety Concept Car is built for the eye. Not merely in terms of aesthetic appearances and lines pleasing to the eye, but rather because the car has been designed around the driver’s eyes to ensure better vision and visibility. When the driver gets into the seat, a sensor identifies the location of his or her eyes. The seat then automatically adjusts to suit the position of the eyes so that the driver obtains the best possible field of vision. Once this is done, the floor, pedals, steering wheel and centre console, including the gear lever, all move to ensure that all the controls are within convenient reach. The driver thus enjoys the best overview of what is happening both outside the car and on the instrument panel. Number one in safety The Volvo SCC is the result of close collaboration between Volvo Cars and its parent company, the Ford Motor Company. The car, which was designed at the Volvo Monitoring and Concept Center in California, demonstrates advances in several research and development projects in the fields of safety and security. It clearly highlights the cutting-edge skills and resources the company has at its disposal. Curved B-pillars The Volvo SCC has a number of additional functions that improve visibility. The driver can see through the supporting pillars of the windscreen – the A-pillars – as a result of a metal box construction combined with see-through Plexiglass. The B-pillars – the pillars between the front and rear doors – curve inwards following the contours of the seat frame to offer an unobstructed field of vision to the offset rear. A sensor located in the outer rear-view mirrors detects the approaching vehicle and alerts the driver to vehicles in the offset rear "blind spot". In addition, rearward-facing cameras integrated into the door mirrors can show the driver what is in the blind spot. The headlight beams adapt to the road and the speed – by directing the beam in the direction that the driver is turning at a crossroads or on a corner, for example. An infrared light enhancer boosts night-time vision beyond the reach of the headlights. A forward-facing camera monitors the position of the car on the road and alerts the driver if there is any tendency to veer off course. Increased crash safety and personal security In addition, the Volvo SCC features a number of exciting features in the areas of active driving safety, crash protection and personal security. Together with the B-pillars, the front seat frames form a safety cage that is at least as effective in roll-over accidents and side-impact collisions as conventional B-pillars. The car has two different types of four-point safety belt, the X4 CrissCross Belt and the V4 Centre Buckle belt. The X4 is based on a conventional three-point belt that is supplemented with an additional diagonal chest belt. The V4 Centre Buckle Belt is a new four-point safety harness that has a centrally positioned buckle and shoulder straps that form a "V" across the chest. The rear seat has two adjustable seat cushions whose height can be steplessly altered to give children the most comfortable and the safest seating position, irrespective of their height. The remote control unit becomes a communication centre The remote control unit has been developed into the Volvo Personal Communicator (VPC) and it has a number of new features. A fingerprint sensor personalises the remote control unit. The driver only has to grasp the door handle to unlock the door – and the car can be started without a key. The VPC transmits the driver’s personal setting parameters to the car, which automatically makes the necessary adjustments to the driver’s seat, steering wheel, pedals and so on. The system can even be pre-programmed with a number of destinations so that the navigation instrument is preset at the same time as the driver unlocks the door. A heartbeat sensor registers both human and animal heartbeats when the car is parked. The sensor is activated if anyone breaks into the car and hides inside it – or if a child or pet is left inside by mistake. If the driver is more than 100 metres from the car, the VPC can still transmit this information – via a cell phone. It is also possible to transfer information from a PC or hand-held computer. 6 Link to post Share on other sites More sharing options...
