Emperor Clutched September 19, 2007 Share September 19, 2007 From your famous post, I assume you're driving an EG right?? Cause I drive an EG5. You're using MUGEN shocks on the front? If they are Mugen. Have it check. Think there might be some oil leak. I had that same problem quite recently.. turns out there was n oil leak. ↡ Advertisement Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 19, 2007 Share September 19, 2007 huh wat famous post u talking? btw ya i drive eg, but using tein superstreet, not mugen.. check before no leak no nothing.. so nothing can be done.. Link to post Share on other sites More sharing options...
Mcff_1980 Neutral Newbie September 19, 2007 Share September 19, 2007 by the way is your mugen shock hard? my tein ss i feel is still not hard enough for my liking, considering BC or Mugen Link to post Share on other sites More sharing options...
Emperor Clutched September 19, 2007 Share September 19, 2007 the mugen shocks are hard... but the springs are not to my likings. best is if you go for a full MUGEN coilovers. Mine are not. Just springs and shocks. But dont make it too hard. Especially the front. If its too hard on the front there's a tendancy to understeer. Link to post Share on other sites More sharing options...
Emperor Clutched September 19, 2007 Share September 19, 2007 if there's no leak, then its probable that its just friction of the springs and the shocks when you sit down. Shouldnt be a problem. Link to post Share on other sites More sharing options...
Gablax Neutral Newbie September 21, 2007 Share September 21, 2007 the rear shocks giving that sound is bcos of the gas working.... the reverse thingy i never hear b4... the brakes making noise its normal... ....................................... Link to post Share on other sites More sharing options...
Kyojin 1st Gear September 22, 2007 Author Share September 22, 2007 the reverse thingy happened from day 1. probably a bad bearing. i'm gonna pop open the calipers when i rotate the tyres. just to be sure the pads are alright. seems like the squeals are staying for much longer. used to be only light pressure, but now even hard pressure, the sound doesn't go away sometimes. ↡ Advertisement Link to post Share on other sites More sharing options...
Brake squeak every morning
Gearbox issues; and problems at VW Service Centre
Common Problems with Optra 5
Headlight problems with modern cars?
Squealing/Squeaking brakes
Anybody experience problems engaging gear for Fiat Punto?
Hybrid cars - any problems?
Power window problems
