Radiator cap
Hkfung
stock comes with 1:1 pressure rating...just wondering the benefit when change to 1:2 or 1:3 pressure rating. radiator pipe pressure will increase which reduces the life-span. does it helps to cool down the engine when SRI & exhaust is done up? or rather, when it is adviceabe to change to a higher rating? [gossip]
got, french made loh
you got time go autobacs walk walk and you see many many different caps
Do not anyhow buy radiator cap for your car. If you car do not have a performance cap made for it, it will cause your coolent to link.
Check out the part number compatibility first before you fix. Unless you have a pressure valve kit which is meant for turbo cars, most performance cap do not have for stock cars.
If you are driving Honda, check out with Mugan kits..
But of course...hehe..it's like putting an Intercooler in an unmodded N.A engine..
Anyone tried this yet,,, [:p][shocked]
Edited by Super4
AND if i'm driving a Nissan...only compatible for NISMO??
AND Toyota.....TRD???
AND Mitsu cars...uses MMC/RallyArt??..
So we can't anyhow whack the radiator cap izzit?...For instance...Use NISMO radiator cap on Toyota or Mitsu...??
Is there an aftermarket kind of performance radiator cap that don't require the same manufacturing company as with ur car make?... [crazy]
Example:
TRD Radiator Cap has its model make part to the engine model.. e.g. NZE~.
Check part number lar.
hmm...i thought cap are universal size and only the pressure rating is diff... [confused]
Caps are not universal size.. A Hyndai Excel cap won't fit my rolla.
My collegue went to get Sparco cap.. after 2 days, he found his radiator coolant leaking in his CRX.
hmm..just wanna find out more why the leak...yr fren use 1.3bar? i think the service manual will state the max pressure the radiator can with-stand...if within this, i guess should be ok [:/] *i hope*