Carbon82 Moderator September 5, 2019 Author Share September 5, 2019 OK, I know someone is going to ask: "Why no Skoda, since you are one of it biggest fan?" 1935 Škoda 935 Dynamic Prototype ŠKODA 935: The Drop-shaped Pioneer It looked like a car from the future, with its aerodynamic bodywork and futuristic rear-mounted boxer engine. The ŠKODA 935 was a pioneer of the new era. In 1935, most cars were boxy, much closer in appearance to old horse-drawn coaches than to modern cars. They ploughed through the air rather than slicing through it. Although people already knew about aerodynamics and were using it on airplanes, only a few daring pioneers were trying to apply it to making cars. After many failed attempts, Chrysler and Tatra came up with first mass-produced streamlined cars in 1934. Their efforts, the Airflow and T77, are well-known, and regarded as game-changers in the industry. While the Airflow kept the traditional layout with a front-engine and rear-wheel drive, Tatra went much further and chose a more radical solution, with an air-cooled V8 engine in the back, an innovative backbone frame and swing axles. While Airflow failed commercially due to its unorthodox looks, the Tatra became a legend. Until recently, however, hardly anyone knew there was another Czech car with a similarly bold layout and futuristic design. It was called the ŠKODA 935 and it made its debut at the Prague car show in April 1935. Its most striking feature was, of course, the streamlined bodywork. Its shape was based on the aerodynamic principles laid out by Paul Jaray – a former designer of Zeppelin airships and assistant at the Prague Technical Univesity, who influenced the design of Tatra’s streamlined cars. There was more to the 935 than aerodynamics, though. Its low, sleek body wasn’t supported by a ladder frame, like most cars of its era. It had a backbone tube frame that was also used to house the 40 litre petrol tank. This design allowed the experimental ŠKODA to be much lower and more aerodynamic than most cars of the era. The innovations didn’t end there. The 935 was fitted with independent suspension of all four wheels, using swing axles. That was something you could find in Tatras as well, but ŠKODA’s solutions were cleverer. For example, the flat-four engine was placed not behind the rear axle, but in front of it. This allowed for excellent weight distribution, improving the car’s handling and stability. Together with the streamlined shape, this meant that the 935 was able to drive comfortably at 130 – 140 km/h, making it exceptionally fast for its era. It was a precursor to the kind of fast highway travel which only existed as an idea at the time. It was no cramped sportscar, either. At almost 5 metres in length, it offered a spacious interior for up to five adults plus 300 litres of luggage in the front compartment. There was also a horizontally mounted spare wheel that acted rather like a second bumper. Also remarkable is the fact that all it took to propel such a large car to highway speeds was a two-litre, flat-four engine with an output of just 55 hp (40.5 kW). Such efficiency is a testament to the vehicle’s aerodynamics. Unfortunately, we don’t know whether any more of these unique cars were ever manufactured. What we do know is that the prototype introduced at the Prague car show was sold to a private buyer in the summer of 1939. Later, it cruised around the Slovak roads in the hands of a local farmer, who finally offered it to the newly founded ŠKODA Museum in 1968. The car spent decades in storage before the time finally came to restore it. It took 6 years of painstaking, passionate labour to return it to its former glory. Thankfully, the car was remained almost completely in its original condition, with only the paint and dashboard differing from the 1935 original. A bit of original paint on the inner side of one pillar helped to match the proper shade of grey, while the dashboard and other parts of the car were restored using period photos. Today, the 935 is one of the most cherished exhibits of the ŠKODA Museum and a reminder that ŠKODA was already innovative and daring decades ago. 7 Link to post Share on other sites More sharing options...
Angcheek Hypersonic September 5, 2019 Share September 5, 2019 Can run on Highway ? later kana ticket for hogging 4 1 Link to post Share on other sites More sharing options...
BanCoe Hypersonic September 5, 2019 Share September 5, 2019 1 hour ago, Carbon82 said: OK, I know someone is going to ask: "Why no Skoda, since you are one of it biggest fan?" 1935 Škoda 935 Dynamic Prototype . what a beauty....... you should drive bring one in (make sure @Angcheek) not sitting inside , he belly strawbelly .... need AC , need stereo 😁 3 Link to post Share on other sites More sharing options...
