Winq Neutral Newbie October 2, 2007 Share October 2, 2007 hi guys, i'm a real newbie in ICE. goin to get my new SSS soon.. so intend to get sound system change. need some advice from the experts here.. intend to get 4 x speakers 2 x tweeter 1 x 12'' sub woofer 1 x centre speaker 1 x 4 channel amp for speaker 1 x 2 channel amp for woofer n centre speaker i think this is all i need.. i dunno still can get wad.. my budget is ard 2.5 to 3k. is it enough? and wad brand will i get with my budget? thanks in advance.. ↡ Advertisement Link to post Share on other sites More sharing options...
Fresh Clutched October 2, 2007 Share October 2, 2007 wow... i thought u noobie? but u seem to know what needs to be changed even before you get ur new ride... Link to post Share on other sites More sharing options...
Headshok 1st Gear October 2, 2007 Share October 2, 2007 simple, get a good HU, ie P80 or 9887, ard $800, so that leaves u with 2.2k for ur other stuff get a decent 4 channel amp + monoblk for woofer. get one set of component spkrs for ur front plus a decent sub. and tada! drop by tmr's meetup lah if u have more questions lah. ditch the centre spkr. cheers! Link to post Share on other sites More sharing options...
Jhoo Neutral Newbie October 3, 2007 Share October 3, 2007 Hi My car came with a "made-in-china" DVD HU, roof top monitor and stock speakers. Spoke to a installer and convinced to upgarde, hence got myself a 4-ch amp, a set components, a set coxial, 2 ch amp and 10"sub. Realised that there are no sub preout on the HU and on EQ adjustment function. I initially tot of getting a addional new HU purely for quality CDs while retaining the DVD HU on the 2nd Din. The new HU will come with full tuning functions (TA, EQ) and the old HU fulfil my DVD needs. I'v econsidered a 2DIN DVD player but most didn't come with EQ function (needs external processor) Alternatively, the installer proposed a cheaper solution to add-on a "good" Preamp. (PPI as rec by installer). Preamp is PPI, HU is 9887 or 9965. If the preamp is almost 1/4 price of new HU, is it worth the investment? I feel that preamp setup is kindof "stone age" in ICE setup. Knowing that I will not go Active. What is a good option. Thanks. Preamp is PPI HU is 9887 or 9965. Link to post Share on other sites More sharing options...
Velocity73 Neutral Newbie October 3, 2007 Share October 3, 2007 Wow, my budget only $500 Link to post Share on other sites More sharing options...
Headshok 1st Gear October 3, 2007 Share October 3, 2007 lup a H701 on top of ur DVD HU, can liao.. OR if out of budget, get a another HU, wire it up to such that it is the main source player. most of the better HUs have an aux out. use this AUX out to aux INTO ur china made DVD player. so that when u wanna play DVD, press the aux button on ur HU, u can watch dvd liao.. aniway, 9965 is ex, so watch out. 9887 would fit u most. have fun! Cheers Link to post Share on other sites More sharing options...
Winq Neutral Newbie October 3, 2007 Author Share October 3, 2007 eh but my swift sport come with built in hu.. the SE told mi if i change the HU i cant control the button on my steering wheel.. plus the shape of the built in hu veri weird.. how ahr? Link to post Share on other sites More sharing options...
Headshok 1st Gear October 3, 2007 Share October 3, 2007 tell ur SE to suck my c*ck ( ur SE chio or not?) they do make the kits for the swift that enables u to fit in after market HUs. go and check out the PI swifts. all have this. its easily avaliable also, they also sell kits that allow u to interface ur steerin controls with ur aftermarket HU. depends how much u wanna pay lor.. but with ur budget( which is quite healthy), i think shouldnt be a problem lah.. its up to u lah! cheers! Link to post Share on other sites More sharing options...
Stitchohana Neutral Newbie October 3, 2007 Share October 3, 2007 apline 9887 can get around $650. Link to post Share on other sites More sharing options...
Low1209 Neutral Newbie October 3, 2007 Share October 3, 2007 i can get a RF amp at a very good price, but is an export set Link to post Share on other sites More sharing options...
Pencapchew Neutral Newbie October 6, 2007 Share October 6, 2007 simple, get a good HU, ie P80 or 9887, ard $800, so that leaves u with 2.2k for ur other stuff get a decent 4 channel amp + monoblk for woofer. get one set of component spkrs for ur front plus a decent sub. and tada! drop by tmr's meetup lah if u have more questions lah. ditch the centre spkr. cheers! Bro, just wondering. Is there a difference between a 2ch amp and a monoblock amp??? Or is a 2ch amp a monoblock amp??? Link to post Share on other sites More sharing options...
Slidingturtle Neutral Newbie October 6, 2007 Share October 6, 2007 chipping in... monoblock = single (mono) channel 2ch = 2 channels typically, peo use monoblocks to drive their subwoofers.. Link to post Share on other sites More sharing options...
Newkid 2nd Gear October 6, 2007 Share October 6, 2007 i cnnot help but compliment you for a superb respond "tell ur SE to suck my c*ck ( ur SE chio or not?)" Link to post Share on other sites More sharing options...
Pencapchew Neutral Newbie October 9, 2007 Share October 9, 2007 Thanks... but would there be a difference if you power your sub using a 2ch amp compared to a monoblock amp??? Link to post Share on other sites More sharing options...
Dunno Neutral Newbie October 9, 2007 Share October 9, 2007 (edited) First basic thing to understand. Subs are driven with only 1ch, ie, mono channel. Monoblocks are single channel and able to drive 2ohm or even 1ohm subs. Normal 2 ch amps can only drive 4 ohm subs, they are 2ohm stable at 2ch only, but not stable at 2 or 1 ohm when bridged into 1ch. Only very high end or expensive 2ch ones are 2ohm stable when bridged into 1 ch to drive subs. That's the main difference between a mono and a 2ch. Having said that, if your sub is a 4 ohm, there's no difference. Edited October 9, 2007 by Dunno Link to post Share on other sites More sharing options...
Boring Neutral Newbie October 9, 2007 Share October 9, 2007 You can change the HU and still have working controls on the steering wheel. I'm driving a swift, installed a aftermarket HU and still have working steering wheel controls. You can pop by the meetup, better to look and hear for yourself. Link to post Share on other sites More sharing options...
Onenightstd2 Neutral Newbie October 9, 2007 Share October 9, 2007 hi guys, i'm a real newbie in ICE. goin to get my new SSS soon.. so intend to get sound system change. need some advice from the experts here.. intend to get 4 x speakers 2 x tweeter 1 x 12'' sub woofer 1 x centre speaker 1 x 4 channel amp for speaker 1 x 2 channel amp for woofer n centre speaker i think this is all i need.. i dunno still can get wad.. my budget is ard 2.5 to 3k. is it enough? and wad brand will i get with my budget? thanks in advance.. watct out the weight of all these equipments may come to abt 30 kgs, yr FC may go up. ↡ Advertisement Link to post Share on other sites More sharing options...
Budget 2025 - February 2025.
Mitsubishi Space Star
BudgetMealGoWhere Portal
Sim Ann shares details of her budget meal after netizens slammed her in a previous Facebook post
SGD 300,000 budget for a used car... 740i or Panamera or ?
Budget 2021, 16th Feb 2021
