GPS co-ordinates
Razgriz
Hi ... don't know whether i m in the right channel anot, but can any1 enlight me on where can i find particular co-ordinates of a HDB blocks? need it due to work requirement
Much help required pls [drivingcar]
Thanks!
*if post wrong place kind shift it right.. thanks*
1.) bring your gps to the block , and write down the co-ordinates
2.) run google earth and navi to the block and record down the co-dinates given by google earth
So leceh
I have a POI file I downloaded from one of the local mapping forum. It contains the postal codes in Singapore in a '.csv' format. I can send it to you if you want, open it and search via the postal code and the long. and lat. are the 1st and 2nd column. The file is about 1MB. Or you can let me know the postal code and I will reply you the position.
1) Use streetdirectory.com.
2) Enter the postal code of the HDB block (if known) to search.
3) After block is found, click on the "how popular is this address".
4) Click on "Show Nearby Amenities" link.
5) Click on "Analyse Loc" button.
6) Viola! The lat-long is displayed.
Anyone knows of a shorter way?
Edited by Huggable
Huggable: Much thanks for your info~ really of much help!
FoxFire: jus to check, need to hav GPS system to open the file? or computer can? as i currently do not hav GPS system
Caravan: Tried google map, cant seems to find, dunno is me jialat, or . .....
Hi, '.csv' is comma separated text file, MS Excel should open it easily or you can just use text editor to open it. Sent to Civic6656.