Carbon82 Moderator September 6, 2019 Author Share September 6, 2019 Supposedly a model to counter the Porsche Panemera, but did not materialize till date. Lamborghini was torn between producing a 4 door sport sedan and a 4 door crossover, and no prize for guessing what is the final outcome. This one look better than panny, imo. 2008 Lamborghini Estoque As with majority of the Lamborghini models, the Estoque derives its name from the sport and tradition of bullfighting: An estoque is a type of sword traditionally used by matadors. The Estoque was introduced at the 2008 Paris Motor Show. The Estoque is the first front-engine vehicle to be introduced by Lamborghini since the LM002 utility vehicle. It was described as a "concept for a $230,000 four-door sedan". It had a 5.2 litre V10 engine shared with the Gallardo, although there had been speculation that this would be replaced by a V12, V8, or possibly even a hybrid or a turbo-diesel engine, as suggested by the then Lamborghini Brand Director, Manfred Fitzgerald. PERFORMANCE HIGH PERFORMANCE AND DRIVABILITY, IN A SINGLE CAR The Estoque concept car is a four-door super sports car that enhances the tradition of the brand with totally new versatility. Suited for daily driving, it is the perfect match for a multi-faceted lifestyle. Conceptually speaking, the Estoque expresses the idea of a Lamborghini which is both a top-class super sports car and a highly practical GT. DESIGN ALL THE LAMBORGHINI CREATIVITY The Estoque is a car with unique, unmistakable style. A long wheelbase, wide track and oversize wheels - combined with a low silhouette and a bold appearance - express the typical creativity of the Lamborghini style applied to a groundbreaking concept sedan. QUICK SPECIFICATIONS Engine: 5.2 L FSI V10 Transmission: 7-Speed Dual-clutch transmission Dimensions: 5,150 mm (L) x 1,990 mm (W) x 1,350 mm (H) Wheelbase: 3,010 mm Curb weight: 1,665 kg 6 Link to post Share on other sites More sharing options...
Carbon82 Moderator September 9, 2019 Author Share September 9, 2019 A Porsche that doesn't look like one, in anyway. In fact, it scream Lada / Tata / Dacia to me... So is the "C" in the C88 for China, or Cheap, you make the guess... 1995 Porsche C88 Concept The C88 was a prototype family car designed for the Chinese market in 1994 by Porsche in response to the Chinese government's invitation to a number of international automotive manufacturers for a new range of cars. It was completed in four months by Porsche engineers and was displayed to the public at the 1994 Beijing Auto Show. The prototype is now on display in the Porsche Museum in Stuttgart, Germany. The four-door compact saloon body was unlike any other Porsche, and did not feature the Porsche badge anywhere. It was designed with only one child seat--reflecting Chinese population control policy--and the prototype was presented by CEO Wendelin Wiedeking himself, who learned his speech in Mandarin. According to Porsche Museum director Dieter Landenberger, "The Chinese government said thank you very much and took the ideas for free, and if you look at Chinese cars now, you can see many details of our C88 in them." The C88 was intended to broaden the market for Porsche designs to India, where it was also unsuccessful. Quick Specifications Dimensions: 4,000mm (L) x 1,635mm(W) Weight: 980Kg Engine: 1.1L Inline 4 16V Horsepower: 67hp Torque: 105Nm Gearbox: 5 Speed manual 0 - 100Km/h: 16sec Top Speed: 165Km/h Fuel Consumption: 5.8L/100Km 5 Link to post Share on other sites More sharing options...
Carbon82 Moderator September 13, 2019 Author Share September 13, 2019 Am surprised that this one never make it to production... 2013 Toyota FT-86 Open Concept The FT-86 Open concept makes its World Debut at the 2013 Geneva Motor Show. Following the global success of the exhilarating, entirely driver-oriented GT86, the FT-86 Open concept has been created to gauge customer reaction to the possible launch of a convertible version of Toyota's remarkable, front 'boxer' engined, rear-wheel drive, compact 2+2 sports car. The FT-86 Open concept is designed to combine all the lively, accessible performance and highly engaging, readily exploitable dynamic abilities of the GT86 with the even greater levels of driving pleasure derived from open-topped motoring. 4,240 mm long, 1,775 mm wide, 1,270 mm high and with a wheelbase of 2,570 mm, the FT-86 Open concept features a multi-layered fabric roof construction with a glass rear screen. The concept vehicle retains the GT86's 2+2 seating format, the roof being stowed behind fixed rear seats with minimal impact on luggage capacity. 7 Link to post Share on other sites More sharing options...
