EP70 specs
Steam
How's it going?? How are you guys?? Dave, remember the option auto vid you sent me? It was running a 5E....is it the 5E-FHE or what?? What model?? Oh....whats your new phone line??
Toyota Starlet (EP70)
-FWD
-1000cc 12-valve 4-cyl in-line engine, with a toothed belt-driven overhead camshaft.
-engine is water-cooled and fitted transversely into the engine compartment.
-front suspension consist of spring struts with coil springs and lower suspension arms.
-rear suspension is made up of a axle carrier, with welded on suspension arms, spring struts with coil springs and a lateral rod(Panhard bar).
-hydraulic, telescopic shock absorbers arer integral with the spring struts.
Dimension & weight
-overall length: 3708mm
-overall width: 1600mm
-overall height: 1397mm
-wheelbase: 2300mm
-front track: 1385mm
-rear track: 1345mm
-ground clearence: 165mm
-turning circle: 9.8m
-kerb weight: 750-775kg
-max. permissible weight 1225kg
for reference... Bro,
What about the rim size? My front tyres are balding and need replacement soon. I wonder whether 15" inch rim is ok or not. But then again, it makes the mileage and speedometer inaccurate if its of 13" or 14" type.
