Is FB battery good?
Qooo
Is there difference in wet or dry MF battery?confused.gif I tot MF oredi can liao, cos dont need to top up.
Yalor... I think MF battery got 2 types. Wet and dry. Mine's the wet type, thus not totally sealed one.
The only complain I have abt my old completely sealed 'dry type' one is once it die, means die. Get stuck at the most inconvenient time! :P
Now trying the MF wet type to see if it can overcome the above problem. Any one with this battery have used till the last drop? Does web type MF battery also just die without warning?
26months shocked.gifthumbsup.gif How I wish mine would so do the same.... now oredi 18months.
hi,
so "normally" how long can a MF battery last then?
is there some sort of indication/label on the battery to say how long can tahan before it dies on u?
Wow so good 70Ah/h. Can gimme the contacts. Tks!
I don't think is necessary to use a 70AH battery if you ride does not have heavy ICE in it. Normally using large capacity battery need to upgrade also the alternator. Otherwsie the charging is nor sufficient. Check you car's manual od std. battery capacity. Slightly more should be alright.
It should not matter even if you have heaps of ice. By right all electrical items should run straight off the alternator when the car is turned on.
Car batteries will die quicker with slow drain than with fast drain (i.e. from start-up) as they are designed that way (hybird car batteries are the opposite). The important bit is the CCA (cold cranking amps), the higher it is the more power that can go to the starter motor for 30 seconds (e.g. 330CCA means 330 amps in a period of 30 secs) so the car starts faster/better. Also important is the RC (reserve capacity) which is the amount minutes the car can continuously make 25amps with the voltage dropping below 10.5v (Amp hour-AH is similar but shows what amps for one hour) because this correlates with how long accessories can last when the car is turned off.
batteryfaq.org is a pretty good resource if you want to know more.
