Sammy_koh Neutral Newbie June 15, 2009 Share June 15, 2009 any Bros out there face the mentioned problem. The washer cant spray already. Wipers working. When depress the Washer can overhear the motor running sound so believe motor is working. When i pull out the cap. the water level gauge is broken which believe bits of plastic might cause the jam. Went to motorgarde quote me around 100+ to replace the motor. Is there a need? Otherwise by removing the bits of plastic would do the trick? ↡ Advertisement Link to post Share on other sites More sharing options...
Ixat 1st Gear June 17, 2009 Share June 17, 2009 Whether there is a need to get it fix depends on how often you use the spray. I seldom wash my car and use it often Get the issue diagnosed at another workshop for a 2nd opinion if you are uncomfortable with the quote you received. Link to post Share on other sites More sharing options...
Amortifiedpenguin Clutched June 17, 2009 Share June 17, 2009 wiper water needs to be topped up once in awhile. you do know that. right? Link to post Share on other sites More sharing options...
Enduro25 Clutched June 25, 2009 Share June 25, 2009 still under warranty?? Link to post Share on other sites More sharing options...
Icejelly76 Clutched June 28, 2009 Share June 28, 2009 could be wax gotten stuck in the nozzle. Or, the tube (under the bonnet) leading to the nozzle came off. Link to post Share on other sites More sharing options...
Hp93868686 Clutched June 28, 2009 Share June 28, 2009 happened 2 mine as well... due to those blue liquid window wash which i pour into the wiper tank and after awhile if u dont use it , it will dry up and hardened inside the tube and nozzle hole . Now only wait till raining then on the wiper ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
Anybody bought those portable car washer
