Czchome Neutral Newbie October 22, 2007 Share October 22, 2007 Is Alpine MRV-F345 Amp a good option? Budget around $500 Pls help Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Dunno Neutral Newbie October 22, 2007 Share October 22, 2007 What speakers are you intending to drive? Alpine amps are very decent amps. Link to post Share on other sites More sharing options...
Czchome Neutral Newbie October 23, 2007 Author Share October 23, 2007 Rockford P162s Components Link to post Share on other sites More sharing options...
Bobcatsysop Neutral Newbie October 23, 2007 Share October 23, 2007 Hi Bro, Here are the specs. Seems to be compatible. Alpine MRV-F345 4-Channel Class A/B Amplifier RMS Power Rating: * 75 watts x 4 chan. @ 4 ohms * 85 watts x 4 chan. @ 2 ohms Bridged: * 300 watts x 1 chan. @ 4 ohms Bridged(channels 3/4) * 75 watts x 1 chan. @ 4 ohms Bridged(channels 1/2) Variable 30-400 Hz low-pass digital filter, 600-8000 Hz high-pass digital filter, 12 or 24 dB/octave Rear channels have a subsonic filter at 15 Hz Signal-to-Noise Ratio 93 dB Specifications of Rockford P162s - 2-way front components Power Handling (RMS) - 60 watts Power Handling (Peak) - 120 watts Frequency Response - 70-22k hz Sensitivity - 88 db Link to post Share on other sites More sharing options...
Czchome Neutral Newbie October 23, 2007 Author Share October 23, 2007 any other Amp to recommend for the budget of $500? Thanks a lot Link to post Share on other sites More sharing options...
Bobcatsysop Neutral Newbie October 23, 2007 Share October 23, 2007 Hi bro, MRV series is the old alpine series.. The new ones are MRP.. for $500 is going to be very tight budget but can probably work excluding cables and fuses. Maybe you should consider the newer MRP series... Try Alpine MRP-F450 4/3/2 Channel Power Amplifier RMS Power (at 14.4V THD+N, 20Hz-20kHz) Per channel into 4 ohms: 70W x 4 (0.08% THD) Per channel into 2 ohms: 100W x 4 Brigded 4 ohms: 200W x 2 (0.3% THD) Perhaps you can come to meet us Wed ICE meetup at 456 Balestier Road. We will try to help you out. ↡ Advertisement Link to post Share on other sites More sharing options...
RAM/MicroSD issues
RAM/MicroSD issues
Advice on exhaust.
Advice on exhaust.
Car accident advice
Car accident advice
