Lufu 1st Gear November 4, 2002 Share November 4, 2002 I notice engine oil comes in different grade, 15W50, 20W50, 5W40 etc.. how to i decode it? what does the 15 means? W50 means ? Which is better than another ? Thanks to all the experts :-) ↡ Advertisement Link to post Share on other sites More sharing options...
Wrxblue 1st Gear November 4, 2002 Share November 4, 2002 Please note that we are using the SAE Viscosity Grade Viscosity is a measure of an oil's flow characteristics, or thickness, at certain temperatures. The low-temperature viscosity (the first number, 5W in the example above) indicates how quickly an engine will crank at cold temperature and how well the oil will flow to lubricate critical engine parts at low temperature. The lower the number the more easily the engine will start in cold weather. The high-temperature viscosity (the second number, 30 in the example above) provides thickness, or body, for good lubrication at operating temperatures. A multigrade oil (for example, SAE 5W-30) provides good flow capability for cold weather but still retains thickness for high-temperature lubrication. so depending on your location and usage the above should give you a guide on the type of oil you should use. ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
Scientists find rich and poor are 'biologically different'
P2096 Check engine light
DIY engine oil change
My engine after 150,000 kms
