Shevchenko Neutral Newbie May 10, 2003 Share May 10, 2003 my car is due for 15k servicing very soon. 15k need to do tyre rotation? or wheel alignmenet? any special things need to do? any places to reccommend to go for servicing? Shell gd? wat abt Motogard? (saw from WheelsAsia mag) thnx! ↡ Advertisement Link to post Share on other sites More sharing options...
Fulcrum Clutched May 10, 2003 Share May 10, 2003 what car are u driving? I believe it is best u service at the authorised dealer u bought the car from. Or are u driving a PI? Link to post Share on other sites More sharing options...
Shevchenko Neutral Newbie May 10, 2003 Author Share May 10, 2003 mit lancer C&C very ex Link to post Share on other sites More sharing options...
Fulcrum Clutched May 10, 2003 Share May 10, 2003 (edited) Hi, Think this list of servicing chores for around 15k is suitable for u: Parts and Material Replacement 1) Change Engine Oil 2) Change Oil Filter 3) Change Drain Plug Gasket 4) Change Contact Breaker Engine Tuning 1) Check and Top-up Engine Coolant 2) Check and Adjust Idle Speed/ Fast Idle Speed/ Mixtures 3) Check Drive Belt/ V-belt Condition and Adjust if necessary 4) Check Cooling System Hoses & Connections 5) Check and Clean Air Filter 6) Check Air Conditioning Refrigerant 7) Check Horn Operation 8) Check All Power Windows Operation 9) Check Central Locking Operation 10) Check Electric Mirrors Operation 11) Check Air Conditioning Blower Condition Chassis 1) Check & Tighten Bolts & Nuts on Undercarriage 2) Check Tyres & Inflation Pressure 3) Check & Lubricate Door Hinges 4) Check and Top-up Power Steering Fluids 5) Check and Top-up Transmission Fluid 6) Check Steering Wheel, Linkages & Gear Box 7) Check Wheel Bearings' Condition Electrical 1) Check and Top-up Battery Water 2) Check All Vehicle Lightings 3) Check & Top-up Windshield Washer Water 4) Check Windshield Wiper & Washer Nozzle 5) Check Battery Condition Clutch and Brakes 1) Check and Adjust Clutch Pedal 2) Check and Adjust Parking Brakes 3) Check and Top-up Clutch & Brake Fluids 4) Check Brake Line Pipes & Hoses 5) Check and Clean Brake Linings & Drums 6) Check and Clean Brake Pads & Discs Try going to the prescribed mitsubishi workshops at AAS.com.sg and see their prices. [nod] Edited May 10, 2003 by Fulcrum Link to post Share on other sites More sharing options...
Car_guru Neutral Newbie May 12, 2003 Share May 12, 2003 You can try Avioncar at AMK Autopoint... some guys in SLCC patronise this mech... ↡ Advertisement Link to post Share on other sites More sharing options...
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Workshops with engine oil flushing machine
Volvo Servicing
Volvo Servicing
