Turbobrick Neutral Newbie January 2, 2002 Share January 2, 2002 Why You Shouldn't Run On Empty There ↡ Advertisement Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear January 2, 2002 Share January 2, 2002 Hmmmm...seems like very good & valid reasons to go JB pump petrol man !![;)] Didn't know about the pump getting hot thingy but my mechanic has always advise me not to drive until empty....always pump while 1/2 tank. No harm done & while begin able to maintain the pressure & hence better fuel economy. It is true....if I drive till empty then pump petrol, I tend to "lose" a few kms.....but if half tank....the mileage seems better...... Or is it just me ???[crazy] Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 2, 2002 Author Share January 2, 2002 A definitely minus for running till dry is indeed the risk of having fuel pump failure due to running hot as fuel is the cooling medium. Similar to the coolant water pump where the coolant/water is the cooling medium for the pump as well. My car gets shitty economy unless crusing on highway consistently so cannot verify the half tank/empty tank symptom. I usually run till 1/3-1/4 before filling. Link to post Share on other sites More sharing options...
Spinner Neutral Newbie January 2, 2002 Share January 2, 2002 Tks. I am too lazy to pump everytime it hits half tank, too troublesome leh. But after hearing what you guys say here...scary man. Link to post Share on other sites More sharing options...
Chase Neutral Newbie January 20, 2002 Share January 20, 2002 I used to always run near empty to measure my fuel consumption. I guess I'll have to kick this bad habit from now on! Link to post Share on other sites More sharing options...
Sky8807 1st Gear January 20, 2002 Share January 20, 2002 If u really want to run low on fuel b4 fill-up. U can fill up at 1/4 tanks or the minute the low level light comes on. When the low light comes on, for me, I will pump on the next available pump I come across. Always got at least more than 5 litres of fuel in the tanks as the bare minimum. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 21, 2002 Author Share January 21, 2002 Yeah, usually the low fuel warning lamp comes on with about 5-10litres remaining, check your owner's manual to be sure. My brick's fuel warning comes on at 8 litres, weird Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 22, 2002 Share January 22, 2002 My babe's light comes on at 7L left. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear January 22, 2002 Share January 22, 2002 That is bcos your brick sucks petrol from those bubble tea straw !!! 8L may not be enuff to get you to the next petrol station....either that or the swedes are getting more and more kiasu liao !! Link to post Share on other sites More sharing options...
Sky8807 1st Gear January 22, 2002 Share January 22, 2002 Mine come on when there are about 7 litres left. Tried it once, quite accurate from what the manual says -7.5 litres. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 22, 2002 Author Share January 22, 2002 I think my brick drinks with TWO of those bubble tea straws.....as long not sucking up pearls into the fuel lines ok lah When we go for Bubble Tea supper har? Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear January 23, 2002 Share January 23, 2002 Suck pearl is okay....dun suck up those broquet pellets can liao !! Bwahahahahahahaha Supper....did someone say supper ??? Onzzzz....give me a call to arrange lor....not a problem....but maybe next week better then can jio Skodaman out also...he busy this week. Link to post Share on other sites More sharing options...
Chase Neutral Newbie March 17, 2002 Share March 17, 2002 The problem is my car has not low fule indicator!!! Yes, none!! My tanks is supposed to be 45l but I have travelled on "empty" for > 50km before and no light! When I finally pumped, it's 40l. If u really want to run low on fuel b4 fill-up. U can fill up at 1/4 tanks or the minute the low level light comes on. When the low light comes on, for me, I will pump on the next available pump I come across. Always got at least more than 5 litres of fuel in the tanks as the bare minimum. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie March 18, 2002 Author Share March 18, 2002 So U mean that other than the "E" mark on the fuel gauge, there's no little LED light to indicated low fuel? Better not risk running so low, no good for fuel pump. Link to post Share on other sites More sharing options...
Xxxsiao Neutral Newbie March 18, 2002 Share March 18, 2002 This might sounds a bit silly, but I've seen it for myself. Me and my friend pumped fuel at the station near malaysia custom. When he filled it to the brim, and I really Mean to the brim, he applied his hands on the rooftop and started to bounce the car up and down. Then the fuel level seems to went down, and he continued this process until he squeezed in an additional dollar. I was incredulous(it looked really stupid, like some cheapskate). He said this was to allow the bubbles to float up so he could sqeeze in more. Can anyone attest to this? Or am I being swakoo? Link to post Share on other sites More sharing options...
Chase Neutral Newbie March 18, 2002 Share March 18, 2002 Yep another flw of humble stead....so after reading this thread, I have always made it a habit to pump when it's 1/4 to empty. So U mean that other than the "E" mark on the fuel gauge, there's no little LED light to indicated low fuel? Better not risk running so low, no good for fuel pump. Link to post Share on other sites More sharing options...
Chase Neutral Newbie March 18, 2002 Share March 18, 2002 LOL! That's really farnee! Cos Msian petrol cheap so must squeeze more is it? But wouldn't that maybe spoil the sensors? You migth waste more money reparing in the end... This might sounds a bit silly, but I've seen it for myself. Me and my friend pumped fuel at the station near malaysia custom. When he filled it to the brim, and I really Mean to the brim, he applied his hands on the rooftop and started to bounce the car up and down. Then the fuel level seems to went down, and he continued this process until he squeezed in an additional dollar. I was incredulous(it looked really stupid, like some cheapskate). He said this was to allow the bubbles to float up so he could sqeeze in more. Can anyone attest to this? Or am I being swakoo? Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie March 18, 2002 Share March 18, 2002 This method is only apply on Diesel, not for petrol fuel. And also for the old model Diesel car like taxi, since the fuel tank got no small air pipe and always chok back the diesel. ↡ Advertisement Link to post Share on other sites More sharing options...
Alfa gt 2jts or 2.2 . is it a gd buy to drive till scrap??
Any Car Battery Shop open till late
Coolant empty
Coolant empty
Qatar hires "$8 fake fans" to fill empty stadiums
Radiator Reserve tank Empty after changing aircon fan motor
SG: Empty ballot boxes found!
Woman bullies NSF into standing in empty train
Watch till end!
Watch till end!
