Beregond Supersonic July 16, 2013 Share July 16, 2013 The adjustment he dun make much but he make on the camber bolt lah. Hahaha. Marketing stratergy. this 1 we cannot comment untill we see his report , or he know how much his camber is out. maybe he hit a kerb and car is pulling 1 side alot, and result show camber - 3-4 degree. what else to do expect install camber kit??? but its true that alot of shop use it to con unknowing customer, by scareing them that a bit camber off, must do , if not dangerour babababa, crab story, and the owner is pressure into installing a camber kit. but my understanding, install front 2 camber kit , plus ajustment with toes ajust , total 130 sgd, very reasonable to me, the camber kit of from spc, already cost 40 +-??? ( asuming he really need to ajust his camber) ↡ Advertisement Link to post Share on other sites More sharing options...
Yhn 4th Gear July 16, 2013 Share July 16, 2013 All cars the front n some the rear can adjust with the original bolts. Some car models the rear r fixed n cannot adjust. Camber n toe-in/toe-out can adjust. Only castor usually cannot adjust. Now many alignment shops using this "change camber bolt" as their new con job to cheat customers. Thanks your enlightenment Link to post Share on other sites More sharing options...
Prostcode Clutched July 16, 2013 Share July 16, 2013 (edited) Talking about alignment shops in JB, any to recommend? Pls provide address also. Thanks Edited July 16, 2013 by Prostcode Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 16, 2013 Share July 16, 2013 this 1 we cannot comment untill we see his report , or he know how much his camber is out. maybe he hit a kerb and car is pulling 1 side alot, and result show camber - 3-4 degree. what else to do expect install camber kit??? but its true that alot of shop use it to con unknowing customer, by scareing them that a bit camber off, must do , if not dangerour babababa, crab story, and the owner is pressure into installing a camber kit. but my understanding, install front 2 camber kit , plus ajustment with toes ajust , total 130 sgd, very reasonable to me, the camber kit of from spc, already cost 40 +-??? ( asuming he really need to ajust his camber) Hv u seen this camber bolt? Its just a normal bolt with the shaft a part off center. That helps to adjust the camber by just turning the bolt. Maybe it makes the job of adjusting easier but ty charge $60 a bolt is crazy. I think their cost most $10 only. So from there I see the profit is damm good thats why ty try to promote u to change the camber bolt. Even if his car hit e kerb n nothing bent, ty can just adjust back without the camber bolt. In fact the bolt does not increase the amt of adjustment. I know its a con cos I used to go to a shop in SG to do alignment all along n he never say must change my bolt. Then one day I go he say must change. So OK I think change lah. Then my next trip he again say must change the bolt. Well seems strange cos all along no problem then all of a sudden he say both bolts need to change one after another. Then on my third visit he again say must change bolt. I was WTF????? Recently he changed both n now say again must change? I already suspect something fishy. From then when I go do alignment, I always tell him do not change any camber bolt. Just do the alignment. He was also trying to sell me his rims n tires which I always say no need cos I can get cheaper from other places. Then he start to play around with my tire pressures. Pump very high n then pump all different pressures till I skidded. From there I never go back there. BTW if u wan to know....the shop is Cr3@tive Trdg at woodlands Indl PK E1. Now I get all my tire alignment done in JB n I also told them I do not want to change any camber bolt. The guy just smile at me. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear July 16, 2013 Share July 16, 2013 If already install the chamber bolt - will this thing post any danger after prolong driving..? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 16, 2013 Share July 16, 2013 Camber bolt is basically a eccentric bolt that is a bolt with a cam for leverage. If the bolt is make from inferior carbon steel, the wear off will be fast. Link to post Share on other sites More sharing options...
Patrickyan Clutched July 17, 2013 Share July 17, 2013 Can try rapid auto to do alignment Link to post Share on other sites More sharing options...
Bonafidestack 4th Gear July 17, 2013 Share July 17, 2013 I did mine at autokinetics at macperson road. Gotta give bryant a call 1st. Nowadays his car pack until full full one. hahaha Link to post Share on other sites More sharing options...
Nothing78 Neutral Newbie August 6, 2013 Share August 6, 2013 Just done wheel aligment at JC Wheel Dynamic Pte Ltd 48 Toh Guan Road East Enterprise Hub Contact : 8481 8985 Look for ah seong, Sincere Boss and will make sure ya car is done up properly. I have visited kenny a few times. Both of them are as good. Cheers I also did my alignment with Ah Seong for years, never give problem before. Thumbs up for him. Link to post Share on other sites More sharing options...
Ooosh 1st Gear August 6, 2013 Share August 6, 2013 For most Jap and Asian and even some European economical cars, most of them comes with rear dead axle ( no adjustment provided) and the front drive comes with MacPherson strut and fix camber angle ( no adjustment provided). So with such cars , the only adjustment is the front wheel toe angle. Using a 4 wheel computerised aligner is 100% over kill. Do you mean cars that back suspension is the torsion beam and not 'independent' suspension like Multi-link or double wishbone? I think cars with torsion beam suspension dont have to adjust back alignment.. Link to post Share on other sites More sharing options...
Zard Neutral Newbie November 21, 2013 Share November 21, 2013 'Jeff23', on 05 Jun 2012 - 2:22 PM, said: Just done wheel aligment atJC Wheel Dynamic Pte Ltd48 Toh Guan Road EastEnterprise HubContact : 8481 8985Look for ah seong, Sincere Boss and will make sure ya car is done up properly. I have visited kenny a few times. Both of them are as good. Cheers I also did my alignment with Ah Seong for years, never give problem before.Thumbs up for him. Cost? Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic January 24, 2014 Share January 24, 2014 (edited) Can i ask u guys any recommended good alignment shop preferred area northeast or west? Then how much the price? Isit diff car brand diff pricing? Is it conti cars and japs cars has diff way of alignment? I was quoted for a crazy price in AD Edited January 24, 2014 by Thaiyotakamli Link to post Share on other sites More sharing options...
Picanyeo 1st Gear January 24, 2014 Share January 24, 2014 JC wheel alignment at Jurong. I went there twice. Thumbs up for Ah Xiong (person-in-charge)! Link to post Share on other sites More sharing options...
Picanto 3rd Gear January 24, 2014 Share January 24, 2014 how much they charge? Can i ask u guys any recommended good alignment shop preferred area northeast or west?Then how much the price? Isit diff car brand diff pricing? Is it conti cars and japs cars has diff way of alignment?I was quoted for a crazy price in AD Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic January 24, 2014 Share January 24, 2014 how much they charge? 240, bro any recommendation for merc/bmw specialist workshop for alignment? Link to post Share on other sites More sharing options...
Donut Supercharged May 4, 2014 Share May 4, 2014 I just did wheel alignment at Arrow Tyres, serangoon north. they got new Hunter machine. cost $60 with GST included, for my jap car not promoting them, but quite a good experience with them. Link to post Share on other sites More sharing options...
HOLY888 Neutral Newbie May 4, 2014 Share May 4, 2014 PURE DRIVE PTE LTD. At HARVEST WOODLANDS INDUSTRIAL PARK E5 Link to post Share on other sites More sharing options...
Club21z 4th Gear May 7, 2014 Share May 7, 2014 Done mine at Yew Tee industrial park, at the corner shop using hunter equipement. $50, reasonable price to me compared to those "premium expert" . ↡ Advertisement Link to post Share on other sites More sharing options...
Audio Shop Recommendation
Any recommendation for ear digging?
Wheel Hubs
Wheel Hubs
Recommendation for locksmith
