Hkarwai Neutral Newbie December 14, 2005 Share December 14, 2005 How to improve this car performance? ↡ Advertisement Link to post Share on other sites More sharing options...
Route Clutched December 14, 2005 Share December 14, 2005 tc Link to post Share on other sites More sharing options...
Toyo 1st Gear December 15, 2005 Share December 15, 2005 the charade being a 3 cylinder engine is not really a performer unless its a Gtti. i wld suggest u to send to a mechanic, change whatever is necessary, maintain it well and it shld perform good enuf Link to post Share on other sites More sharing options...
Atlantis_boi Clutched December 15, 2005 Share December 15, 2005 Put a GTTi engine under the hood Service it regulary. Keep the engine in a healthy condition. Once in a while, pump good petrol to pamper the car & add additives to clean the engine & clear off the carbon. Link to post Share on other sites More sharing options...
Hkarwai Neutral Newbie December 15, 2005 Author Share December 15, 2005 Hardly can find turbo engine.. further expensive to change one or to maintain.. Thinking can turbo charge it? add accessories to improve it? Link to post Share on other sites More sharing options...
Atlantis_boi Clutched December 15, 2005 Share December 15, 2005 I dunno if nwdays u stil can get a GTTi half cut engine anot. If can, it wun b too expensive. It's of course possible to turbocharged ur current engine but not too high a boost else u risk 'piang-ing' ur engine if u didnt strengthen the internal. Link to post Share on other sites More sharing options...
Toyo 1st Gear December 15, 2005 Share December 15, 2005 maybe can try aftermarket air filter, open pod or drop in. u can also consider Grounding, Volt stabilizer Link to post Share on other sites More sharing options...
Hkarwai Neutral Newbie December 15, 2005 Author Share December 15, 2005 half cut GTTI consists of what? Just add on to my existing engine? Need LTA approval? Link to post Share on other sites More sharing options...
Atlantis_boi Clutched December 15, 2005 Share December 15, 2005 (edited) Nono. Half cut meaning the GTTI engine & the turbo. SOme comes with all the necessary piping while some dun. If it does, u juz haf to remove ur existing engine & fit in the later engine & fix up everything. Dun bother with LTA. They will nv approve as this is a 'not standard' mod Hope u get wad I mean Edited December 15, 2005 by Atlantis_boi Link to post Share on other sites More sharing options...
Stivo Neutral Newbie December 15, 2005 Share December 15, 2005 i hope this helps .... the easiest way or cheapest way is 1. change a straight thru' exhaust 2. get a CAI feed 3. do a grounding on the car 3. remove any reduncdant weight on the car...eg. spare tyres ( i know you are thinking what if you have got a puncture tyres.... you are in Spore so help is available) anything other than that cost $$ Kelvin Link to post Share on other sites More sharing options...
Ncss Clutched December 16, 2005 Share December 16, 2005 (edited) This car is 3 cylinder... no hope to be powerful. Can only use as normal small family car follow behind others. My friend own it before... not must use after doing tons of mod & finally give up. Good start to be the first car to practice your public road skill... but you will get bore after sometime because always kenna bully... but dammed good for parking. Edited December 16, 2005 by Ncss Link to post Share on other sites More sharing options...
Route Clutched December 16, 2005 Share December 16, 2005 sorry, but correct me if i'm wrong. i've always heard of the kelisa engine being more powerful because its 3 cylinder? Link to post Share on other sites More sharing options...
Freakman Neutral Newbie December 16, 2005 Share December 16, 2005 cant agreed with you more bro... cause i dring 3 cycl COE car also.. and i know how it feels... Link to post Share on other sites More sharing options...
Freakman Neutral Newbie December 16, 2005 Share December 16, 2005 sorry, but correct me if i'm wrong. i've always heard of the kelisa engine being more powerful because its 3 cylinder? you are comparing a new car to a 13/14 year old car leh... how to?? techology also different leh.. Link to post Share on other sites More sharing options...
Freakman Neutral Newbie December 16, 2005 Share December 16, 2005 How to improve this car performance? brother.. like some of the bro here mentioned, no point doing up a 14 year old 3 cyclinder car.. what is more important is keep the spare cash for wear and tear along the way... you need it.. trust me cause i have been driving my old car for 3 years liao and have been booking doctor appt regulary... unless if $$ is not a prob for you.. then sure drop a GTTI engine.. and hope dun get stop by TP... Link to post Share on other sites More sharing options...
Ncss Clutched December 16, 2005 Share December 16, 2005 (edited) Last time my friend own them leh... cannot run. Test drive before... Change exhaust, change this & change that also no use. 1 driver can run a bit la..., behind add 2 more persons, wa liao... like turtle. At last too much mod, break down on road one day, tow away & my friend change to CRX... so much better. Now he dives Celica SS2 My first car suzuki 3 cylinder also... the problem with 3 cylinder is that it vibrate a lot especially idling. 4 cylinder like Nissan March 1.0 is more quiet. Edited December 16, 2005 by Ncss Link to post Share on other sites More sharing options...
Route Clutched December 16, 2005 Share December 16, 2005 ic.. Link to post Share on other sites More sharing options...
Route Clutched December 16, 2005 Share December 16, 2005 at the price its selling now, alot of people are taking it as a point a to b car. ↡ Advertisement Link to post Share on other sites More sharing options...
Daihatsu admit tampering with safety tests for 30 years
Daihatsu Owners
Daihatsu Owners
Daihatsu Charade with Le Mans livery?
[Official] 2020 Toyota Raize / Daihatsu Rocky / Perodua Ativa / Subaru Rex
Daihatsu Extol
Daihatsu Extol
Daihatsu Materia/Toyota bB
Daihatsu Unveils Adorable, Quirky Custom Cars For 2021 Tokyo Auto Salon
Daihatsu Copen
Daihatsu Copen
