Vtim 3rd Gear February 8, 2005 Share February 8, 2005 yah that's true, cause there's no way you can clutch in/out ↡ Advertisement Link to post Share on other sites More sharing options...
Presea 2nd Gear February 12, 2005 Share February 12, 2005 Hi bro, For our car, my mech charges $250 including labour. If you're interested in a recon-Jap import Gearbox, that's $250 as well (some other places quoted $400+). cheers Link to post Share on other sites More sharing options...
Yansen Neutral Newbie February 28, 2005 Share February 28, 2005 hey din see this till now. anyway i changed my clutch last yr in september liao. thx anyway. Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 1, 2005 Share March 1, 2005 hi yansen, how much u changed ur clutch?? Link to post Share on other sites More sharing options...
Yansen Neutral Newbie March 1, 2005 Share March 1, 2005 parts i bought myself at 120 in sg. then went to my jb mech to do for rm120 labour. Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 2, 2005 Share March 2, 2005 wow..that's one of cheapest i've heard Link to post Share on other sites More sharing options...
Yansen Neutral Newbie March 2, 2005 Share March 2, 2005 jb mah. labour sure cheap. Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 2, 2005 Share March 2, 2005 (edited) any address yansen?? Edited March 2, 2005 by Xtraun Link to post Share on other sites More sharing options...
Phoenix Neutral Newbie June 22, 2007 Share June 22, 2007 I notice ram car until rpm 3K at each gear change but car still slowly picking up. Pick up slower than container truck until kena high beam so went to workshop just now and after testing my clutch and engage fwd and back says clutch wear out and quoted $460 for parts, oil and labour done in 1 day. Saw the price quoted and though I had a deal so can any one provide contacts or lobangs. Prefer west area if possible. BTW, I'm driving a 91 nissan presea Link to post Share on other sites More sharing options...
Decibel Neutral Newbie June 22, 2007 Share June 22, 2007 Far too expensive. $300 would be a reasonable benchmark, perhaps some bros can recommend you mechs in the West. Link to post Share on other sites More sharing options...
macrosszero Turbocharged June 22, 2007 Share June 22, 2007 It sounds about right for a clutch replacement. The gearbox oil has to be drained, a new clutch installed, and the flywheel has to be machined to engage with the new clutch friction plate nicely. Then the gearbox needs to be filled with new gear oil. Link to post Share on other sites More sharing options...
Decibel Neutral Newbie June 22, 2007 Share June 22, 2007 (edited) Should include clutch disc + pressure plate + release bearing. $300-$350 should cover this including labour + oil (excluding flywheel grinding). Edited June 22, 2007 by Decibel Link to post Share on other sites More sharing options...
macrosszero Turbocharged June 22, 2007 Share June 22, 2007 You're right, I should have specified it was a clutch kit. Price would vary quite a bit buying originals or OEM. You can save some money locating a Nissan stockist, buying the required parts, and bringing it to a mechanic of your choice for labour cost only. Link to post Share on other sites More sharing options...
Phoenix Neutral Newbie June 22, 2007 Share June 22, 2007 Is flywheel grinding required? I think the quote should include the whole works since my car was not open out or anything for checks so I assume they would provide a quote to cover everything. The next concern is whether workshop will start saying actually this and that also related after repair commence and then more cost incurred as I just drove to the nearest workshop in my area (Pioneer Rd) to save the trouble of enduring driving to eunos which is what I see one of the bro here recommended. Link to post Share on other sites More sharing options...
macrosszero Turbocharged June 22, 2007 Share June 22, 2007 It is of course possible that other items could be damaged,such as the gear selector prong (or something else). With each new clutch kit, it is necessary to "refresh" the flywheel, as it would have been worn in to fit the old clutch. Link to post Share on other sites More sharing options...
Decibel Neutral Newbie June 22, 2007 Share June 22, 2007 Hey bro, you can give my mech a call for a quote, hes very experienced and charges reasonably too. I service and do all major work with him, mine is a jap COE car too. Workshop is in AMK though but you can just call for a price comparison. 6451-4933 (Jefrrey) Link to post Share on other sites More sharing options...
Decibel Neutral Newbie June 22, 2007 Share June 22, 2007 I don't believe grinding the flywheel is an absolute necessity bro, would be good to do I guess if he plans to drive the car for much longer. It isn't really cheap Link to post Share on other sites More sharing options...
macrosszero Turbocharged June 22, 2007 Share June 22, 2007 It isn't an absolute necessity, but it is recommended. The old clutch friction plate wears grooves into the flywheel. Clutch breaks. If you don't not re-face the flywheel, it will retain its old grooves and will begin cutting into the friction material of the new clutch. Given that the new clutch friction plate is technically new and flat, the flywheel should be re-faced to allow both items to wear in gradually and naturally. But you're right, with a COE car, it may not be worth the trouble since it is likely to run out of COE in another 4 years. You have the option to do it right and drive with no fear of a clutch failure, or hope that it all hangs together till you send it to the scrapyard. ↡ Advertisement Link to post Share on other sites More sharing options...
Clutch
Clutch
Looking for Job in automotive sector, need advise
In need of vehicle history software
Syria Quake
Syria Quake
