Passion 5th Gear July 1, 2008 Share July 1, 2008 Bro,got money buy big car,don't save on all this small different in petrol.Shows that you're super niao.Scare then go pump Ron95.I saw alot of huge car like alphard,toyota ISIS and dunno what model from toyota all pump 92 at SPC.these ppl are really one kind. ↡ Advertisement Link to post Share on other sites More sharing options...
Zakuii 1st Gear July 1, 2008 Share July 1, 2008 It is not neow or neow. If the car drinks min 91, no harm pumping 92. Why create wastage by pumping a more expensive petrol? Link to post Share on other sites More sharing options...
Passion 5th Gear July 1, 2008 Share July 1, 2008 bro,different country,different requirement for the engine.that's explain why some car from PI need to go thru LTA checks before release in the market.So it may requirement 91 in Japan,but for singapore atmosphere,may need at least 95?I may be wrong,but i heard this is what happen. Link to post Share on other sites More sharing options...
Zakuii 1st Gear July 1, 2008 Share July 1, 2008 (edited) The manual will state what ron to use. When I was driving the 2l Stream, it is stated clearly in the manual it can use ron 91 and above (for SEA countries, I believe). I believe Stream's K20 engine block and Civic 2l K20 block should be somewhat similar. If so, it should be able to take ron 91 or above. And, I believe petrol grades has nothing to do with environment. Engine oil is. And Japan has equally extreme weathers too, like very hot or very cold, for months. Therefore, their weather conditions are worst than ours. Singapore's temperature fluctuations is almost similar throughout the whole year. Edited July 1, 2008 by Zakuii Link to post Share on other sites More sharing options...
Passion 5th Gear July 3, 2008 Share July 3, 2008 Engine oil has different.Petrol also makes a different if I'm not wrong.Something to do with engine crank or something.Some experts pls enlighten. Link to post Share on other sites More sharing options...
Xieboren Neutral Newbie July 22, 2008 Share July 22, 2008 if the compression ration above 10.5,theorytically can. Link to post Share on other sites More sharing options...
Theman Clutched July 22, 2008 Share July 22, 2008 yup, no problem at all, in Japan, only have ron 91 and ron 100 (or 100 soemthing, cant remember clearly), all the car can use ron 91, except for certain sports car which speficically mentioned can't use ron91. ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
2022 Toyota GR Corolla
2025 Mitsuoka M55
2025 Mitsuoka M55
Honda Civic servicing... Which workshop to go?
