Cheap Workshop in Malaysia...
Gylgyl
[sweatdrop] Hi guys! To save the money in our pocket, cheap workshop is another option we can get...
i went to Malaysia JB today... lackey around for workshop to change my suspension. They qoute me RM$80 ( Labour charges ) for all fours! and RM$20-30 ( Labour charges )to change my motor oil include one oil filter only... ( have to bring own oil).
The address is :
Century & Batt service centre
Lot 2, Jalan Harimau, century Garden
80250 Johor bahru, Johor Darul Takzim
[gossip]
Hi Gylgyl,
Thanx for the info. nod.gif Do you also have the tel number and/or the contact person there as well ?
yes tel no is 06 07-3316385
Lee Kok Hui..
they do wheel alignment also ... 4 wheel alignment plus 4 wheel rotation is RM$50....
i do RM$45 only. the place gyl mentioned... coz he brought me there.
4 wheel balancing + alignment.
also help u check if your rim is damange.... in my case is. ... gonna change at least 2 rims....
I guess it depends on the package involved...
Done my alignment for RM65 which includes rotation, service brake..
Best is to bring your own oil filter too...
Mine: Own oil, Own filter ($6). Labour for changing = RM10.
The workshop i go to also called: Century but different one.
Century Auto Express & Trading
No.25E, Ground Floor, Jalan Dato Abdullah Tahir, 80300, Johor Bahru.
Tel:
07-3315813
07-3322018
Look for Ah Yeow, just mention Subaru Kelvin.
Although some workshop may charge cheaply for their labour, but all they do is just change your engine oil and filter. They don't check the rest of the things, such as the condition of your brakes, timing belt, etc. This goes the same for most workshops in Singapore too.
In the agent workshop, thought they may be more expensive, but they have to follow a set of servicing procedures given by the car manufacturer. So the car has a higher chance of being check thoroughly.
My question is, by just changing engine oil and filter, is it consider enough for normal servicing? Or should more be done at each servicing interval.
ya...u rite.u have to know the mechanic there or someone introduce u then its quite a bargain.i always go to my mechanic for normal servicing or change parts.
eg:belting here about $160(parts only),JB cost M$165 plus labour.ive changed the belt for almost a yr n no problem with the belting.so,the choice is urs.also i changed my engine oil there n cost me M$68 for Pennzoil semi-synthetic,oil filter and coolant [thumbsup] .if anyone spot a car with a Pennzoil sticker on the right rear,hey its me. [nod][nod]
i get it local from KYB distributor! ... KYB G-Excel ! All four is S$260...u want the address??? PM me i will reply to u back..
Nowadays.. most engine are using Timing Chain. Therefore, you can nothing about it.
If you are really into kiasee.
1. Lubricate Pully and Belt (use Belt dressing and NOT WB40)
2. Do thorttle body cleanign every 50,000Km
3. Tighten grounding points.
4. Clean engine (like mine so clean [laugh] ), getting away the grim.
5. Touch up under-carriage
6. Rubberise Wheel Arches.
7. Do Contact cleaning for ignition coils and electrical parts.
8. Change spark plug or clean spark plug every 20,000KM
9. Change coolent every 50,000KM
10. Change clutch oil, power sterring, aTF Fluid every 50,000km
How much for the labour charges if changing gear oil? [:p]
