Sash1401 4th Gear April 30, 2008 Share April 30, 2008 dear fellow bros, found tat the engine oil in my car is goin down gradually at a slow speed. is tat normal? if i were to top up, izit possible i top up wif other brand of engine rather than the one given by the servicing center? ↡ Advertisement Link to post Share on other sites More sharing options...
Ultramega 1st Gear April 30, 2008 Share April 30, 2008 (edited) Mixing engine oils of same brand still ok. Not advisable to mix different brand oils. My opinion is that engine oils are chemicals and chemicals should not be mixed without in-depth knowledge. You never know, the additives in the 2 oils may conflict with each other and do more harm than good to your engine. Edited April 30, 2008 by Ultramega Link to post Share on other sites More sharing options...
Dwoon 1st Gear April 30, 2008 Share April 30, 2008 Can mix lah.... if its synthetic oil you have inside your engine, then stick with synthetic for top up. Doesn't really matter what grade..... Been doing that for years as my ride is an oil drinker..... I lose as much as 2 quarts over the life of the OCI. (8 to 10K kms) I use left over Karlub for that matter. Link to post Share on other sites More sharing options...
Sky8807 1st Gear April 30, 2008 Share April 30, 2008 Mixing is not a problem. However, if possible stick to same type, syn to syn, min to min. Once u found the oil of your choice, stick to it. Link to post Share on other sites More sharing options...
Sash1401 4th Gear May 6, 2008 Author Share May 6, 2008 so in tat case diff brands cannot b mixed... so those from shell helix cannot b mixed wif esso brands? is tat correct? Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 6, 2008 Share May 6, 2008 [reply] dear fellow bros, found tat the engine oil in my car is goin down gradually at a slow speed. is tat normal? if i were to top up, izit possible i top up wif other brand of engine rather than the one given by the servicing center? Generally, I believe most engine oil can be mixed. Why don't you state which engine oil you currently using, and which engine oil you intend to top up with, that way will be more specific. Link to post Share on other sites More sharing options...
Tploh Clutched May 6, 2008 Share May 6, 2008 Brand = Shell, Mobil, Castrol, cxxxxxe, etc. Type = Pure Synthetic (eg: Amzoil), Synthetic, Semi-Synthetic and Mineral. SAE Grade = 10W-40, 5W-30, etc. Standard = API (SM or SL) or AECA ( A1, B2, etc). So, Brand can be mixed. Type can be mixed, except for Pure Synthetic. Grade try to keep within close proximity, and use Standard which fits your car. Reference : http://www.carbibles.com/engineoil_bible.html Link to post Share on other sites More sharing options...
Sstar Neutral Newbie May 6, 2008 Share May 6, 2008 Mixing engine oils of same brand still ok. Not advisable to mix different brand oils. My opinion is that engine oils are chemicals and chemicals should not be mixed without in-depth knowledge. You never know, the additives in the 2 oils may conflict with each other and do more harm than good to your engine. actually most of us mixed different brand oil quite often. imaging during car servicing, the old engine oil can not drained out completely, then put different brand oil...... Link to post Share on other sites More sharing options...
Sky8807 1st Gear May 6, 2008 Share May 6, 2008 Mix is NO problem. When u chgd brand, sure got mix. only after a few oil changes then it can be fully one type inside engine ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
