Ae86 Neutral Newbie March 27, 2006 Share March 27, 2006 Your tweeters are mounted on the sail panels so stage height is no problem.Have you try switching the amp back to full range and just let the passive x-over do the filtering?Does your head unit have built in eq, dsp or time alignment if it has then try to fine tune your system, I don't see the need to buy additional x-over or eq this will not solve the problem.Do you happen to know what is the frequenycy of the passive cross over of the front speakers? ↡ Advertisement Link to post Share on other sites More sharing options...
Tanjkp Clutched March 27, 2006 Share March 27, 2006 haha... well i am not new to audio... i used to play audio equipment in my room but my dad complaining that i have been making too much noise so i moved to car audio as he will not hear the noise haha... get what i mean... well nowadays cars hu cannot be change and yes i tap from speaker cable... and i doubt my hu can be removed... PS... this is really the first equipment that i have used... previously was in my mum's family car but now i got my own so moved it... but the pro60 and one of the naka 4ch is new... Tapping sound from speaker will not have good effect. To have good sound effect the sound must tap out from audio out of HU and plug into audio in of the additional amp. Link to post Share on other sites More sharing options...
Wahlao Neutral Newbie March 27, 2006 Share March 27, 2006 u should either come down to the ICE meetup to seek second opinions or just head to a competant installer to check ur setup. I'm assuming you know the fundamentals of sound from playing home audio & that the setup is done correctly (e.g. speakers/tweeters not out of phase like some bros pointed out) there's limitations to the tuning due to the integrated HU for conti cars but that doesn't mean it can't be done, especially after spending a considerable amt of $$$ Link to post Share on other sites More sharing options...
Coolnil Neutral Newbie April 8, 2006 Author Share April 8, 2006 when and where is the usual meetup? Link to post Share on other sites More sharing options...
Wahlao Neutral Newbie April 9, 2006 Share April 9, 2006 refer to this thread:- http://www.mycarforum.com/forum/Aftermarke...APRIL_P1285126/ note that the usual place is MacPherson Jackson Kopitiam Nasi Padang Place Link to post Share on other sites More sharing options...
Seven Neutral Newbie April 9, 2006 Share April 9, 2006 it seems like the audio source is just tapped from the original left right spk wires. (4 wires, 2 front and 2 rear) and you are feeding the same signal into 3 sets of amps. there could be some impedence mismatch somewhere. (the hi-low thingy maybe ?) does the HU have any subwoofer line out at the back that you can send to the sub's bridged amps ? ↡ Advertisement Link to post Share on other sites More sharing options...
RAM/MicroSD issues
RAM/MicroSD issues
