Kwongwing Neutral Newbie June 28, 2006 Share June 28, 2006 Yup if your HU has a second set of RCA outs for rear spkrs. Rear amp has to be turned down, or use faders to fade to front if necessary. I had to add an additional volume control else my rear spkrs were too loud. ↡ Advertisement Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie June 28, 2006 Share June 28, 2006 I am the one with the Toyota Estima - I also just went full Active liao - another round of headaches Welcome to the world of Active Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie June 28, 2006 Share June 28, 2006 >>fwah, another one gone actively active how's the performance so far? >> When your turn ? Link to post Share on other sites More sharing options...
Fasthonda Neutral Newbie June 28, 2006 Share June 28, 2006 congrats on going active... Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie June 28, 2006 Share June 28, 2006 Hi there can help me with something...is this the correct way to wire up a 2 way active front with rear speakers powered using the HU??? Using an external x-over. Thanks all hmm......why you need to have a extra Croxxover from HU to 4 Channel Amp ??? You hu cannot support Active ? Link to post Share on other sites More sharing options...
Wankie Clutched June 28, 2006 Share June 28, 2006 maybe when i change car..... hopefully at least 2 yrs later Link to post Share on other sites More sharing options...
Romanc88x Clutched June 28, 2006 Share June 28, 2006 Don and Darkness, Welcome to the Active pool. Link to post Share on other sites More sharing options...
Romanc88x Clutched June 28, 2006 Share June 28, 2006 What HU model are u using? As we can see you have an external x-over. Link to post Share on other sites More sharing options...
Don_pica Neutral Newbie June 28, 2006 Author Share June 28, 2006 yup... thks... Link to post Share on other sites More sharing options...
Darkness Neutral Newbie June 28, 2006 Share June 28, 2006 oh the sony cdx-gt800d i assumed that there is no active x-over but this evening i dropped by a pro-sony installer and he said no prob the hu can support active actually the spec is as follows...not sure how to read if got x-over or not... Features 52W x 4.5-MOSFET Output Power CD / MP3 / Atrac3 Plus / WMA Player with ID Tag Drive S Mechanism 8 Gradation FL Display / Spectrum Analyzer 24 Bit Integrated XDSP CD Changer Control / AUX Lite Technical Specifications Tuner: SSIR-EXA Synthesizer Tuner, FM-18 / MW-6 / LW-6, BTM (Best Tuning Memory) Amplifier: S-Mosfet / Power Output 52W x 4, DSP Integrated 24bit, Pre Out: 2X, 4V. High Voltage Pre-Out, Sub Out, Aux-In Lite, DSO 3D (Dynamic Soundstage Organizer), EQ13 / HDEQ, ITA (Intelligent Time Allignment), BBE-MP CD Deck: Drive-S HX, New X-DSP, CD-R / CD-RW Playback, ATRAC 3 Plus, MP3 and WMA Playback ================================================== TUNER SSIR-EXA Synthesizer Tuner FM18/MW6/LW6 Preset List BTM (Best Tuning Memory) RDS/EON CD DECK Drive-S HX Deck New X-DSP MP3 Playback with ID3Tag v.2.4 ATRAC3plus Playback WMA Playback with Tag Indication CD-R/RW Playback CD-Text Display/Scroll Repeat/Shuffle CHANGER CONTROL CD CONTROL - CD-Text Display/Scroll - Repeat/Shufle - List - MP3 CD Changer Connectable MD CONTROL - Title Display/Scroll - Repeat/Shuffle - List SOUND CONTROL AMPLIFIER - S-MOSFET Output Power: 52W x 4 - DSP integrated 24bit - Audio Capacitor - Pre Out x 2 - 4V High Voltage Pre Out - Sub Out - Aux-In Lite - DSO 3D - EQ13 (13-Band Equalizer/7 Modes/DSP) - Intelligent Time Alignment - Loudness - High Pass Filter - Low Pass Filter - BBE MP - Space producer Link to post Share on other sites More sharing options...
Darkness Neutral Newbie June 28, 2006 Share June 28, 2006 Yup if your HU has a second set of RCA outs for rear spkrs. Rear amp has to be turned down, or use faders to fade to front if necessary.I had to add an additional volume control else my rear spkrs were too loud. interesting...so i assume ur min value for rear fadder was still too loud so u had to add additional hardware?! Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie June 29, 2006 Share June 29, 2006 These specs give a clue that the HU is able to support active: "- High Pass Filter - Low Pass Filter " But actually have to look at the manual for more details. To answer yr question to me: Yup the amp for my rear was alraedy at minimum, fader pushed all the way to front spkrs - still too loud. Sigh ... Link to post Share on other sites More sharing options...
Headshok 1st Gear June 29, 2006 Share June 29, 2006 i don tink can go active leh.. my old 7700 got the high pass and low pass, when u on it, it will cut off at wither 78hz or 125hz.. cannot control Link to post Share on other sites More sharing options...
Mdvic Neutral Newbie June 30, 2006 Share June 30, 2006 Bro Vicky, Since Wednesday , no problem, bro Kermit tune for me and till now ok .........dont know why ................ If the problem solved then it time for fine tuning........... heheheheheh...... Link to post Share on other sites More sharing options...
Kermit 1st Gear June 30, 2006 Share June 30, 2006 Bro, Try to resist fondling your hu until it's time for fine tuning...ok? If not the aerlier efforts will go to waste. On Wed, I adjusted your amp gains...they were too high, which probably was the cause of your problem. But since it's ok now...enjoy it first. ;) Link to post Share on other sites More sharing options...
Mdvic Neutral Newbie June 30, 2006 Share June 30, 2006 Ok Bro, Tks a 1,000,000................but i find the Bass too low so i just adjust abit lah....can a not? Ha!!!! Wanted to buy you guys coffee the other night , but you all left liao....... All suddenly MIA......... Link to post Share on other sites More sharing options...
Kermit 1st Gear June 30, 2006 Share June 30, 2006 Ha...make sure you adjust only that...because whatever you adjust may affect other things...good luck. Kopi can anytime, no prob... Link to post Share on other sites More sharing options...
Darkness Neutral Newbie June 30, 2006 Share June 30, 2006 These specs give a clue that the HU is able to support active:"- High Pass Filter - Low Pass Filter " But actually have to look at the manual for more details. To answer yr question to me: Yup the amp for my rear was alraedy at minimum, fader pushed all the way to front spkrs - still too loud. Sigh ... thanks man... i think headshok is correct i asked the salesman who sold me the HU he also not sure but said based on wat he knows need external x-over to run active. Oh btw decided not to get the 800. Got the 700 instead...all the same except no motorised face plate. the saleman claims the gear rather easy to spoil if handle a bit rough so rather not take the risk Hee hee...next job to hook up my HU and see wat it can do ↡ Advertisement Link to post Share on other sites More sharing options...
Recommend under seat active sub
Questions on my active sub LPF crossover
Active vs Passive Setup
Active Brake Assist function limited
Yeah, finally a member of 2Fast2Furious too...
What to Do in an Active Shooter Situation
Keeping Your Sex Life Safe, Fun And Active
Mazda's retirement home for active seniors
