Problems with Octavia
Fortress
Kindly comment and stick to the topic. Thanks.
My goodness, was a little upset to understand the build quality.
Got this from the website.
http://www.honestjohn.co.uk/index.php?url=...bycar/index.htm
Recall-
2000: LXi models built May '98 to Jan '99: incorrect ABS servo fitted could lead to brakes locking up. 25/6/2001: Fuel tank may leak. Check for leaks and replace tank where necessary. 2001: On Octavia 4x4s built up to March 2000, the bottom rear hub carrier ball joint can corrode and seize, leading to the lower suspension arms snapping at the hub ends. 10/5/2002: 2,995 Octavias recalled because electrical fault in ABS ECU could cause overheating, possibly even leading to fire damage. 31/3/2003: VINS TMB***1U*32665031 to TNB***1U*32675256 and TNB***1U*38665036 to TMB***1U*38667146 rar window wiper may loosen during high speed driving causing it to break off. Replace wiper arm and blace. 26/3/2003: VINS TMB***1U*X2148718 to TMB***1U*X22227663 and TMB***1UY2285279 to TMB***1UY2294866: Due to a manufacturing fault, tension cracks may occur on the vacuum pipe to the brake servo in the area of the pipe connections. If a vacuum pipe leaks the brake servo loses its function requiring a lot more force on the brake pedal to stop. Check vacuum pipes and replace if necessary.