Carbon82 Moderator September 30, 2019 Author Share September 30, 2019 Mercedes Vision Gran Tursimo What a beautiful Car! 5 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged September 30, 2019 Share September 30, 2019 (edited) On 9/13/2019 at 6:28 PM, Carbon82 said: Am surprised that this one never make it to production... 2013 Toyota FT-86 Open Concept The FT-86 Open concept makes its World Debut at the 2013 Geneva Motor Show. Following the global success of the exhilarating, entirely driver-oriented GT86, the FT-86 Open concept has been created to gauge customer reaction to the possible launch of a convertible version of Toyota's remarkable, front 'boxer' engined, rear-wheel drive, compact 2+2 sports car. The FT-86 Open concept is designed to combine all the lively, accessible performance and highly engaging, readily exploitable dynamic abilities of the GT86 with the even greater levels of driving pleasure derived from open-topped motoring. 4,240 mm long, 1,775 mm wide, 1,270 mm high and with a wheelbase of 2,570 mm, the FT-86 Open concept features a multi-layered fabric roof construction with a glass rear screen. The concept vehicle retains the GT86's 2+2 seating format, the roof being stowed behind fixed rear seats with minimal impact on luggage capacity. wasted that the interior of the concept was not followed thru Edited September 30, 2019 by Sdf4786k 1 Link to post Share on other sites More sharing options...
Carbon82 Moderator October 23, 2019 Author Share October 23, 2019 Nissan Ariya Concept Nissan unveiled the Ariya Concept, a crossover EV with twin electric motors, powerful acceleration, award-winning driver assistance technology and a look that signals a complete reinvention of the brand's design. The new Nissan Ariya Concept, introduced at the 2019 Tokyo Motor Show, signals the dawn of a new era for Nissan as the company embarks to redefine its brand philosophy for the next evolutionary phase of the automobile. The Nissan Ariya Concept features a spacious, premium cabin with high-tech features and a body that conveys the pure, clean nature of electric cars. It embodies the Nissan Intelligent Mobility vision of personal transportation - one where electrification and vehicle intelligence will offer seamless and adaptive travel experiences free of accidents or harmful emissions. The Nissan Ariya Concept expands on design elements first hinted at by the Nissan IMx concept at the 2017 Tokyo Motor Show. They include the bold electrified V-motion signature "shield" and striking rear light blade, short overhangs, and an interior that feels more like a lounge than a conventional vehicle. Although it's a concept vehicle, the crossover EV's bold styling and unconventional interior and exterior elements could make it into production in the near future. "The Ariya Concept represents a strong collaboration between design and engineering," said Yasuhiro Yamauchi, representative executive officer, Nissan Motor Co., Ltd. "It is the next stage of Nissan's future design language as we embark on a new era for the company - the next stage in our evolution." Nissan Intelligent Mobility - a new design language The Ariya Concept represents an entirely new design direction for Nissan. "A new vehicle architecture means fresh opportunities to redefine how vehicles interact with society, how an EV paired with advanced driving capabilities can offer a new perspective," said Alfonso Albaisa, Nissan's senior vice president of global design. "With this vehicle and the IMk concept, we wanted to ensure that the soul of every Nissan car possess a distinctive Japanese DNA conveyed in a simple-yet-powerfully modern way, something we call 'Timeless Japanese Futurism.'" Characterized by the concepts "sleek," "seamless" and "sexy," the Nissan Ariya Concept features examples of this new design language throughout the exterior, including wide front fenders, super-thin LED headlights, as well as the front shield (typically a grille on a gasoline-powered vehicle) which is emblazoned with a bespoke, illuminated Nissan emblem. The shield incorporates a subtle geometric pattern that reveals itself when the electrified V-motion signature is illuminated. "We replaced the conventional grille with what we call a 'shield' - an expressive piece with innovative 3-D texture within that goes beyond cosmetics, but also as a way to highlight the technology lurking within the vehicle," said Albaisa. "In this case, it's a radar sensor and other technologies that help the Ariya Concept read the road and visualize things the driver can't see." Highlighting the vehicle's profile are five-blade, 21-inch aluminum wheels with custom tires. A low, sleek roofline allows the vehicle to slice through the air. The styling of the Ariya Concept's rear is also a departure from traditional SUVs, with a steeply raked C-pillar that blends seamlessly into a muscular rear deck. A one-piece light blade with blacked-out lenses runs across the width of the body. Rear fender flares and a high-mounted rear wing offer not-so-subtle suggestions of the vehicle's power. "The exterior strikes a balance between dynamic beauty and 'tech sharpness,' with proportions that show what's possible with Nissan's 100% electric vehicle platform," Albaisa said. "The surprisingly short overhangs, large cabin, large wheels and tailored two-tone paint scheme provide an elegant appearance that balances sport and luxury." The Nissan Ariya Concept's