Jaason Neutral Newbie October 1, 2004 Share October 1, 2004 Engine Wash => applying some chemical and washing it away with water spray + drying it with air gun. It is advisable to have engine wash? If Yes, how regularly? And what to lookout for? If No, why not? What damage do you think it will have done? Your views please. ↡ Advertisement Link to post Share on other sites More sharing options...
Panda Neutral Newbie October 1, 2004 Share October 1, 2004 I wash my engine weekly... To me an engine wash => hose down, soap, hose down, wipe dry. All these should only be done when the engine is not too hot. Stay away from the battery terminal. The rest of the electricals should be well insulated. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie October 1, 2004 Share October 1, 2004 wash only when you think it's too greasy and dirty. I had mine washed in May this year. Still clean and dust free up to now. If need be, perhaps once a year is good enuf, but then again, it's only a guide. even the car manual does not mention anything about engine washing. Depending on the age of your car, it's wise to keep some electrical compartments dry while washing the engine. eg Distributor, plug caps etc etc... If you intend to use chemicals, just make sure you wash it in an airy environment. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 1, 2004 Share October 1, 2004 Engine bay washing is part and parcel of preventive maintenance program. Know where you are spraying the water - chemical wash and low pressure water jets is most idea. After washing use high volume compressed air to blow dry and then send your ride for a sunbath in the carpark. Link to post Share on other sites More sharing options...
Gylgyl Neutral Newbie October 3, 2004 Share October 3, 2004 not a good idea to wash often... cos it will also wash away all grease and lubricate which are meant to be there ... alway re grease all moving parts after wash.. just my experiences Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 4, 2004 Share October 4, 2004 Hardly you can find any grease point in today's car.All moivng parts are greased and packed for life. ↡ Advertisement Link to post Share on other sites More sharing options...
Car wash at JB
Car wash at JB
Saw a Chinaman teaching his daughter how to wash car...
SCHNELL Engine Oil 5W40
SPC Minds Wash towards Vivo City/Harbourfront(Pasir Panjang)
P2096 Check engine light
Why Singapore don't have such a car wash machine anymore?
DIY engine oil change
