Blueblueman 4th Gear November 19, 2015 Share November 19, 2015 may be can you elaborate what is your like ? cost / power lost / drag / ride comfort / FC / look ? trust me you cant have all above. 16 better than 17 overall(above) except the look if you little better comfort and ride on 16 , do consider tyre size 195/50/16 Towards look and handling as will visit GH occasionally Looking at 16, should be all rounded. 17, is it true width when wider at 215 will be tougher to drive? I have been on 16 but never 17 ↡ Advertisement Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 20, 2015 Share November 20, 2015 Towards look and handling as will visit GH occasionally Looking at 16, should be all rounded. 17, is it true width when wider at 215 will be tougher to drive? I have been on 16 but never 17 yes it is true that wider the tire need more power to roll . don't always think wider the better (is actually wider is bad for wet especially on cheapo tire) if you do go up north I will say 16 better than 17 for 16 do consider 195/50/16 if not after high performance type 205/45/16 has wider range of HP tyre do go for premium tire when one is looking at all rounder and reliability 4 tires is only contacts between you and road Link to post Share on other sites More sharing options...
Blueblueman 4th Gear November 20, 2015 Share November 20, 2015 yes it is true that wider the tire need more power to roll . don't always think wider the better (is actually wider is bad for wet especially on cheapo tire) if you do go up north I will say 16 better than 17 for 16 do consider 195/50/16 if not after high performance type 205/45/16 has wider range of HP tyre do go for premium tire when one is looking at all rounder and reliability 4 tires is only contacts between you and road Thanks may go for pss Link to post Share on other sites More sharing options...
Jtyres 2nd Gear November 20, 2015 Share November 20, 2015 Do note that PSS is not manufactured in 16" Thanks may go for pss Link to post Share on other sites More sharing options...
Blueblueman 4th Gear November 20, 2015 Share November 20, 2015 Do note that PSS is not manufactured in 16" Bro, what good Tyres available in 16 for vios? They are saying 195/50/16? Or 205/45/16?? Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 21, 2015 Share November 21, 2015 for 195/50/16 if you wanna go for sporty performance like yokohama A drive R1 or Dunlop sp max something but it comes with the noise FOC Link to post Share on other sites More sharing options...
Zxcvb Turbocharged November 21, 2015 Share November 21, 2015 For the NCP93 Vios (2007-2013), closest 16" tyre profile should be 205/50/16. But a 205/45/16 also can if you don't mind the tyres circumference being smaller. Link to post Share on other sites More sharing options...
Blueblueman 4th Gear November 21, 2015 Share November 21, 2015 For the NCP93 Vios (2007-2013), closest 16" tyre profile should be 205/50/16. But a 205/45/16 also can if you don't mind the tyres circumference being smaller. Very tempted to go for 17, but more or less settle for 16. Thanks for the profile, thanks Link to post Share on other sites More sharing options...
Baal Supersonic December 25, 2015 Share December 25, 2015 With many oem cars coming with min 16 inch, does it appear that 15inch ..both rim n tyre choice may soon b uncommon? With limited choices of tyre brand? 1 Link to post Share on other sites More sharing options...
yellowshaun 4th Gear May 15, 2021 Share May 15, 2021 (edited) Sorry to bump old thread. But better than creating a new one eh? I realised the Vios E is 15" wheels and the Vios G is 16" wheels. So their handling characteristics would be different hor? If I'm more keen on maximising fuel efficiency, advisable to downgrade to 14" wheels ma? But that would make the car's handling even worse right? Also, what's the estimated selling price of the stock 15" wheels? (I buy a new set and sell the stock ones off)? Edited May 15, 2021 by yellowshaun Link to post Share on other sites More sharing options...
Kopites Supersonic May 15, 2021 Share May 15, 2021 1 hour ago, yellowshaun said: Sorry to bump old thread. But better than creating a new one eh? I realised the Vios E is 15" wheels and the Vios G is 16" wheels. So their handling characteristics would be different hor? If I'm more keen on maximising fuel efficiency, advisable to downgrade to 14" wheels ma? But that would make the car's handling even worse right? Also, what's the estimated selling price of the stock 15" wheels? (I buy a new set and sell the stock ones off)? My previous vios was on 14 from stock. Handling wide can consider to add a front struts bar to give a more stable drive. As for fuel efficiency the correct tire pressure and regular maintenance should help. I reckon 14 to 15 is more for aesthetic rather than driving "feel". 2006 bios i was able to achieve around 15/16 per ltr. Higher in NSHW. 1 Link to post Share on other sites More sharing options...
yellowshaun 4th Gear May 15, 2021 Share May 15, 2021 2 hours ago, Kopites said: My previous vios was on 14 from stock. Handling wide can consider to add a front struts bar to give a more stable drive. As for fuel efficiency the correct tire pressure and regular maintenance should help. I reckon 14 to 15 is more for aesthetic rather than driving "feel". 2006 bios i was able to achieve around 15/16 per ltr. Higher in NSHW. Oh yours was a 93? My FC only 14km/l. The vios chat group says bo bian one cause the 151 is more heavy. =X Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 15, 2021 Share May 15, 2021 (edited) Have to calculate cost of buying new 14 rims and tyres with the savings from going smaller. You have to do a lot of miles to make the marginal savings in fuel to make the change worth while. This is a Vios so not much loss in handling but the ride quality will improve a bit. Edited May 15, 2021 by Jamesc Link to post Share on other sites More sharing options...
Kopites Supersonic May 15, 2021 Share May 15, 2021 1 hour ago, yellowshaun said: Oh yours was a 93? My FC only 14km/l. The vios chat group says bo bian one cause the 151 is more heavy. =X What is 93? Link to post Share on other sites More sharing options...
Ceecookie 5th Gear May 15, 2021 Share May 15, 2021 2 hours ago, yellowshaun said: Oh yours was a 93? My FC only 14km/l. The vios chat group says bo bian one cause the 151 is more heavy. =X Actually 14 is already good for the vios since it's not using hybrid engine. Only diesel or hybrid engine can venture to 20 and above region Link to post Share on other sites More sharing options...
Hamburger Hypersonic May 15, 2021 Share May 15, 2021 Sell car take public transport. Sorry if the truth hurts. Whatever measures one take will never gain back the ROI. Fuel saved is too insignificant. 2 Link to post Share on other sites More sharing options...
yellowshaun 4th Gear May 15, 2021 Share May 15, 2021 2 hours ago, Kopites said: What is 93? It's the cute face Vios! 4 hours ago, Jamesc said: Have to calculate cost of buying new 14 rims and tyres with the savings from going smaller. You have to do a lot of miles to make the marginal savings in fuel to make the change worth while. This is a Vios so not much loss in handling but the ride quality will improve a bit. Ah thanks for this. So conversely, if change to 16" inch wont suffer much in terms of FC? From 14 km/to 13? 1 hour ago, Hamburger said: Sell car take public transport. Sorry if the truth hurts. Whatever measures one take will never gain back the ROI. Fuel saved is too insignificant. Can get back one as long as the COE keep increasing. My car value now (on the mycarforum valuation) is more than what I bought it for =DDD Link to post Share on other sites More sharing options...
Kopites Supersonic May 15, 2021 Share May 15, 2021 1 hour ago, yellowshaun said: It's the cute face Vios! Ah thanks for this. So conversely, if change to 16" inch wont suffer much in terms of FC? From 14 km/to 13? Can get back one as long as the COE keep increasing. My car value now (on the mycarforum valuation) is more than what I bought it for =DDD Mine was the 1st generation facelift. Not this generation. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
