Dptm Neutral Newbie May 20, 2002 Share May 20, 2002 Noticed the steering wheel vibrates when i apply on the brakes to come to a stop. It normally happens at the point when the car is coming to stop. Can this be due to warped brake discs or the wobbling of the wheels? Or uneven wear of the brake pads? Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 20, 2002 Share May 20, 2002 Most likely warped discs which will lead to uneven pads. Get the discs skimmed and see whether the problem goes away. Link to post Share on other sites More sharing options...
Luke721 Neutral Newbie May 20, 2002 Share May 20, 2002 Could also be due to the lining in your rims ... Run a check on your front tyres during your next servicing if the problem is not that serious ... Link to post Share on other sites More sharing options...
Dptm Neutral Newbie May 20, 2002 Author Share May 20, 2002 Thanks Turbobrick, will try that. BTW, any workshops to recommend? Link to post Share on other sites More sharing options...
Yongwd 1st Gear May 20, 2002 Share May 20, 2002 Do a simple test ... Drive at slow speed ~ 40km/h, gradually come to a stop. Feel the brake pedal, any small pulsation? If yes and steering vibrates, your rotor is warped. Get your mechanic to replace or skim the rotor. Replace a new set of brake pad at the same time. If thickness of rotor below spec, get a new replacement Noticed the steering wheel vibrates when i apply on the brakes to come to a stop.It normally happens at the point when the car is coming to stop. Can this be due to warped brake discs or the wobbling of the wheels? Or uneven wear of the brake pads? Thanks. Link to post Share on other sites More sharing options...
Dptm Neutral Newbie May 20, 2002 Author Share May 20, 2002 pardon my ignorance, what/where is the lining? Link to post Share on other sites More sharing options...
Dptm Neutral Newbie May 20, 2002 Author Share May 20, 2002 Thanks alot Shagmobil, will try the test! Read that u had alot of experiences/knowledges with toyota cars. I'm driving a corolla 96 manual (AE111), thinking of changing the spark plugs cable and the plugs. Will this bring about any significant improvements? Link to post Share on other sites More sharing options...
Yongwd 1st Gear May 20, 2002 Share May 20, 2002 if u are a high revver, changing to a colder range will perk performance slightly. Denso K16PRU-11 will be a good choice. Town driving and heavy start stop, use hotter range K20PRU-11 instead. nothing much can do with 4a engine. take care of the fuel filter, air filter and use good engine oil, the 4a unit will be good enuff Thanks alot Shagmobil, will try the test!Read that u had alot of experiences/knowledges with toyota cars. I'm driving a corolla 96 manual (AE111), thinking of changing the spark plugs cable and the plugs. Will this bring about any significant improvements? Link to post Share on other sites More sharing options...
Dptm Neutral Newbie May 20, 2002 Author Share May 20, 2002 does this plugs applies to the AE111 as well? for fuel filter, any recommendations or any brand will do? Link to post Share on other sites More sharing options...
Yongwd 1st Gear May 20, 2002 Share May 20, 2002 (edited) ae111 also on 4a-fe. applicable too fuel filter I replace myself (not ez coz threaded fuel line) with oem japan filter. OEM cost only ard 30% ($12) of original ($30) a little off topic, drop me a private mail if u got further questions. does this plugs applies to the AE111 as well?for fuel filter, any recommendations or any brand will do? Edited May 20, 2002 by Shagmobil Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 20, 2002 Share May 20, 2002 Try Ah Lin at Blk 29 Sin Ming Ind Est, #01-215. Tel 4563710 Link to post Share on other sites More sharing options...
Dptm Neutral Newbie May 20, 2002 Author Share May 20, 2002 thanks guys for the advice, really appreciate it. Link to post Share on other sites More sharing options...
Tookara Neutral Newbie May 20, 2002 Share May 20, 2002 think its your steering column bushings or something like that. Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 20, 2002 Share May 20, 2002 Hi! there, Tookara, Are you from Delphi, asking for a/c w/shop? Rgds Paul Yong Link to post Share on other sites More sharing options...
Guyver 1st Gear May 20, 2002 Share May 20, 2002 if u are a high revver, changing to a colder range will perk performance slightly. Denso K16PRU-11 will be a good choice. Town driving and heavy start stop, use hotter range K20PRU-11 instead. nothing much can do with 4a engine. take care of the fuel filter, air filter and use good engine oil, the 4a unit will be good enuff Hmm... i'm using Denso... wonder which one would it be..... so u mean for high revver.. use K20PRU-11? Btw, fuel filter is the oil filter? Good engine oil... any recommendation? i'm using Caltex Havoline... SAE 5W-30.... the mechanic says can last 5000km... but i've overshot over 4000km liao..... is it ok? i feel that my fuel economy is dropping.... is it caused by the degrading engine oil? Btw what car are u driving? and how come u have good knowledge about toyota cars? Link to post Share on other sites More sharing options...
Yongwd 1st Gear May 21, 2002 Share May 21, 2002 Hmm... i'm using Denso... wonder which one would it be..... so u mean for high revver.. use K20PRU-11? Btw, fuel filter is the oil filter? Good engine oil... any recommendation? i'm using Caltex Havoline... SAE 5W-30.... the mechanic says can last 5000km... but i've overshot over 4000km liao..... is it ok? i feel that my fuel economy is dropping.... is it caused by the degrading engine oil? Btw what car are u driving? and how come u have good knowledge about toyota cars? fuel filter is couple to fuel line - petrol oil filter is screwed onto engine block - engine oil Engine oil? Hmmm... u ask gavin lah, he engine oil siao. I use cheapest fully syn oil available. Thanks MCF for the Mobil 1 promotion, I bought total 10 bottles to expend. Take note your 4a-fe engine requires at least 5w-40/SD grade. Havoline has -30?? U using fully synthetic, semi synthetic or mineral engine oil?? Prolong your oil change will do more harm then good. Oil will start to thicken and leave sludge and carbon deposits on engine valve head. When engine oil is contaminated, oil temp will increase, ie wear and tear increase too.. etc etc.. Justify your driving habbits and do oil change accordingly. Your fuel economy bad perhaps is a sign that engine oil is due for change. I know more Mazda then Toyota, just share some knowledge I know about these cars. I driving a 1.3 Corolla. Mazda parts are generally cheaper, last longer then Toyota. Link to post Share on other sites More sharing options...
Dptm Neutral Newbie May 21, 2002 Author Share May 21, 2002 Hi Shagmobil Where can i find the spec on the thickness of the rotor? Or rather what is the thickness? Pardon my endless questions! Link to post Share on other sites More sharing options...
Luke721 Neutral Newbie May 21, 2002 Share May 21, 2002 it's located within the rims - but again, depends on the kind of rims which you've got ↡ Advertisement Link to post Share on other sites More sharing options...
Discriminatory practices towards the aged
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Budget 2025 - February 2025.
