Destiny03 Clutched July 13, 2007 Author Share July 13, 2007 wah you sound so commited to the product haha anyway congrats ↡ Advertisement Link to post Share on other sites More sharing options...
Byond 1st Gear July 13, 2007 Share July 13, 2007 best to get a 1st hand new one... cos its targeted life span is about 3 yrs to 5 yrs. if one set (eg. D1specs ver 2 costs $188), basically, you are paying $5.30 per month for 3 yrs...36 months..if it exceeds the 3 yrs period... Viola.... you have already kio tio liao lol.. ahhaa Get those that are made in japan... more recommended than those made in taiwan...etc..etc.. cos more reliable..pay abit more..for that pc of mind. Link to post Share on other sites More sharing options...
Destiny03 Clutched July 13, 2007 Author Share July 13, 2007 wat you say is very true. hehehe but then hor the installation would not void the warranty ? becos i see that you have to uninstall the engine nuts near the to mount the ground wire. Link to post Share on other sites More sharing options...
Byond 1st Gear July 13, 2007 Share July 13, 2007 by right..it should not void ur warranty. My agent did not void my warranty as it does not includes cutting of fuel line etc..etc.. its just an add on device. HOWEVER, its best to double check with ur agent lst lah..to be on the safe side. this is what i can advise u. Link to post Share on other sites More sharing options...
Destiny03 Clutched July 13, 2007 Author Share July 13, 2007 did you get your ride from borneo? Link to post Share on other sites More sharing options...
Haneda Neutral Newbie July 13, 2007 Share July 13, 2007 Think VS is all about the same...but i think there is some difference after installation as the FC inproves slightly, and also when the aircon cuts in the VS helps to stabilise the supply. Link to post Share on other sites More sharing options...
Robin 4th Gear July 13, 2007 Share July 13, 2007 i'm using Pivot raizin + grounding for close to 4 yrs ... its not bad. idling seems more stable, got some improvement in fC Link to post Share on other sites More sharing options...
Uplinkhack 1st Gear July 13, 2007 Share July 13, 2007 sorry what's the grounding for ah? in case lightning strike antenna then won't get electric shock ah? Link to post Share on other sites More sharing options...
Destiny03 Clutched July 13, 2007 Author Share July 13, 2007 good question Link to post Share on other sites More sharing options...
Byond 1st Gear July 13, 2007 Share July 13, 2007 I drive a Mazda.... Link to post Share on other sites More sharing options...
Byond 1st Gear July 13, 2007 Share July 13, 2007 haha then u remove ur attenna lol...and leave a small metal chain to the ground via ur car.. then its better Link to post Share on other sites More sharing options...
Destiny03 Clutched July 13, 2007 Author Share July 13, 2007 wow seem like you are have background working in a electronics manufacturing working environment just a guess hehe Link to post Share on other sites More sharing options...
Byond 1st Gear July 13, 2007 Share July 13, 2007 if change battery...also need to unlock the nuts mah.. then change.. then if like that...void warranty? mazda motor never volt my warranty on my battery just becos of the vs installation i dont think BM will void..but better to check lah but as usual...no one would wanna commit such a thing... haha Link to post Share on other sites More sharing options...
Byond 1st Gear July 13, 2007 Share July 13, 2007 http://www.mycarforum.com/classifieds/classifieds.pl?id=7045 Can consider this if u want 2nd hand... up to u.. :) Me in sales line... last time work in manufacturing anyway...i love to talk c0c* 1. haha Link to post Share on other sites More sharing options...
Destiny03 Clutched July 13, 2007 Author Share July 13, 2007 hahha expected you to have experience in manufacturing when i hear about you having the metal chain dragging on the ground haha Link to post Share on other sites More sharing options...
Destiny03 Clutched July 16, 2007 Author Share July 16, 2007 ok i am offically a pivot user now wahahha but i am monitoring it now. I am seeking for the grounding kit to go along with my car. whahhaa Link to post Share on other sites More sharing options...
Hreticfreakerz Neutral Newbie July 17, 2007 Share July 17, 2007 [reply]Hi all, I am considering of getting a voltage stabiliser for my vios. but i am not sure with one to choose. so far i have several choice D1 Spec VS + 3pt ground = $125 Pmax + 8 point grounding = $150 Pivot raizin + no ground = $80 +ground topup 35 ezstab = $188 i need the guru here to give some comments on the products and help. Thanks Its not much about the brand but the thickness of the grounding cable to see the difference thinner cable not much to see diff,improves ur low end torque..Fc & pick up also improve..max u can go in grounding cable would be 20pts..minimum 5pts but 10pts is fair enough... Link to post Share on other sites More sharing options...
Destiny03 Clutched July 18, 2007 Author Share July 18, 2007 wow thanks =) i am thinking of getting 8AWG cables. but on the market seldom see thick cable unless DIY. You have recommendation? ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommendation for good facilities Health Centre/ Spa
Recommendation for private driving instructor near BBDC
Recommendation for Spectacles
Recommendation for gynaecologist
Any recommendation for Malaysia Data Plan
Audio Shop Recommendation
Any recommendation for ear digging?
