Jonbummer Neutral Newbie March 19, 2007 Share March 19, 2007 ok noted... guess i might have to give u a buzz soon for FP60 as for the other offer, it's more than interesting and will keep that in mind! ↡ Advertisement Link to post Share on other sites More sharing options...
Gjrforce Neutral Newbie March 26, 2007 Share March 26, 2007 how much and where to get the FP60? Link to post Share on other sites More sharing options...
Geogeo Neutral Newbie March 27, 2007 Share March 27, 2007 My 2nd tank of RON92 + FP60 give me about 13.5km/l with 30-40% of highway. Low end feels smooth during gear change. About to go filling up my 3rd tank, hopefully can get similar FC. Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie March 29, 2007 Share March 29, 2007 did u get your reply? else i can PM the contacts. cheers Link to post Share on other sites More sharing options...
Saaber Neutral Newbie March 29, 2007 Share March 29, 2007 yes, I have PM him... Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie March 29, 2007 Share March 29, 2007 oh goody.. i'm sure there's another satisfied driver! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie March 29, 2007 Share March 29, 2007 yes, good stuff must share... Link to post Share on other sites More sharing options...
Gjrforce Neutral Newbie March 30, 2007 Share March 30, 2007 ok, i buy it after my UOA test..should be a few week later. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie March 31, 2007 Share March 31, 2007 okay Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 4, 2007 Share April 4, 2007 any more new reviews.. Link to post Share on other sites More sharing options...
Hondalalala Neutral Newbie April 4, 2007 Share April 4, 2007 wat is FP60 asctually? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 4, 2007 Share April 4, 2007 It is a product from Lubecontrol, www.lubecontrol.com There is a an article on it in onemotoring, http://www.onemotoring.com.sg/publish/onemotoring/en/motoring_buzz/motoring_accessories/additives.html LubeControl 20 (LC20) We consume Vitamins and Anti-oxidants for our body to combat the effects of aging. How about our Engine Oil, the lifeblood for our car engine? Introducing Lube Control (LC20), Anti-oxidant for Engine Oil. LC20 is a special blend of chemicals that is designed to clean and protect your engines oil, power steering, and automatic transmission systems. This product will also break down and dissolve carbon deposits that can be harmful to your engine and it will penetrate into even the smallest places in your engine to clean and lubricate. LC20 levels the TBN (Total Base Number), reduces oxidation, provides an extra measure of lubricity, provides extra rust control, and will literally melt (soften and emulsify) carbonaceous deposits. It then places these carbonaceous deposits into the oil solution. LC20 keeps your oil in good condition and reduces oxidation so well that oil change intervals can be extended. LC20 can also be used in automotive and small engines to clean carbon deposits and keep rings and cylinders from rusting during storage. 2-cycle and 4-cycle engines that have stuck rings can be unstuck with LC20. LC20 works with all forms of motor oils, including synthetic, and has a variety of uses such as end of season storage, removing carbon and varnish, and pre-conditioning the rings before startup. This product will also enhance hydraulic systems, as proven in a report preformed by Dyson?s Analysis (See Report) New Recommended Dosage for Singapore 2 Oz per quart initial. 3 Oz topup every 3500KM and keeping to normal oil change interval Check oil level. Do not overfill crankcase FuelPower 60 (FP60) A fuel system cleaner, a fuel injector cleaner, a fuel treatment, a fuel pump lube, it removes water from the fuel tank, it removes carbon, protects against rust and best of all magically improves combustion efficiency. Works with both petrol and diesel vehicles. FP60 is added to fuel (gas or diesel) to clean injectors and the fuel delivery system. FP60 increases combustion efficiency, lubricates fuel pumps and injectors, cleans the fuel system, and potentially increases mileage. It scavenges water and moisture from the fuel system as well so the resulting mix can be burned in the combustion chamber. Combustion chambers can be cleaned using FP60. FP60 is special blend of chemicals designed to clean your vehicle?s fuel system and increase the potential energy in the fuel mixture. This in turn will potentially increase fuel mileage and lengthen vehicle-running time. This product will not only clean but protect a vehicle?s fuel system by leaving a thin protective coat of oil over vital fuel system parts including fuel pump, gas tank and fuel injectors. FP60 also acts as a fuel stabilizer by dissolving carbon deposits and lowering the fuel mixture freezing points in both gas and diesel fuels. This product has also been proven to decrease both carbon monoxide and nitrous oxide emissions up to 30% which will reduce pollution. Recommended Dosage - 1 Oz (~30ml) treats 5 Gallon ( 20 litres) of fuel Link to post Share on other sites More sharing options...
Windwaver Turbocharged April 7, 2007 Share April 7, 2007 My 2nd tank of RON92 + FP60 give me about 13.5km/l with 30-40% of highway. Low end feels smooth during gear change. About to go filling up my 3rd tank, hopefully can get similar FC. Where you buy the FP60? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 7, 2007 Share April 7, 2007 you got pm... Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 12, 2007 Share April 12, 2007 upzz for more reviewsss Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie April 12, 2007 Share April 12, 2007 bro... can pm me too? price and place for both items.... reach 100k mileage already... think i need that kind of tonic for my car.... cheers Link to post Share on other sites More sharing options...
Saaber Neutral Newbie April 12, 2007 Share April 12, 2007 you got PM Link to post Share on other sites More sharing options...
Eng01170 Neutral Newbie April 14, 2007 Share April 14, 2007 I want the FP3000. ↡ Advertisement Link to post Share on other sites More sharing options...
How to feedback on hospital service?
Seen the new look on Sgcarmart's Used Car pages? Love it or hate it? We want to hear from you!
Feedback
Feedback
Anyone have invested in SSB?
Feedback on hazard
Feedback on hazard
Cannot post an Ad
Cannot post an Ad
Any feedback on castlewoodgroup?
VW Tiguan 2011-2012 feedback
