Ruzhyo Clutched August 4, 2007 Share August 4, 2007 Sorry but I am not sure if this is the correct folder to post. I am looking for a good alarm system that does not cost an arm and leg. My car already comes with a smart key. Can I retro fit another alarm? Do I need to bring 2 remotes with me? Pls advice ↡ Advertisement Link to post Share on other sites More sharing options...
Ultramega 1st Gear August 5, 2007 Share August 5, 2007 depends on what functions you want. simple ones - can use back your key. multi-functional ones - may need to carry 2 remotes. Link to post Share on other sites More sharing options...
Ruzhyo Clutched August 5, 2007 Author Share August 5, 2007 1st of all, thank you for your fast reply. I have seen some alarm systems. I am interested in the ones that have sensors for glass breakage, vibrations, car being tow/jacked up, the alarm remote with the LCD that can show the status some distance away etc. Where can I find a wide range of alarm systems to choose from? Any good installer to recommand? Link to post Share on other sites More sharing options...
Bluemice 2nd Gear August 5, 2007 Share August 5, 2007 seems like u r aiming for a long range , 2-way remotes, with sensor array. try these, for a start. crimestopper viper magicar goggle for more details. oh, local sets dun come cheap. mice Link to post Share on other sites More sharing options...
Ruzhyo Clutched August 5, 2007 Author Share August 5, 2007 I looked them up, just not sure if need 2 remotes. Troublesome to carry 2 and not sure if it will screw up my smart key Link to post Share on other sites More sharing options...
Bluemice 2nd Gear August 7, 2007 Share August 7, 2007 i think if thats the case, it must be safer + wiser to stick to stock. mice Link to post Share on other sites More sharing options...
Erictan Neutral Newbie August 12, 2007 Share August 12, 2007 apologise for hijack your thread: any idea if camry 2.0 new model has problem with remote? i can't seem to make my remote sensitive enough. new battery changed also no use. only can lock door near the right hand wiper there... any one encounter same problem? Link to post Share on other sites More sharing options...
Bluemice 2nd Gear August 12, 2007 Share August 12, 2007 er... i think u replied to wrong pax liao. anyway, i tink there is a camry car club in SG do try them for mroe info n details. dun ask me wer i dunno. Else, hv u tried to make noise at the AD ? mice Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie August 12, 2007 Share August 12, 2007 Most stock remotes have relatively short range - but should have at least 2 to 3 metres range at the least. Yours seem a BIT on the TOO short side - if new car should check with your agent else if you have been using the remote for some time should try changing the battery. ↡ Advertisement Link to post Share on other sites More sharing options...
FT discrimination agst locals
Stop False Accusation
Aftermarket Alarm
Aftermarket Alarm
Aftermarket car alarm
NASA's Voyager 1 is sending mysterious data from beyond our solar system. Scientists are unsure what it means.
Alkaline water system
Comments on T3B system as a trading tool
Laundry Drying system - Pull-down/Push-up type