Suisei Blue paint scheme creates a dual appearance, depending on the distance viewed. From afar, the deep blue color takes on a matte-like finish. Upon closer inspection, large embedded glass flakes produce billions of light refractions, reminiscent of a comet crossing the night sky. Accenting the Ariya Concept's roofline and wheels is a new signature color for future Nissan EVs: copper, the color of the sun as it breaks through the night to start a new day. It symbolizes the dawn of a new automotive era while also giving a nod to traditional Japanese artisans who formed copper into works of functional art. While the Nissan Ariya Concept's exterior mainly expresses the ideas of "sleek" and "sexy," the interior reflects a notion of seamlessness - represented by the integration of technology with daily life and the precise nature of Japanese craftsmanship. "With a flat floor - made possible by the battery pack layout and absence of an internal combustion engine- the Ariya Concept welcomes occupants as they step in the cabin with a feeling of expansion and openness," said Albaisa. "Panels blend naturally into each other and flow seamlessly from the front, sides and rear, giving a panoramic impression from any seat position. The minimalist dashboard is uncluttered by the buttons and switches found in conventional vehicles. When the Ariya Concept is energized, seamlessly integrated haptic touch controls along the instrument panel come to life with a glow. When the car is not in use, they disappear into the surface. The only physical controls are the start button, a single knob to operate the 12.3-inch display monitor, and the climate controls, which are artfully ingrained into the instrument panel's genuine-wood lower section. The instrument panel transitions flawlessly into the doors and interior elements, to be out of sight when not in use. The Nissan Ariya Concept's supportive, comfortable seats feature a super-thin frame, providing even more free interior space and enhanced visibility. The front and rear seats are positioned to ensure that everyone has a great view of the surroundings and offer a sensation reminiscent of floating on a magic carpet. To make long drives more comfortable, the seat back and seat bottoms feature perforated leather upholstery, with material concentration where the occupant's lower back and hip touch. A brilliant copper fabric under the perforation adds beauty and depth. Throughout the cabin, interior materials were carefully selected to give an impression of solidness, technology and utility. Fine black synthetic leather covers the instrument panel and inner door panels. A different grade of synthetic leather with a textured grain lines the A-pillar and ceiling. This provides a subtle yet effective visual contrast. Satin copper-colored aluminum accents, incorporated into the instrument panel, seats and steering wheel, exude a sense of unity with the exterior color. An icon of Nissan Intelligent Mobility Nissan designed the Ariya Concept to fully embody the three pillars of Nissan Intelligent Mobility - Intelligent Driving, Intelligent Power and Intelligent Integration. Combining advanced electric-vehicle technology with a new level of seamless human-machine interface connectivity, it offers an entirely new driving experience. The Nissan Ariya Concept features the latest version of Nissan's award-winning driver assistance system, ProPILOT 2.0, for a more confident and comfortable drive. The system combines navigated highway driving with hands-off single-lane driving capabilities. By engaging the vehicle's navigation system to help maneuver the car on a predefined route on designated roads, the system can assist the driver with passing, lane diversions and lane exiting on multi-lane highways. ProPILOT 2.0 also enables hands-off driving while cruising in a given lane.1,2 When approaching a road diversion or preparing to pass another vehicle, the system judges the appropriate timing of branching off or passing based on information from the navigation system and 360-degree sensing. The driver receives intuitive audio and visual guidance and is prompted to put both hands on the steering wheel and confirm the start of these operations via a switch. When driving with ProPILOT 2.0 engaged, the interior lighting changes colors to signal that hands-off driving is enabled, while creating a relaxing atmosphere. Built with a high-performance, 100% electric drive system, the Nissan Ariya Concept delivers instant torque to the wheels from a dual front/rear motor drive configuration. This layout delivers balanced, predictable power to all four wheels, equal or better than many premium sports cars. The Ariya Concept promises excellent cornering performance and traction on slippery surfaces such as snow and loose dirt, without drivers needing to change their driving style, steering input or even pedal position. It accomplishes this thanks to the high-power, twin-motor, all-wheel control system. Employing knowledge gained from years of vehicle control development - including the Nissan GT-R's ATTESA E-TS torque split system and the Nissan Patrol's intelligent 4X4 system - engineers created this new system to manage the EV's power delivery and brakes automatically, ensuring smooth passage with minimal tire slippage. Drivers can maintain their driving posture and comfort, letting the system do all the work. Seamless integration Intuitive technology allows the Nissan