Ody_2004 Turbocharged September 27, 2006 Share September 27, 2006 Hi, Is it normal to have different gap from the fender to the tires? For my rear right the gap is 2 fingers, for my rear left the gap is 3 fingers. I checked it on level ground. Is this normal? I had just change the shock and spring. ↡ Advertisement Link to post Share on other sites More sharing options...
Wpho Neutral Newbie September 27, 2006 Share September 27, 2006 I have the same experience with my 2001 Ody and my altis. I have checked with a few installers and they all say its normal. Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged September 27, 2006 Author Share September 27, 2006 Thanks for the reply. But i don understand why is it normal. My car seem dipping to one corner. Link to post Share on other sites More sharing options...
Mtang36 Neutral Newbie September 27, 2006 Share September 27, 2006 I don't think its normal. Bring it to another workshop to have it checked. Link to post Share on other sites More sharing options...
Machspeed Neutral Newbie September 27, 2006 Share September 27, 2006 don't seem normal unless u have additional load in the car causing the car to lean to 1 side.. Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged September 27, 2006 Author Share September 27, 2006 that's no additional load at any end. Thanks for all reply. Will get it check. Link to post Share on other sites More sharing options...
Wpho Neutral Newbie September 27, 2006 Share September 27, 2006 Can you confirm it is the rear right that is lower than the rest? You must check this when the car is standing on completely flat surface. This was the case for both my cars. Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged September 27, 2006 Author Share September 27, 2006 yes. completely flat and level surface. I try multiple area to confirm it. Link to post Share on other sites More sharing options...
Icekitten Clutched September 28, 2006 Share September 28, 2006 Confirm not normal. I just went for adjustment of springs and had the same problem as you. The reason for that was bcoz they forgot to adjust one side. Link to post Share on other sites More sharing options...
Kazuo Neutral Newbie October 10, 2006 Share October 10, 2006 front and back don't have to be equal spacing, afterall, the rear can sit more people, heavier and will sink down more. as for tilted to left or right, i'm not sure. Some say normal, some think it's abnormal. ↡ Advertisement Link to post Share on other sites More sharing options...
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
Deadly amusement park ride
Batteries for ride-on toys
Front lower arm and suspension questions
Car F*ckability Test
