Mini-itx Clutched September 27, 2010 Share September 27, 2010 Just asking whats the benefits of using a low temp thermostat (if there is any). Cause mine is stucked open and I need to get it replaced. ↡ Advertisement Link to post Share on other sites More sharing options...
Thug Clutched September 27, 2010 Share September 27, 2010 They simply open up at lower temp so ur engine will be cooler... but engines need to be a certain temp to function at its full. If u are racing everyday then do it. If not... Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear September 27, 2010 Share September 27, 2010 Just asking whats the benefits of using a low temp thermostat (if there is any). Cause mine is stucked open and I need to get it replaced. Perhaps if you only drive (not hypermiling) on during the hot days here, not too much issue (COE only ten years) ↡ Advertisement Link to post Share on other sites More sharing options...
DTC P0597 Thermostat heater control system open circuit
Is there a cure/remedy for Diabetes?
Hahaha there was a bird on my car...
What to wear with max temp 20 degree and minimum 10 degree
Awana Genting-Anybody stay there recently?
Is there a Honda S2000 forum out there?
How to reduce air temp inside car on hot days?
