Tigershark1976 Turbocharged August 19, 2007 Share August 19, 2007 Hi all, Recently got myself a rodek AEX 2/3 way active crossover. I'm gg to install it in Mal but need to buy the necessary wire or RCA cable b4 gg there as the cable in Mal are extremely ex... In Active setup, the signal from Head (mine is Pioneer 6850) unit is send to the Crossover, from the crossover, the signal will be split into high/low/mid and then send to dedicated Amp/channel. From the amp, the amplified signal will then be send to the speaker directly. Am I correct??? please advise... my current setup is 2 channel Passive setup, I will get another mid speaker and add another Alpine 4 channel Amp to run the 3 channel Active setup, so does it means that I will need another 2 pair of RCA cable?? if both amp and crossover is going to be place at the front seats, is 3m cable enough? ↡ Advertisement Link to post Share on other sites More sharing options...
Dunno Neutral Newbie August 19, 2007 Share August 19, 2007 You only need 2m RCA from HU to front seat and 0.5m RCA from your Rodek crossover to your amp, assuming your Rodek is stacked with the amp. ↡ Advertisement Link to post Share on other sites More sharing options...
How to Setup Your Android Auto - video tutorial
Recommend under seat active sub
Business setup advice for slow economy
Questions on my active sub LPF crossover
Active vs Passive Setup
VERY SLOW internet connection
Active Brake Assist function limited
Urgent advise needed on Lowering Spring + stock Spring setup
