Mdvic Neutral Newbie June 27, 2006 Share June 27, 2006 Bro, Kermit, Cool man ...will listen to your adivse and sit on it........ If i Find it not good then i change.... ↡ Advertisement Link to post Share on other sites More sharing options...
Mdvic Neutral Newbie June 27, 2006 Share June 27, 2006 (edited) Hey Bro , Tks man....hahahaha kept me pondering the "C&G"......... Any specfic size for this brand or only one size? Ha !!! the tricky part,,, Q1.When i ask the shop to wire my speakers, do i ask him to change all the stock wire, right to the tip of the HU, or join it from the present stock wire? Q2.And for the Speaker and Tweeter wire, do I ask him to cut it very short so as the NEW Belden wire can join from there, like maybe leave about 10cm in length to join. Q3. Or do i ask him to cut off everything and solder right at the brackets of the Tweeter and Speakers??? can you pls help me in this area Tks..... Edited June 27, 2006 by Mdvic Link to post Share on other sites More sharing options...
Headshok 1st Gear June 27, 2006 Share June 27, 2006 belden, ask bro KW lah. when u go installer, just tell them change all ur cables to the one u have, including the one on ur tweet and spkr basically, they will charge u quite a bit, so make sure they do "option 3" of wat u just said, rip out everything and soder on the new cables Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie June 27, 2006 Share June 27, 2006 First off - whatever cables you use, it is only as good as the weakest link - so presumably you are changing to a cable which is better than your current set-up so therefore the logical choice is to "chop" at the source and replace everything w/ connections soldered where possible. Take care when soldering to the speaker terminals, else run the risk of burning the voice coil. So Q2 & 3 answered. As for your Q1 - presumably the speaker wire direct to your HU is running your rear speakers. Unless you are going to have very critical listeners sitting in your back seats I would suggest that you just leave your current set-up. I may have some spare runs of Belden RCAs if you are interested. But note that Belden, and other brands have a wide range of cables, so cannot generalize for any brand. FYI, Sarong also uses Belden cables in his set-up. As for Kermit, tsk tsk, advising people to not change cable then he himself go spend a BOMB on his RCA However, what Kermit says is correct in the sense that one should always concentrate on a good proper set-up first, should not just blow your budget just on cables alone although having resonably good cabling is important. As a guide I would always advise that 10 - 15% of the budget be allocated for cabling. For ICE other than just the HU, speakers, etc. do not forget that there are also many other factors that are also important, like: - power supply i.e. power cabling, distribution boxes, caps, fuses - sound-proofing, for the doors, panels, boot, firewall, etc. - installation and positioning especially of the speakers Etc. Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie June 28, 2006 Share June 28, 2006 Thks to all... Finally i got my setup Actively done up. Upgrade all my power cable to 4GW.. very thick til my rear having hard time to close it up. got to learn how to tune it up man...YEAH!!! Congrats bro! Nice car and setup you have there Link to post Share on other sites More sharing options...
Don_pica Neutral Newbie June 28, 2006 Author Share June 28, 2006 Hihi... of course i remember you... driving a red sport car...you convert to active too??? audison is good...depending on which series you talking about... Link to post Share on other sites More sharing options...
Don_pica Neutral Newbie June 28, 2006 Author Share June 28, 2006 thks thks...i love the setup of the lancer and civic that i saw yesterday....really superb...THUMBS UP....i still learning how to read/understand those ICE languages.... Link to post Share on other sites More sharing options...
Mdvic Neutral Newbie June 28, 2006 Share June 28, 2006 WAh!!!! Tks Bro, Another very Chiem explanation,,,me very ..Liao... Will come down tonight and chat with you regarding the cables, Ps: let me know which one is you ,, sorry i am bad in remembering ppl ..... MY only 2 pea brains....hahahahahahahah Link to post Share on other sites More sharing options...
Vicky Neutral Newbie June 28, 2006 Share June 28, 2006 Yo.. Your Left and right speaker balancing problem solve liao or not? Now pan hard left, RIght side still got sound? Link to post Share on other sites More sharing options...
Irxsve Neutral Newbie June 28, 2006 Share June 28, 2006 Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie June 28, 2006 Share June 28, 2006 I am the one with the Toyota Estima - I also just went full Active liao - another round of headaches Anyway, basically what I mean to say is that if want to change cables, change all, don't just change halfway. Else, the old cable being the "bottleneck" would still remain. Link to post Share on other sites More sharing options...
Darkness Neutral Newbie June 28, 2006 Share June 28, 2006 (edited) Hi there can help me with something...is this the correct way to wire up a 2 way active front with rear speakers powered using the HU??? Using an external x-over. Thanks all Edited June 28, 2006 by Darkness Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie June 28, 2006 Share June 28, 2006 CORRECT!!! Link to post Share on other sites More sharing options...
Darkness Neutral Newbie June 28, 2006 Share June 28, 2006 haha looks like my countless nites surfing MCF ICE section has not gone to waste after all hee hee okie 1 more ... if say i get another amp to power the rear then i use a new rca to go to the new amp. and then from the amp use speaker cable to the speakers rite? Rear Speakers ----(speaker cable x 2)----- AMP -------(RCA)---------- HU also if i wire up as shown in the above diagram will i still be able to: 1)control the sub vol from the HU 2)fade left and right 3)fade front and back thanks man sorry for being such a bore Link to post Share on other sites More sharing options...
Don_pica Neutral Newbie June 28, 2006 Author Share June 28, 2006 your active is exactly the same as me..hehehe... but i do not have any external xcross over Link to post Share on other sites More sharing options...
Darkness Neutral Newbie June 28, 2006 Share June 28, 2006 yeah cause my HU does not have a built in x-over oh well wat to do. hee hee. Link to post Share on other sites More sharing options...
Wankie Clutched June 28, 2006 Share June 28, 2006 fwah, another one gone actively active how's the performance so far? Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie June 28, 2006 Share June 28, 2006 OK lah - have to re-tune everything! Did a basic tune-up this morning, will fiddle with setting later - mid-bass a bit weak now ↡ Advertisement Link to post Share on other sites More sharing options...
Recommend under seat active sub
Questions on my active sub LPF crossover
Active vs Passive Setup
Active Brake Assist function limited
Yeah, finally a member of 2Fast2Furious too...
What to Do in an Active Shooter Situation
Keeping Your Sex Life Safe, Fun And Active
Mazda's retirement home for active seniors
