Using KP600 B&D Polisher
Icarus
I stay in HDB... and want to use my KP600.. realized the plug at my MSCP is this type :
My 3 pin plug can't fit into this socket as the socket is somehow bigger. Anyone knows if there are any convertors we can use? If cannot, then where can we polish the car besides going to private housing? [dizzy][sweatdrop][sweatdrop][sweatdrop]
That's a 15amp socket.
Maybe you can get this to convert the plug head. But I think if you plug in your 13amp socket into this, you may blow your 13amp. Anyone from the EEE can confirm?
Edited by Djcoolmax
indeed. i thought i read somewhere that thou should never steal from this garment.
the 15a socket with right adapter should power the device. however, like it was said, if there is a earth leak and short, the breaker maynot trip correctly or fuse will not blow which will result in device damage.
if i recalled their design correctly, there is a main breaker somewhere in this kinda public power supply, u need to switch it on first. otherwise there may not be electricity supply. anyway, pls check live with testpen before use.
good luck.
Edited by Dermocyma
[shakehead] Becareful.......Dun Kanna Caught By HDB/TC Staff..........
Illegal Use Of Electricity............ [idea]
Edited by Ccssgm
Wouldn't blow same voltage. Be careful KP600 no earth [sly]
