Typhoonz 4th Gear June 17, 2008 Share June 17, 2008 Asking for my friend who owns the above... Her Verna 1.6 (A) has this screeching noise when she turning the steering wheel... She said she has got this done before where the AD changed the bearings... Anyone also has this problem and what's the cause? The car is turning 3 at the end of the year so I told her to quickly bring it down and get them to fix it before it expires... ↡ Advertisement Link to post Share on other sites More sharing options...
Rb26dett Clutched June 17, 2008 Share June 17, 2008 could be steering pump.have it checked if there is any leakage. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 17, 2008 Author Share June 17, 2008 Thanks... Link to post Share on other sites More sharing options...
Tohto Hypersonic June 17, 2008 Share June 17, 2008 Check the power steering oil level. Make sure no leakage. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 18, 2008 Author Share June 18, 2008 Thanks for the tip! Link to post Share on other sites More sharing options...
Nkps 1st Gear June 18, 2008 Share June 18, 2008 aiya.... she swee bo? if no swee-er than minah, forget it lar... Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 19, 2008 Author Share June 19, 2008 Don't like that lah... Link to post Share on other sites More sharing options...
Iygnaug 1st Gear June 19, 2008 Share June 19, 2008 Asking for my friend who owns the above... Her Verna 1.6 (A) has this screeching noise when she turning the steering wheel... She said she has got this done before where the AD changed the bearings... Anyone also has this problem and what's the cause? The car is turning 3 at the end of the year so I told her to quickly bring it down and get them to fix it before it expires... What wheels and rims is she on? Maybe it's a case of wheels too big for the fender, thus when the wheel turn, it hit the fender...the sound outside the cabin can be translated to screeching sound inside the cabin.. just a guess only.... Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 19, 2008 Author Share June 19, 2008 Don't think it's her wheels size as this problem only occurred recently... Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 19, 2008 Share June 19, 2008 [reply] Don't think it's her wheels size as this problem only occurred recently... Is the sound like rubbing sound or high pitch screetching sound? Cos if the shock absorber worn out, it will cause the car to lower and hence wheels may rub against the car chassic when doing a full turn. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 19, 2008 Author Share June 19, 2008 She don't have to do a full turn for the screeching sound to happen... A slight turn on the wheel will set it off... Link to post Share on other sites More sharing options...
Tohto Hypersonic June 19, 2008 Share June 19, 2008 It seems like the power steering pump is not working properly or no oil flow..Go to the workshop to check. Link to post Share on other sites More sharing options...
Route88 2nd Gear June 19, 2008 Share June 19, 2008 Screetching sound must be from the belt.Belt drive the pulley which in turn generate the pump. Pump spoil,get warranty to replace pump Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 20, 2008 Author Share June 20, 2008 Think she has sent it back to the AD to check liao... Told her to stress the AD... Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 20, 2008 Author Share June 20, 2008 Her friend even told her that the steering column got problem... Link to post Share on other sites More sharing options...
Tohto Hypersonic June 20, 2008 Share June 20, 2008 So what is the problem after checking at AD.. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear June 20, 2008 Author Share June 20, 2008 Don't know... She hasn't called me yet... Link to post Share on other sites More sharing options...
Powerkeong Neutral Newbie September 10, 2008 Share September 10, 2008 Hi Bro, I also own a Verna 1.6A. I bought it second hand. it 2 yrs 3 months old now. Still got Warranty at Komoco Motor? I also have this screeching sound problem. When I go up multi-storey carpark den got... If got warranty I'll go down n get it fixed. ↡ Advertisement Link to post Share on other sites More sharing options...
Intermittent rattling noise, car in ICU
Steering leather wrapping
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
2024 6th Generation Hyundai Accent / Verna
Steering rack noise on 2010 Altis
Extending quiet time by 1½ hours among recommendations to tackle neighbourhood noise in Singapore
