Imamiah Clutched March 29, 2007 Share March 29, 2007 bros, my car kanna some road tar stains, i used to have a lotion fr Waxco (buy fr NTUC Fairprice) that can be used to remove those tough stains. but used finished liao, cant find anymore. any bro noes where to buy similiar stuff??? ↡ Advertisement Link to post Share on other sites More sharing options...
Mubarakrashid Neutral Newbie March 29, 2007 Share March 29, 2007 Autoglym's Tar Remover is the answer.. Link to post Share on other sites More sharing options...
Imamiah Clutched March 31, 2007 Author Share March 31, 2007 thanks bro. i suppose, can find at hardware shops? how abt careefour? Link to post Share on other sites More sharing options...
Mubarakrashid Neutral Newbie March 31, 2007 Share March 31, 2007 can easily find in lot of stores.. carrefour, giant, ntuc, home-fix diy, autobacs etc.. and its quite multi-purpose too.. but as long as u dont apply it to leather.. Link to post Share on other sites More sharing options...
Route88 2nd Gear March 31, 2007 Share March 31, 2007 Road tar is enemy to white car,those small dot dot road tar is diffult and time consuming to remove. Maybe can try cleaner wax instead. Link to post Share on other sites More sharing options...
Number19 Neutral Newbie April 2, 2007 Share April 2, 2007 If you wish to buy back the same thing, I'm quite certain I saw the Waxco tar remover at Carrefour @ Plaza Sing. At least 4 or 5 small bottles in stock, comes with a small sponge. Meguiar's #21 is also retailing there, but the price is rather expensive @ $28 Link to post Share on other sites More sharing options...
Carlovz Clutched April 3, 2007 Share April 3, 2007 i tried the Autoglym's Tar Remover but can't seems to remove the road tar on my ride's side skirt lei..... feel like respraying the side skirt..... Link to post Share on other sites More sharing options...
User12343 Clutched April 3, 2007 Share April 3, 2007 try wd40. Link to post Share on other sites More sharing options...
Decksurgeon Neutral Newbie April 3, 2007 Share April 3, 2007 soak the aotuglym tar remover on a fingernail sized piece of tissue paper. stick that soaked piece over the tar spot. wait a while. let the tar remover saturate the spot. then see if you can remove it. if that does not work. STP carb cleaner. not exactly the type of thing you want to use on bodywork. but that removes all muck! quickly wash and polish the area after to protect the paint. if both dont work.....maybe you dont have tar spots? maybe paint spots? Link to post Share on other sites More sharing options...
Kaka23 3rd Gear April 3, 2007 Share April 3, 2007 Can claybaring remove those Tar Sports? Link to post Share on other sites More sharing options...
Carlovz Clutched April 3, 2007 Share April 3, 2007 thanks bro.....will give your method a try.... Link to post Share on other sites More sharing options...
Carlovz Clutched April 3, 2007 Share April 3, 2007 wd40..? Can meh? Tot that is for metal surface... Link to post Share on other sites More sharing options...
Adawang 1st Gear April 3, 2007 Share April 3, 2007 tar is oil based, wd 40 can dissolve it, so can kerosene Link to post Share on other sites More sharing options...
User12343 Clutched April 3, 2007 Share April 3, 2007 no problem, wd40 is cheap and good. spray on tissue and wipe on the stains, following by using another clean tisu and clean off the oil film. Link to post Share on other sites More sharing options...
Carlovz Clutched April 3, 2007 Share April 3, 2007 oh ok.....thanks bro.. Link to post Share on other sites More sharing options...
Number19 Neutral Newbie April 3, 2007 Share April 3, 2007 Definitely~! Link to post Share on other sites More sharing options...
Ngaiky83 Clutched April 3, 2007 Share April 3, 2007 My friend tried on his car & it works... but I suggest better not use tissue unless u wan some scratch marks.. Try spraying on the tar direct & then use MF cloth to wipe off, use water to rinse off in case there's some of the WD40 left on the car body. Link to post Share on other sites More sharing options...
Mikeyeo Clutched April 3, 2007 Share April 3, 2007 WD40 can remove those tar on your car. However, if your car paintwork is treated with Syetem-6 by Tuff-Kote, they come with a bottle of Stain Remover. The latter will remove even dry bird dropping without damaging your paintwork. I always put a bottle of the above Stain Remover in each of my cars as I do not know when I would need them. ↡ Advertisement Link to post Share on other sites More sharing options...
Reckless Cyclist
Reckless Cyclist
What is this road at buangkok?
