Genie47 1st Gear August 3, 2005 Share August 3, 2005 If you want to test very easy. Take your stock filter box out. Connect to vacuum cleaner. At least 2000W type and does not use bag. Dyson comes to mind. 1. Wash the dust collector with known water. Pour the water through filter funnel with filter paper. Collect the filter paper. This is your negative control 1. 2. Install the collector and start sucking air with no filter for xx min. Longer the better. Take collector out wash with water and collect water through filter funnel with filter paper. Keep the filter paper. This is negative control 2. 3. Hook up the filter box with stock filter. Start vacuum cleaner and run for the same xx min. Again wash with water and collect through filter paper. Keep filter paper and label this "stock filter". 4. Hook up the filter box with Hurricane. Start vacuum cleaner and run for the same xx min. Again wash with water and collect throguh filter paper. Keep filter paper and label this "Hurrican filter". 5. You can hook up K&N, APEXi or anything and repeat. 6. Dry the filter papers. Spread them out and take pictures. The one with the least dirt has the better filtration and the one with the most dirt has the poorest. If you want numbers, you might need to put it through a particle counter but that is beyond the home lab. Best is to run the vacuum for 30min for each filter. ↡ Advertisement Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie August 3, 2005 Share August 3, 2005 hehe, i've got the vacumn, i've got k&n, i've got stock paper filter, but no hurricane, anyone wanna sponser? Link to post Share on other sites More sharing options...
C708 Neutral Newbie August 3, 2005 Share August 3, 2005 6. Dry the filter papers. Spread them out and take pictures. The one with the least dirt has the better filtration and the one with the most dirt has the poorest. Would like to point out that your assessment is totally wrong.....if filtration is good, the filter would trap more dirt, instead of what you point out above.....most dirt is the poorest......that would mean filtration is not good.....if it filters dirt ...it means that dirt is trapped onto the filter, not vice versa.......such a wrong perception......totally misleading !! Anyone care to second my view ?? Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear August 3, 2005 Share August 3, 2005 think u have misunderstood his experiment. from i gather, the filter paper is like the engine innards and serves to collect unfiltered particles which have bypassed the XXX brand air filter. so filter paper with the least dirt means most of the dirt has been trapped by the XXX brand air filter -> good filtration properties. right Genie? Link to post Share on other sites More sharing options...
Reliable Clutched August 3, 2005 Share August 3, 2005 think u have mis-read his experiment. Link to post Share on other sites More sharing options...
Genie47 1st Gear August 3, 2005 Share August 3, 2005 Yes, you have interpreted this correctly. More dirt found in the vacuum cleaner's collection bin = the dirt got through the filter. Link to post Share on other sites More sharing options...
Kklee 6th Gear August 4, 2005 Share August 4, 2005 how many microns ( of dust, etc ) can the hurricane trap or filter? Link to post Share on other sites More sharing options...
Lammy Neutral Newbie August 4, 2005 Share August 4, 2005 its about 80microns, close to that of HKS open pod. Link to post Share on other sites More sharing options...
Geminian1906 Neutral Newbie August 5, 2005 Share August 5, 2005 (edited) tat means the filteration is not as good as K&N filter? Edited August 5, 2005 by Geminian1906 Link to post Share on other sites More sharing options...
Lammy Neutral Newbie August 5, 2005 Share August 5, 2005 Hi Guys, Come by Autotrail 05 booth A33-34 for coffee and reception at 3pm, Saturday 6 Aug 05. All are invited. Lammy Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie August 5, 2005 Share August 5, 2005 how many microns is K&N? Link to post Share on other sites More sharing options...
Kklee 6th Gear August 6, 2005 Share August 6, 2005 http://knfilters.com/faq.htm#10 Link to post Share on other sites More sharing options...
Hattee Neutral Newbie August 6, 2005 Share August 6, 2005 If you take any KNN filter and look at it facing a good light source, you be surprised by the number of large pores scattered all over. These pores appear no less than 250 micron (1/4 mm). Perhaps, their filtration rating is based on normal distribution of particles penetration and never absolute effective particle obstruction. You might not find so many large pores with Hurricane apparently, tho' both have almost similar spread manner of filter element. Link to post Share on other sites More sharing options...
Neesun Neutral Newbie August 6, 2005 Share August 6, 2005 Some interesting comparisons here , air filter tests -> http://www.bobistheoilguy.com/airfilter/airtest1.htm Link to post Share on other sites More sharing options...
Breezepass79 Neutral Newbie August 8, 2005 Share August 8, 2005 i am using a simota one.. it not crazy gain but satisfactory.. am thinking to mod to a aero form sys frm them.. with carbon fiber Link to post Share on other sites More sharing options...
Sunsmile Neutral Newbie August 8, 2005 Share August 8, 2005 I can feel better throttle response and some power gain. I think it's worth buying as it is maintenance friendly. Unlike K&N filter, u need to apply special oil to the filter. With hurricane filter, all you have to do is wash it with water and dry it, that simple. I bought it at $105 and heard that they are going to jack up the price to $130 after our national day. Link to post Share on other sites More sharing options...
Genie47 1st Gear August 8, 2005 Share August 8, 2005 Nothing can beat the stock filters but even with stock filters, our local guys are finding stuff entering the engine. The air quality here is bad in the particulate department. The US car owners don't face much of this problem. Ironic that an industrialized nation has cleaner air than our tiny red dot. Link to post Share on other sites More sharing options...
V200 Neutral Newbie August 10, 2005 Share August 10, 2005 You want, I can get my hands on particle counter! But it is 0.3 and 0.5microns! I think in 1 min, the counter will kaput! Lazer contaminated ! ↡ Advertisement Link to post Share on other sites More sharing options...
Air Purifier Discussion - tips and info
DIY engine oil change
Steel cabinet
Steel cabinet
Recommendation for water filter
K&N or Hurricane or works stainless steel air filter.
Dyson Zone, the real deal or has April fool's day come early?
Replacing fuel filter
