Regboyboy Neutral Newbie January 11, 2004 Share January 11, 2004 Inconsistent throttling on my S80. Only happens when car is on D and stationery, the car might stall sometimes. What is the problem?? I've tried trouble shooting and i've come to these few conclusions 1) The throttling returns to normal when i shift it to N or P. 2) The throttling returns to normal when i switch off the air-con. Need advice. ↡ Advertisement Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie January 11, 2004 Share January 11, 2004 "Inconsistent throttling" Hi! there, boyboy, Check your sparkplugs first. Are the plug cables providing a clean spark? Clean your AFM, check the ignition relays, fuel pump & relay, how old is the fuel regulator? When's the last time you clean the airfilter? Rgds Paul Yong Link to post Share on other sites More sharing options...
Regboyboy Neutral Newbie January 11, 2004 Author Share January 11, 2004 Ok i'll check those out. The air filter was cleaned last week. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 12, 2004 Share January 12, 2004 (edited) Cleaned your throttle body on Friday night? Edited January 12, 2004 by Mikeckchong Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 12, 2004 Share January 12, 2004 His throttle body quite hard to access... Link to post Share on other sites More sharing options...
King 1st Gear January 12, 2004 Share January 12, 2004 Agree with you....on this,other than IPSum,this is the other car throttle body then hard to access.... Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 12, 2004 Share January 12, 2004 Maybe thats the idea ... they dun want you to access the throttle body and mess around with it Link to post Share on other sites More sharing options...
King 1st Gear January 12, 2004 Share January 12, 2004 so free.? so when go Jb? Link to post Share on other sites More sharing options...
Hitman Neutral Newbie January 12, 2004 Share January 12, 2004 Just went yesterday lah bang ... came back jam like sardines manz Lucky I pump to the brim in anticipation of the jam Clean up house until siaozzzzz Link to post Share on other sites More sharing options...
King 1st Gear January 12, 2004 Share January 12, 2004 ya,i saw the traffic camera,so decide not to go in. next week i go in i call u Link to post Share on other sites More sharing options...
Ninox Neutral Newbie January 12, 2004 Share January 12, 2004 Was having the same problem after 90,000km and SM replaced the throttle body. Cost more than a k for the replacement. Try cleaning it first. Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 12, 2004 Share January 12, 2004 His throttle body quite hard to access... And I thot only Alfa has hard to reach parts! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 12, 2004 Share January 12, 2004 alfa one consider OK liao lor... Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 12, 2004 Share January 12, 2004 Two possible causes - a) Vacuum leak - check vacuum hose connections to intake plenum b) Hot wire in throttle housing malfuctioning - unable to send the correct DCvolt corresponding to throttle opening. Hot wire has a very special coating - do not attempt to clean with aerosol degreaser or carburator cleaner. The best cleaning fluid - electronic component contact cleaner HTH Link to post Share on other sites More sharing options...
Regboyboy Neutral Newbie January 12, 2004 Author Share January 12, 2004 Can't very hard to access Link to post Share on other sites More sharing options...
Regboyboy Neutral Newbie January 12, 2004 Author Share January 12, 2004 Wah so ex? Anyway thanks for the info! What car are u driving? Link to post Share on other sites More sharing options...
Regboyboy Neutral Newbie January 12, 2004 Author Share January 12, 2004 Ok thanks Link to post Share on other sites More sharing options...
Audiorook Neutral Newbie January 12, 2004 Share January 12, 2004 Agree with you....on this,other than IPSum,this is the other car throttle body then hard to access.... Agree on the Ipsum.... thats why couldnt do the clean on last friday... boo hoo hoo ↡ Advertisement Link to post Share on other sites More sharing options...
Inconsistent RPM
Inconsistent RPM
Inconsistent Idling Speed