Ariya Concept to fit seamlessly into the driver's daily life, on-board and off-board, providing the freedom and enjoyment of mobility anytime and anywhere. Traveling assistance isn't limited to the vehicle. Among the human-machine interface features is Door to Door Navigation, which allows anyone to set a destination on their smartphone, transfer it to the Ariya Concept and have the vehicle's navigation system continue offering directions. If the final destination is reached by foot, the system will transfer the remaining route back to the driver's smartphone. When approaching the Ariya Concept, the driver is greeted with a welcome light as the vehicle unlocks automatically, eliminating the need to fumble with a key fob. Even before getting inside, settings such as the driver's seat position and climate controls are adjusted to the driver's personal preferences, which the driver can save to a smartphone as a unique profile. The car can sync with the driver's schedule to anticipate departure times and prepare the vehicle to be climate-controlled and ready to hit the road - maximizing driving range by using grid power to heat or cool the car. Once the driver is inside, the Virtual Personal Assistant can help look up information and locate parking, so that the driver can keep their eyes on the road. While traveling, the Nissan Ariya Concept's Smart Route Planner automatically identifies and plots charging stops along the way, ensuring that the driver arrives at the desired destination, whether near or far. Excellent power storage management allows for long-distance driving, without lengthy charging times interrupting travel plans. When it's time to charge, the Ariya Concept uses CHAdeMO quick charging to energize the battery swiftly and conveniently. The charging port unlocks upon the driver's approach and uses distinct colors to show the vehicle's charge status at a glance. If the plan includes picking up friends along the way, an integrated video chat feature can help confirm details before setting off. It can also link with their smartphones and the Ariya Concept's center information display to show their exact location. Upon arrival at their destination, drivers can use a smartphone or dedicated device to park the car automatically from a nearby location, thanks to ProPILOT Remote Park. This can be of help to passengers who need additional space or assistance to exit the car. Firmware Over The Air (FOTA) technology provides constant, hassle-free updates for the navigation system, graphic user interface and driving characteristics to ensure the car is running effectively and has the latest versions and features, keeping the driver's experience fresh and enjoyable. When parked at the office or home, the Ariya Concept supports Nissan Energy technology. The technology makes it possible to connect with energy systems to charge the EV battery, power homes and businesses, and even selling energy back to the power grid. Nissan Energy helps drivers fully harness the Ariya Concept's capabilities by expanding its use from just driving to include every aspect of life. 5 Link to post Share on other sites More sharing options...
Carbon82 Moderator November 6, 2019 Author Share November 6, 2019 Calling @Davidtch This V6 x 2.67 your cup of tea? BMW 7er Goldfisch V16 (E32) Meaning “Goldfish” in German, the BMW 750iL Goldfisch was an absurd and amazing one-off by BMW that seemed to have been made purely to see if it could be done. What BMW did essentially was to stuff a massive 6.6 liter V16 engine under the hood of an E32-generation 7 Series, which could barely accommodate a V12. In fact, the V16 was such a tight fit that BMW had to modify the 7 Series quite a bit to get the monster engine inside. For a start, the radiator had to be relocated to the rear boot of the car. But rather than using a standard radiator, BMW opted for two smaller ones. To send air to them, fiberglass ducts were made and worked into the rear quarter panels, where ducts were cut. To extract hot air from the trunk, a custom-designed grille was made to fit into the rear of the car, requiring modifications to the entire rear end, including the taillights. Power was ample for its time, with the massive V16 making 408 hp and 625 Nm of torque. That was significantly more powerful than the 300 hp V12-powered 7 Series of the time and would actually still be pretty powerful today. Though, the only 16-cylinder car on the market today makes over 1,500 hp, so we’ve progressed since then. The best part about all of this? It had a six-speed manual transmission. Not only was it a V16-powered 7 Series but it had a manual transmission. How incredible is that? It was a fascinating car and one that looked awesome but, of course, never saw production. It’s not hard to see why, either. It was incredibly expensive, completely unnecessary, would have sold horribly and was difficult to build. It was wise to not move forward with the project from a business standpoint. Still, the BMW 750iL Goldfisch is an incredible car and one with a great story. We wish BMW would have actually made it because it would have been one of the very coolest cars ever made. Imagine actually buying a V16-powered 7 Series with a six-speed manual and rear air ducts? 6 Link to post Share on other sites More sharing options...
inlinesix Supersonic November 6, 2019 Share November 6, 2019 IL6 x 2 FTW Link to post Share on other sites More sharing options...
