Yc86 Clutched February 15, 2006 Share February 15, 2006 what's the symptoms for a 'sick' radiator? maybe something got stuck inside, obstructing the flow.. is there a water pressure gauge to tell if things are flowing well inside? i ask this cos my water temp gauge suddenly reads an excess of 100deg, even during cruising, it reads 92+ when it should be at 86. at traffic lights, the temp goes up to 110. suspect things not moving smoothly in the radiator this thing only happened today, right after i installed my oil temp/pressure gauge. i did not touch the coolatn or radiator at all.. initially i thought i didn't top up sufficient oil to cover the amount which had spilt out when i took out the oil filter. but after filling up, the problem still persists. could insufficient oil be the cause of the increased temp? also, the thermoswitch doesn't switch on at 98deg anymore, instead.. it switches on at over 100 only. how come the switch can change by itself.. ↡ Advertisement Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear February 15, 2006 Share February 15, 2006 It could just mean that ur thermostat is starting to spoil, if not get ur entire cooling system pressure checked... it also sounds like a possible leak somewhere... prolly too small for the naked eye coz the temp increase isn't that large. Link to post Share on other sites More sharing options...
Dwoon 1st Gear February 16, 2006 Share February 16, 2006 Bro, you DIY the oil temp & pressure gauges ah? Link to post Share on other sites More sharing options...
Yc86 Clutched February 16, 2006 Author Share February 16, 2006 (edited) oh, any shop can check the cooling system pressure? thinking of going to bt merah to check later, but all are those normal workshops... see have time or not there is a slow leak though, have to top up coolant every 2 weeks... strangely, the higher operating temp seem to give slightly more power at night.. maybe imagining things ba Edited February 16, 2006 by Yc86 Link to post Share on other sites More sharing options...
Yc86 Clutched February 16, 2006 Author Share February 16, 2006 yupz... kinda scary/risky and very messy, but fun~ Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 16, 2006 Share February 16, 2006 (edited) The coolant high pressure steam may have managed to get into to combustion chamber and in a way "compact the fuel" Go to any Shell Autoserve they should have the radiator pressure tester to carry out the check. Edited February 16, 2006 by Yeobh Link to post Share on other sites More sharing options...
Yc86 Clutched February 16, 2006 Author Share February 16, 2006 oki thanks! should be free right..? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear February 16, 2006 Share February 16, 2006 since yeoh has told u where to get it done... all i can say is ur car feels more powerful as our engines run better hotter... only prob is metal fatigue Link to post Share on other sites More sharing options...
Yc86 Clutched February 16, 2006 Author Share February 16, 2006 yup... feels slightly more powerful, but quite heartpain to see the gauge in the red zone what's the max and peak water temp a stock engine can sustain? 120deg? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear February 17, 2006 Share February 17, 2006 The engine can take much higher temps than that but... the headgasket usually can't coz the different expansion rates of the headgasket, block and head tend to warp or crack it thus theres no seal between the head and block. esp vital when theres a cast iron block and alloy head as most cars are. If you are one of the luck few who's car comes with alloy head, block and headgasket, it can take higher temps than the cast iron alloy combo. ↡ Advertisement Link to post Share on other sites More sharing options...
Radiator Cap
Radiator Cap
Radiator slight crack
Coolant overflowing from expansion tank
How useful is higher pressure radiator cap?
Radiator tank leaks
Radiator tank leaks
Plastic weld
Plastic weld
How to protect your radiator from debris and damages
Radiator change
Radiator change
