Subarugt Neutral Newbie July 30, 2007 Share July 30, 2007 (edited) any bros here know how to use.. i bought 1 but can seen to get the best result when using compound Edited July 30, 2007 by Subarugt ↡ Advertisement Link to post Share on other sites More sharing options...
Maddriver 4th Gear July 31, 2007 Share July 31, 2007 Are you using ryobi buffer to remove swirls or water marks? What polishing pads are using with 3M compound? Link to post Share on other sites More sharing options...
Garlic 1st Gear July 31, 2007 Share July 31, 2007 What product and pad are you using? Compound is very aggressive and you will need to follow up with less aggressive polishes and pads to restore shine. Link to post Share on other sites More sharing options...
Subarugt Neutral Newbie August 1, 2007 Author Share August 1, 2007 remove swirl marks... am using compound maxi pads with the 3M Link to post Share on other sites More sharing options...
Subarugt Neutral Newbie August 1, 2007 Author Share August 1, 2007 i know bro... using maxi compound pads with 3m... after that with polish n sealent application Link to post Share on other sites More sharing options...
Garlic 1st Gear August 2, 2007 Share August 2, 2007 Have you tried removing them with the polish first? Its always good to start with the least abrasive combo. Did you buff until dry or let product haze before wiping off? Polish should not be buffed dry, stop when its almost clear and still wet. Did you mist the pad with QD or a little water prior to buffing? How much product did you use? Link to post Share on other sites More sharing options...
Subarugt Neutral Newbie August 3, 2007 Author Share August 3, 2007 wa bro... any tips to guide me? will u be at amk on sun? Link to post Share on other sites More sharing options...
Gorilla41 Neutral Newbie August 10, 2007 Share August 10, 2007 Hi guys i'm new in this forum so i was wondering what buffer should i get and which brand should i get for the polish to remove scratches and oxidation for my 2 year old no polish/wax/ or even washed car ↡ Advertisement Link to post Share on other sites More sharing options...
How are you using the SkillsFuture?
Using blower to dry car
CPU chip - What are you using? Intel or AMD?
56 Delightful Victorian Slang Terms You Should Be Using
Cordless power tool system - which one ?
Who Still using STP Oil Treatment?
Anyone using Blaupunkt BP-9.0A?
Using hose in mscp
Using hose in mscp