Carbon82 Moderator November 27, 2019 Author Share November 27, 2019 Volkswagen Type 2 Bus Electrified Concept Showcasing the possibilities of the e-Golf powertrain to motivate classic VW models, Volkswagen of America commissioned west coast electric vehicle conversion specialist EV West to construct an electrified 1972 Volkswagen Type 2 Bus. "Their passion for classic-car culture and commitment to renewable energy made EV West the ideal choice for this project," said Mathew Renna, VP G4, Volkswagen North American Region. "We thought, who better to see if the e-Golf powertrain would be the perfect fit for our older vehicles. It's great to see that the spirit of hot rodding is going to live on into the electric age." The professionally harvested stock powertrain and 35.8 kWh battery system from the donor 2017 e-Golf gives the e-Bus an approximate range of 125 miles. The powertrain will reside in the rear compartment of the e-Bus, which was previously occupied by the stock air-cooled 60-horsepower four-cylinder engine. The independent rear suspension of the Type 2 Bay Window makes a perfect mate to the transverse driveline which is contained in a single unit that houses the 100kW synchronous AC permanent magnet electric motor, one-speed transmission and charging system. Most of the other exterior and interior features of the e-Bus will remain, mostly unchanged. The battery units are contained inside custom engineered, reinforced and fireproof enclosures located under the front seats and in the former location of the fuel tank. The stock long-throw shifter remains but now actuates park, reverse, neutral, drive, and the regenerative braking modes (PRNDB) that are all familiar aspects of the e-Golf. To further maintain its authentic feel, the e-Bus will be fitted with a classically styled multi-function digital EV gauge in the dashboard. This gauge allows the operator to cycle through multiple views and monitor vehicle outputs. "We are very excited to be a part of this project," said Michael Bream, Founder and CEO of EV West. "Merging a historic model from an iconic brand with the technology of today, is just one of many ways that we can step closer to a more sustainable future while continuing to enjoy our rich automotive heritage." 6 Link to post Share on other sites More sharing options...
Davidklt 6th Gear February 21, 2020 Share February 21, 2020 On 9/4/2019 at 1:08 PM, Carbon82 said: Starting this thread to share and discuss about some nice concept cars, that may or may not have make it to production. This car left me a deep impression, so much so that I can still remember it after nearly a quarter century... Why buy four cars when you just need one, but with four different body styles? 1995 Mercedes-Benz VRC Concept Basic Module Wagon Cabriolet Coupe Pickup Basic Informations Vehicle: Mercedes-Benz Vario Research Car Introduced in: 1995 Where: Geneva Motor Show Goals: Variable vehicle concepts, ergonomics Powertrain: Front-wheel drive, continuously variable automatic transmission Technical highlights - Swap bodies: saloon, estate, convertible and pickup on one and the same chassis, exchanged within 15 minutes - Light and sturdy bodies made of carbon-fibre reinforced plastic (CFRP) - Active Body Control (ABC) [Production launch in the Mercedes-Benz CL (1999, C 215 series)] - Colour display [Production launch in the Mercedes-Benz S-Class (1998, W 220 series)] - Central rotary control for the electronic functions [Production launch in the Mercedes-Benz S-Class (2005, W 221 series)] - Navigation system [Production launch in the Mercedes-Benz S-Class (1995, W 140 series)] - Safety display coupled to traffic sign evaluating function and distance warning radar One car, four vehicles – variability is the emphasis of the design of the Vario Research Car (VRC) by Mercedes-Benz, which attracted great attention at its premiere at the 1995 Geneva Motor Show. For in just a few minutes, the VRC can be converted into a different car. Whatever trip you plan, you will not need more than one car thanks to the variability of the body of the Vario Research Car. On weekdays it’s a saloon. For longer journeys, the load capacity of an estate is available. In the summer the sun invites you to take an open-top ride in a convertible. And for heavy loads, there’s the pickup with its open cargo space. Mercedes-Benz solved the problem with a compact two-door car. It features a single-piece body consisting of roof, side walls and rear section; the body can be lifted off and exchanged for another variant. Doing it calls for a few simple operations and only about 15 minutes’ time. The Vario Research Car was combined with a vision: customers do not own the bodies themselves but drive up to a rental station. While they drink a cup of coffee, service technicians switch the body. A few minutes later, customers are back on the road again. How long they use a particular body variant is up to them, because the rental system is just as flexible as the car itself. One car for different activities Futurology provided the impetus