Keith10w Neutral Newbie August 18, 2007 Share August 18, 2007 Just a few days ago my gauge start to react abnormally, previously when i floored the accelerator the needle will go to zero immediately, but now if i floored the accelerator it will just go to 15mg an wouldn't go further. what could be the problem ?? Pls Help !!! I am using pro sport stepper gauge ↡ Advertisement Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 18, 2007 Share August 18, 2007 Is it a mechanical or electrical gauge. If mechanical check that the hose isnt kinked. If electrical check the electrical connections (preferably test to see if the gauge is working properly). One ques though, does the car feel any different? Link to post Share on other sites More sharing options...
Keith10w Neutral Newbie August 18, 2007 Author Share August 18, 2007 Hi It is a mechanical gauge, properly have to send to workshop and check . car feels no diff. Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear August 18, 2007 Share August 18, 2007 before you do that check the vacuum hose running from the engine bay to the gauge. Sometimes it kinks in a way that it still allows air to pass through till a certain pressure then its sucked shut preventing the gauge from reading any lower. Its actually quite common with cheap hoses. Link to post Share on other sites More sharing options...
Keith10w Neutral Newbie August 18, 2007 Author Share August 18, 2007 Thanks bro I will do a check Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie August 20, 2007 Share August 20, 2007 i encountered before, which is the vacuum hose bended. Link to post Share on other sites More sharing options...
Keith10w Neutral Newbie August 20, 2007 Author Share August 20, 2007 suspecting that also....but dumb me....i dunno where is the hose... ↡ Advertisement Link to post Share on other sites More sharing options...
Home repair advice needed
Computer advice needed
Citroen C4 1.2 Sensor & Display