for the Vario Research Car. The prediction is that people will have more leisure time which they will employ for different activities. For these activities, and for everyday use, they would like to choose a vehicle to fit their purpose. But having one’s own little fleet would not be economical. The Vario Research Car from Mercedes-Benz offers the solution. On top of that, the VRC illustrates clearly that research vehicles demand a dialogue with the public: Mercedes-Benz requests drivers to state their opinions about each new concept. In the case of the Vario Research Car, the response has been particularly extensive and unusually diversified. From this response, Mercedes-Benz obtained numerous valuable suggestions for future production models. This research car too features a number of forward-looking technical solutions. The body change should be easy to accomplish. Only the interplay of several components can make this possible. The service technicians place the roof structure on the chassis; electric motors pull it into its final position, where special locking mechanisms hold it at eight anchorage points. To release it, it suffices to actuate levers on the door pillars and the upper windshield frame. The rest is again done by the servomotors which undo the locks and slightly raise the body so that it can easily be lifted off. For the electric connections in the rear, which differ for each body, there is a central terminal which automatically recognises the type of body. If, for example, an estate body is mounted, the rear-screen wiper/washer will be supplied with current. In the saloon, the heated rear screen and trunk lights have to be connected to the electric system. In the convertible, the electric drive for the soft-top requires energy and has to be controlled. Bodywork made of new materials The bodies are light and sturdy – a result of the new materials tested by the engineers. They are made of the high-tech material CFRP – carbon-fibre reinforced plastic. Compared to aluminum, CFRP is 25 per cent lighter and, what is more, features high strength. The bodies weigh only 30 to 50 kilograms each and, despite their lightweight design, afford a high level of stability and crashworthiness. The Vario Research Car served to further test front-wheel drive in a Mercedes-Benz, which was combined with continuously variable automatic transmission as well as active suspension (Active Body Control, ABC) for improving handling safety and comfort. The cockpit contains a colour display which shows the driver all the required information. On the centre console a rotary actuator is installed with which the driver can selectively control the entire menu. It includes not only rev counter, trip computer and trip odometer, but also the route recommendations of the onboard navigation system. A special feature is the safety display in combination with a traffic sign evaluating system. If the driver keeps to the official speed limit, it shows a green circle. If he or she drives faster or does not keep a proper distance from the vehicle ahead, the colour and shape of the symbol change – the circle turns into a yellow ellipse or a red triangle depending on how much the driver exceeds the speed limit or falls below the safe distance. For this function, the onboard electronics are coupled with distance radar and traction control. The upper part of the centre console accommodates a second display where, among other things, information on the settings of the air conditioning and navigation system are shown. When the driver stops to refuel, he or she is also told whether the tyre pressure, the levels of engine oil, coolant and wash water, and the light system are okay. While on the go, drivers are prevented from choosing additional functions, so as not to distract their attention from traffic, while front passengers have unimpeded access to all secondary information. To tell the difference, the rotary control “senses” whether it is being touched by the left hand (front passenger) or right hand (driver). First-time use of drive-by-wire for steering and brakes The Vario Research Car was the first research car from Mercedes-Benz featuring drive-by-wire technology, in which the steering and the brakes, for example, are actuated electrically with no mechanical linkages existing to the steering hands and braking feet. But the testing of this technology was not the main purpose of the VRC – the variability of the body was the principal concern. With the Vario Research Car, Mercedes-Benz underpinned its forte, the holistic design of new vehicles – and its ability to put them on wheels in fully operational condition. From a 1995 magazine. 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged February 28, 2020 Share February 28, 2020 Daewoo in 1995 did quite well and this was a domestic only version sold in korea ↡ Advertisement Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Cars at Expo - Apr 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
Kia EV9 Concept
Kia EV9 Concept
New car discount/price/promo
